Alignment after lift?
Discussion in 'Suspension' started by radbowman, Mar 25, 2009.
  1. Mar 25, 2009 at 4:21 PM
    radbowman
    radbowman [OP] Member
    Rochester
    02 Tacoma TRD
    ARE Topper
    I am looking to lift my 2002 double cab, at what hieght of lift do you create an issue with front end alignment? I mostly use mine on the road but I hunt, fish etc. and do get off the beaten path.What I don't want to do is lift it, make it unstable and then not like how it drives down the highway. I have read about issues with the CV angles but what about the angle of the steering arms, wouldn't that effect the alignment process?
  2. Mar 25, 2009 at 4:23 PM
    tacoma08MZ
    tacoma08MZ Well-Known Member
    Levi
    Pittsburgh, PA
    2008 Access Cab 4x4
    tinted head/tail lights-blacked out badges-3 inch tuff country lift 33 inch nittos-black steelies custom spare bed mount-hilift-weathertechs-kenwood dnx5120 dvdnav headunit-remote start-painted grille surround-fog lights-grillcraft black mesh grille
    Get an allignment anytime you lift it any height...someone correct me if im wrong!
  3. Mar 25, 2009 at 4:56 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
  4. Mar 25, 2009 at 5:10 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    in short....yes
  5. Mar 25, 2009 at 5:12 PM
    Blackened Taco
    Blackened Taco Well-Known Member
    Tony
    Virginia
    2005 AC 4WD TRD Sport Tacoma Speedway Blue
    3 inch suspension lift, 16 inch TRD FJ Cruiser black alloys, 33 X 12.5/16 Swamper Trxus M/T, Line-Xed Toyota skid plate, TRD exhaust, TRD cold air intake, Full tint to match factory tint, In channel wind deflectors, Custom wired hidden XM, Black shorty antenna, Black background headlights, Sockmonkey TRD decals, Kenwood 5120 HU with navigation, Boston Acoustic SL60 front compnonent speakers, SL65 rear speakers, Grillcraft lower mesh grille, Black badging, AromorTech Offroad rear bumper and rear shackle flip kit Access tonnosprt cover, 12 volt power adapter wired in under the dash for standard plug in items. Recently added Devil Horn Toyota Logo, Thanks Andres.
    x3 ............ for the CV joints consider a diff drop it helps.
  6. Mar 25, 2009 at 5:32 PM
    radbowman
    Rochester
    02 Tacoma TRD
    ARE Topper
    I have heard that lifting a vehicle in general creates problems with being able get it into proper alignment have you had any issues like that?
  7. Mar 25, 2009 at 5:35 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Some folks have been luck and didn't need anything. Some have installed aftermarket upper control arms to make sure and avoid problems.
    I'll be using UCA's to make sure mine is right.
  8. Mar 25, 2009 at 5:57 PM
    radbowman
    Rochester
    02 Tacoma TRD
    ARE Topper
    Adding UCA's supposed to remedy any alignment problems?
    What I'm thimking is adjusable Coilovers 2 or 3 inches, diff spacers, and AAL 's for the rear.
  9. Mar 25, 2009 at 5:59 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    I lifted mine 3 inches and did an alignment because the front toe was slightly off, everything was perfect, didnt even really need it. Also on the first gen Tacomas you dont need the UCA's its a good idea to get them but there not needed :D
  10. Mar 25, 2009 at 6:07 PM
    Blackened Taco
    Tony
    Virginia
    Most common for a lifted vehicle is the caster offset, for the most part the toe and camber stay pretty much in place. If you use a spacer lift/leveling kit alot of times you can get your caster closer buy rotating your coil springs 180 degrees. I don't know if that also works with coil over replacements and so forth, but if you can spin the coils, then they also should be able to help some caster issues as well. I need to do this to my truck, I am retarded on one side and accellerated on another, causing some pull, but this is not a tire wear issue so I have been slow on doing it.
  11. Mar 25, 2009 at 6:44 PM
    radbowman
    Rochester
    02 Tacoma TRD
    ARE Topper
    What is the difference in the 1st and 2nd gen. Tacoma suspension, that would make it so you don't need to replace 1st gen. UCA's with a lift of 2 to 3 inches? Don't mean to be a pain just tryin' to learn something.
  12. Mar 25, 2009 at 6:47 PM
    TRD4x4858
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    The UCA design is different on the 2nd gen
  13. Mar 25, 2009 at 6:53 PM
    radbowman
    Rochester
    02 Tacoma TRD
    ARE Topper
  14. Mar 25, 2009 at 7:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Never heard of rotating your springs to regain lost caster....where did you here this? The caster is determined by the relation of the hub between the upper and lower control arms. As the suspension is pushed down, the top of the spindle is moved forward reduceing caster. Dont think it has anything to do with the spring position.
