Alignment a warranty issue??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PPower05, Dec 26, 2010.
  1. Dec 26, 2010 at 12:03 PM
    PPower05
    PPower05 [OP] Well-Known Member
    Perry
    Ranson, WV
    2010 SR5
    Hi all,
    My Tacoma was recently in a rear end collision ($8700 worth of damage), and the service department @ toyota told me that I would need an alignment, as my tires where cupping. The truck only has 14,500 miles on it, and I have gotten the tires rotated once. Is this a warranty issue? My 2010 double cap is all stock, never done anything crazy with it, did one 2200 mile road trip and that was about it.... Any suggestions?
    Thanks!
  2. Dec 26, 2010 at 12:14 PM
    builthatch
    builthatch MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    could it have occurred from the accident? it's hard to say which direction you can go. i'd probably have had it grouped into the damage repair if i were you, either way, since the truck was in new condition before the accident and now has an issue.
    i'd get a second opinion from a reputable independent shop anyway.
  3. Dec 26, 2010 at 12:20 PM
    Archangel
    Archangel Discount Tire Company
    Charlotte, NC
    13 Malibu LT
    Toyota guarantees their alignment for 20,000. I've had this argument already at 5k on my 2010. They claim if it screws up the tires because of alignment, then they will replace the bad tires and redo the alignment.
  4. Dec 26, 2010 at 12:23 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Rob
    Pacific Northwest
    2018 TRD OR DCSB
    I would almost have to believe it has to do with the accident...
    I have driven over 50k miles without getting an alignment before..
  5. Dec 26, 2010 at 7:30 PM
    PPower05
    Perry
    Ranson, WV
    2010 SR5
    I really dont think it has anything to do with the accident. You can see an ever so slight cupping to the tires already beginning to form on the outsides of the tires. The truck was only driven approx. 20 miles while at the shop, you can clearly tell that it was caused by an improper alignment or inproper suspension settings. However, with that being said, I know most dealers consider tires to be a "wear items"; Having driven sports cars before my Taco, I know that dealers wouldn't TOUCH clutch issues (my friend had a car that had a clutch go bad around the 15K mark), simply because it was considered a "wear" item.
  6. Dec 27, 2010 at 7:33 AM
    cjimenRR
    cjimenRR Be Good or Be Good At It
    North Hollywood, Ca
    12' Sport DC,LB, 4x4
    Which tires are cupping, front or back? Your tires should have been rotated 3 times already with that kind of mileage so it may be a combination of both bad alignment/lack of rotation. Alignment is under warranty for 12mo or 20k miles which ever comes first
  7. Dec 28, 2010 at 2:15 PM
    PPower05
    Perry
    Ranson, WV
    2010 SR5
    3 times?? I thought it was once every 6,000 miles??
  8. Dec 28, 2010 at 2:43 PM
    bambooshoots
    bambooshoots Be a fountain, not a drain.
    Kevin
    College Station, TX
    2015 Honda Accord Sport
    I did it again. Got tired of paying truck payments and gas and traded in for a 2015 Honda Accord Sport since I enjoyed my 2013 Sport so much.
    Some people do the rotate/balance for the tires every 5,000 miles.
    As far as alignment goes I believe it should be every 6,000 miles or whenever needed.
