Alignment after leveling? Need? Timeline?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Msharp, Dec 14, 2015.
  1. Dec 14, 2015 at 4:50 AM
    Msharp
    Msharp [OP] Member
    Micheal
    Central\Northern Virginia
    2015 TRD Off Road Pyrite Mica
    Bilstein Adjustable 1.75" Matched window tint Toyo AT2 XD bully 17"
    I know that getting an alignment after doing any front suspension work should always happen but i have a quick question regarding that.
    I just had bilsteins set at 1.75 installed and before that the truck was pulling to the left a little bit after the install it runs straight as an arrow.
    Does the alignment need to be done still or give it some time to settle in? How much time?
    Thanks for your help
  2. Dec 14, 2015 at 5:51 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    What coils did you use? If stock coils that already have some miles on 'em, I wouldn't expect it to settle a lot. Many of the newer, better brand coils are now expected to settle less than older versions. I wouldn't wait long. You can screw up a tire pretty quick if there's much of a misalignment.
  3. Dec 14, 2015 at 5:56 AM
    Msharp
    Msharp [OP] Member
    Micheal
    I did use stock coils. Wouldn't it be pretty noticeable if it were out of alignment? I am due for service this week so i will probably just have the dealership go ahead and do an alignment. Better safe than sorry i suppose.
    Thanks for the advice
  4. Dec 14, 2015 at 6:32 AM
    flying_az
    flying_az Well-Known Member
    Scottsdale, AZ
    2014 TRD Off Road, 4X4, MT
    Old Man EMU, Avid sliders, Pelfreybilt skids, winch mount bumper & winch, 265/75-16 BFG KO2s, fiberglass tonneau cover, flexible mud flaps, locking tailgate, debadged, decals removed, breather relocate
    You may consider going to Firestone and purchasing a Lifetime Alignment. For around $200 they will set alignment every 6 months, or whenever needed, for as long as you own it. If you plan on doing much off-roading, or making addition changes to the suspension in the future, it may be worth it to you.
  5. Dec 14, 2015 at 6:56 AM
    Clearwater Bill
    Billy
    Largo Florida
    Depends.
    Caster is what normally impacts steering center more than anything. While the lift may have 'fixed' that, it may have been at the expense of some camber which being out of spec can create some unusual wear.
    Toe is the other setting to 'eat' tires, either on the inner or outer edges. You generally don't feel that in 'tracking', but in a sports car the well initiated can feel it in turn in response.
    So yes, you should go ahead with an alignment. Just to be sure all is well.
  6. Dec 14, 2015 at 7:22 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    guaranteed toe caster and camber are all sorts of messed up.... get an alignment if you like your tires.
  7. Dec 14, 2015 at 9:09 AM
    Msharp
    Msharp [OP] Member
    Micheal
    Thanks to everyone for the lesson in alignment. Sounds like I will be heading to the shop soon to get it straightened out.
    Then on the other hand the quicker I "wear" these tires out the sooner i can get the ones that I really want. Thats a logical issue that the wife cant argue with.
  8. Dec 14, 2015 at 10:46 AM
    nd4spdbh
    SoCal
    Pff.... get new tires N O W..... the rugged fails SUCK AT LIFE.... and pretty much are only good in dry pavement. Go get some hankook dynapro atm rf 10's.... michline ms2's etc... and sell the rugged fails on CL.... the 400ish you will spend after its all said and done on tires is WELL worth it.
  9. Dec 14, 2015 at 10:49 AM
    Msharp
    Msharp [OP] Member
    Micheal
    Its funny you say that... I just listed the wheels and tires on CL to see what I can get for them.. The upgrade bug has bitten hard and wont let go.
  10. Dec 14, 2015 at 10:54 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Yet ANOTHER wallet falls victim to TW............. ;)
    ToyotaDriver likes this.
  11. Dec 14, 2015 at 11:40 AM
    nd4spdbh
    SoCal
    Just tires... you dont need new wheels.......
    but sliders might be a good thing :D
  12. Dec 15, 2015 at 2:42 AM
    Msharp
    Msharp [OP] Member
    Micheal
    Pardon my ignorance.... Sliders??
  13. Dec 15, 2015 at 5:11 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
