Alignment after Lifting
Discussion in 'Suspension' started by 2girlsdad, Jul 7, 2011.
  1. Jul 7, 2011 at 8:24 PM
    2girlsdad
    2girlsdad [OP] Active Member
    Garner, NC
    V6 4x4 TRD Off Road Sport
    Before I get blasted, I have searched. I know there's issues with 3" lifts and alignments without new control arms. But I am leaning towards a 6" lift and I don't see much information on alignment issues. I'm not ok with castor or camber being "a little off". I want it to be spot on. Of the Fabtech and the ProComp 6" kits, which one has issues with getting the alignment right? Are both fine, or are other parts needed to be purchased other than what's included in the kits? I don't want to wear out $1200 or more worth of tires early because I can't get the front end tracking straight. Does anyone have any input on this? If it's posted somewhere else, I have overlooked it, because I have yet to find it. Thanks.
  2. Jul 7, 2011 at 8:29 PM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    6" lift should give you less alignment problems, if any, than a 3" lift. The 3" lift pushes the limits of what is already there. The 6" kit moves everything down with brackets.
  3. Jul 10, 2011 at 7:53 PM
    2girlsdad
    Garner, NC
    awesome, thanks
