Alignment after installing 5100's
Discussion in 'Suspension' started by 05RedTaco, Sep 29, 2012.
  1. Sep 29, 2012 at 3:31 PM
    05RedTaco
    05RedTaco [OP] Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Got alignment done after I installed 5100's set at 2.5 with stock springs. According to the print out it seems that they were able to get the alignment within stock specs...
  2. Sep 30, 2012 at 9:53 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    It's not good. Look at the red indicator for caster. Didn't they discuss that with you? It's gotta wander like a mother. Maybe have them lose some camber to get more caster? Install aftermarket UCAs? You should have read here that you cannot jack up the 5100s to 2.5 without some kind of mod.
  3. Sep 30, 2012 at 10:07 AM
    4banger09
    4banger09 Well-Known Member
    Alex
    Nb, Canada
    09 Tacoma Access cab 4cyl
    Leveled
    Apparently you can, but just with a lot of caster
  4. Sep 30, 2012 at 10:39 AM
    05RedTaco
    Tony
    Scottsdale
    It doesn't wander, drives straight, yes I do need UCA's...
    The good news is that camber is within specs and my tires shouldn't wear funny...
  5. Sep 30, 2012 at 10:54 AM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    even without new uca's , the guy who aligned this should have been able to get more caster than that. That is brutal. I have a hard time believing your steering doesnt feel loose. Have you taken your truck on the highway yet? I am guessing your tech set the toe and ignored the rest.
  6. Sep 30, 2012 at 12:08 PM
    05RedTaco
    Tony
    Scottsdale
    Had it up to 74mph on highway (speed limit is 65 around here), everyone drives 8-10mph over. It feels solid and drives good. I know they moved the LCA bolts. I remember in what position they were, because I installed the 5100's the day before and the easiest way how to swap shocks on Tacoma is to loosen the LCA bolts.
    I had it pedal to the metal on local 1/8mile dirt track last night and it felt solid.
    At the end of the day I am ok with the alignment as far as the camber is somewhat normal and wont wear my new expensive tires in a weird way...
  7. Sep 30, 2012 at 3:24 PM
    Hairy Taco
    North of Hell
    08 TRD
    If you are happy, and it steers proper that is what matters at the end of the day.
    My caster was initially just over 1 after my lift and alignment. There was no doubt that my steering quality had been compromised. Since installing my more adjustable uca's my caster is at 2.4 and I am can essentially keep the truck steady with one finger if I choose.
  8. Sep 30, 2012 at 3:39 PM
    05RedTaco
    Tony
    Scottsdale
    However I see your point about the caster. I have no choice, but to start saving for UCA's :eek:
    Hopefully I wont do any permanent damage to the suspension by running it with the caster so out of whack :eek:
  9. Sep 30, 2012 at 5:49 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    My caster is at 1.5 and Im still getting it done again lol
  10. Sep 30, 2012 at 5:53 PM
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    All I know is you did this down the street from me :)
  11. Sep 30, 2012 at 7:34 PM
    05RedTaco
    Tony
    Scottsdale
    Lol the shop is by my house... I live by Indian School and 24th st...
  12. Sep 30, 2012 at 7:36 PM
    GREEKBOY12295
    Nick
    Phoenix, AZ
    7th street and bethany son
  13. Oct 1, 2012 at 9:40 AM
    BTO
    California
    Low caster won't damage or wear anything. It should make it squirrely as hell on the freeway is all. If it's not then no harm done. I just don't understand how it can be. Maybe it's your camber plus your tires just happen to hit a sweet spot?
  14. Oct 1, 2012 at 9:47 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Mine seems fine on the highway with a 1.5 caster, but you can tell the wheel is back and it now rubs on a turn over a bump on the cab mount
  15. Oct 1, 2012 at 10:52 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Does anyone know if adding a larger tire will throw out the alignment?
  16. Oct 1, 2012 at 11:52 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    No , it won't
