Alignment Adjuster Seized
Discussion in '2nd Gen. Tacomas (2005-2015)' started by canyonchaser, Aug 14, 2015.
  1. Aug 14, 2015 at 9:35 AM
    canyonchaser
    canyonchaser [OP] Member Known Well
    Dave
    Utah
    LR TRD PRO MT
    My dealer told me they couldn't get a perfect alignment because the left adjuster for toe-in is seized. He said typically when this happens they replace the entire control arm. I'd like to avoid that if possible.
    Could someone show me where the adjuster is? I'd like to start hitting it with penetrating oil on a regular basis so that next time I need an alignment there's a chance it'll move.
    Thanks,
    dp
  2. Aug 14, 2015 at 10:31 AM
    nickonfire700
    nickonfire700 Reg. Cab Nation Member
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Satoshi grill, 3rd Gen TRDOR Bucket Seats, TRD front skid plate, TRD Beadlock Wheels, TRD Exhaust, OEM bed mat, LCE Header, LCE Balance Shaft Delete, ECGS front diff bushing, TRD Sport LSD rear diff, Diode Dynamics SS3 Sport fog lights, Stainless Steel Brake-lines, No A/C with Defrost mod, 2014 OEM Radio, Illuminating 4x4 switch, Various LEDs, UWS Toolbox, Proven Design Products Mudflaps, Bilstein 8112 front Coilovers w/ rear Bilstein 5125's/IronMan lift leaf springs, Archive Garage Hammer Hangers, JBAs HD UCAs, SOS Bolt-On rock sliders, TRD bedside decals, ImMrYo Mirror Bracket, Relocated rear diff breather, 2019 Steering wheel, color matched door handles
    You can try with penetrating oil, but it will never come loose. The cam bolt siezes to the bushing on the lower control arm, making it impossible to make any adjustments. The only option is to replace the bushing and cam bolt assembly. I had to do the same on my truck, as two were seized.
    The cam bolts are on the inside of the lower control arm, you should see a bolt head, then a circular cam right behind it (they are connected).
