alignment adjustments
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 225nontypical, Oct 19, 2010.
  1. Oct 19, 2010 at 12:50 PM
    225nontypical
    225nontypical [OP] ????????????
    backwoods
    11 tundra DC TRD OffRoad
    bilstein 5100's weather tech floor mats katskinz leather heated seats
    ok i understand what all the numbers and adjustments mean and do, but i have a question, since i do not know how to adjust the alignment.
    i have LR UCA's i understand how those work (adjust) but is there a caster adjustment on the truck other then my LR UCA'S?
    here is why i ask, i was at firestone to get my alignment checked (the same one i showed how to adjust the UCA's when i got them). anyway i told them i wanted 2.4-2.7 of caster. when i picked it up they told me they could not get it there? the explanation was that when they adjusted the UCA'S it went to far (i was at 2.2 when they started and it jumped to 3.0) so i told them do not adjust the UCA's just use the trucks adjustments. they told me the truck does not have adjustable caster????? am i just crazy or are they full of crap!!!!!!!!!!!!!!!!!!!!!!! so is the truck at a set caster? that just can not be there has to be an adjustment on the front suspension for caster right?
    anyway with the vast knowledge on this site i figured someone could set me straight. for the life of me i can not figure out how they could get it perfect 5 months ago and now i am at 2.2 and 2.7 and they can not fine tune it. thanks for the help.
    i am starting to think there is not a shop around here that really knows what they are doing or they are just lazy.
  2. Oct 19, 2010 at 8:25 PM
    225nontypical
    backwoods
    TTT anyone
  3. Oct 19, 2010 at 8:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Caster is adjusted via the lower control arm cam adjusters. THe shop guys are idiots.
  4. Oct 19, 2010 at 10:04 PM
    pinktaco808
    pinktaco808 Hot Steppa
    rightttt
  5. Oct 19, 2010 at 10:08 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    I don't mean to offend anyone, but DON'T go to firestone for a good alignment. Through all my rigs and various lifting experiments I've learned that you should always go to a specialist if you have any aftermarket suspension parts. Go to the place in town that has a bunch of lifted trucks in the front lot: they'll know what can be tweaked and can troubleshoot. Call your local 4x shop or auto-fab shop and ask them where they send their stuff. It might cost $20 more but it's worth it.
  6. Oct 20, 2010 at 9:12 AM
    225nontypical
    backwoods
    the problem is they all either send it to Les schwab's or Firestone. i have called most of them. (schwab's seems to be the favorites) i think i am just stuck with morons
  7. Oct 20, 2010 at 9:13 AM
    225nontypical
    backwoods
    thank you, you confirmed exactly what i thought thanks Chris
  8. Oct 20, 2010 at 10:22 AM
    B...
    B... Member
    SLC, Utah
    some of this, a little of that
    Can you reccomend anybody in Reno?
  9. Oct 20, 2010 at 1:33 PM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    Yeah Firestone blows for alignments on anything with a lift. I have their lifetime alignment and they can never get it right.
  10. Oct 21, 2010 at 7:28 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I've only used Firestone once, when my prefered shops were all busy and I wanted it done that day. They did the alignment to my specs (0/0/2.1 - for a .85 Billy lift and 265/70 tires), and were all right on within reason,,, was actually 2.1 and 2.2 if I recall correctly. Now, they did need to do it twice that day as they aligned it and then the steering wheel wasn't quite centered on the test drive. They re-did it and all is good.
  11. Oct 21, 2010 at 8:24 AM
    toku58
    toku58 Well-Known Member
    HAWAII
    4x4 Beast!
    6" Fabtech Stage II, 17x9" Centerline Eclipse rims, with 12.5x35x17" BFG KM2's. On board air system,Toyota skid plate, spidertrax wheel spacers, TRD CAI w/AFE ProDry filter (21-90045),Flowmaster Dual exhaust, GrillCraft grill w/custom emblem, Custom Shifter, BushWacker fender flares, Hood struts, Underhood lights, TW driveshaft, Wet Okole seat covers, Dashlight mod, Many other little things to make the truck complete!
    It's sad when the people who do alignment, don't understand alignment.
    On you LCA's ther are 2 cams on each side. the front cam basically adjusts CAMBER, and the rear cam adjust CASTER. BUT! Adjusting either one WILL affect the other.
    The theroy to setting up LR UCA's is a process. You set the LR's to Neutral and see what numbers you can acheive. This is used as your baseline.
    Then if more caster is needed? you move the LR's.
    BUT! Before you add Caster. Make sure the LCA's are max, and it cannot get anymore Caster. i.e. 2* caster is the most you can get. Because when you adjust the LR's more than likely you will be about 3* (If I remember correctly each click of the LR's will add/subtract 1*)
    So basically your truck still uses the RANGE of adjustment of the LCA's, But the LR's move the range up or down 1*.
    Make sure the tech understands that the LR's will increase/decrease the range, so he still needs to use the entire range of adjustment.
    Good Luck!
    Oh? P.S. more than likely he will be offended that someone off the street knows more than he's learned durring his extensive years at his job. So he might not want to listen to what you have to say.:eek::rolleyes:
  12. Oct 21, 2010 at 10:47 AM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    ^ That's right on. I also had the same problem where the guy didn't really understand what he was doing. He just looked at the screen and followed the directions. He couldn't get the adjustment where I wanted so he let me do my own alignment. This was at Les Schwab. Most shops wouldn't let you do that but he was a pretty cool guy and I told him off the bat if he couldn't get it to spec to call me and I'd help him.
  13. Oct 21, 2010 at 11:08 PM
    pinktaco808
    what about slammed trucks???
