Alignment after LR UCAs....Too much caster?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BigHeadTaco, Mar 6, 2013.
  1. Mar 6, 2013 at 1:55 PM
    BigHeadTaco
    BigHeadTaco [OP] GFY
    Big Head
    Full OME lift 885's with Dakar leaf springs. LR UCA's. ImMrYo relocation bracket.
    My set up is OME 885 with rear dakar springs. Installed the LR UCAs yesterday and had my alignment done today. I have seen that ideal caster is 2.4 and greater. Is my caster excessive? It drives ten times better with the new UCAs compared to stock, any input is appreciated.
  2. Mar 6, 2013 at 1:56 PM
    SFSMedic
    SFSMedic Well-Known Member
    Brett C
    Corona, CA
    12 4-door 4x4 TRD Offroad
    Subscribed as I just did my lift with UCAs and will be having my alignment don't this weekend.
  3. Mar 6, 2013 at 2:01 PM
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    The higher the better is what I heard on caster and from what I can tell and have read thats pretty damn near perfect. The experts will chime in soon.
  4. Mar 6, 2013 at 2:02 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Closer to 3 would be better
    What setting did you put the LR UCA's at during install ?
  5. Mar 6, 2013 at 2:02 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I thought the magic numbers were 3,0,0
  6. Mar 6, 2013 at 2:12 PM
    BigHeadTaco
    Big Head
    D or 0....
    This alignment is correcting firestones attempt to adjust the LR UCAs.
    The boner at firestone was using a giant pry bar for some reason and scratched my shocks and UCAs...needless to say I told him to stop and I went elsewhere.
  7. Mar 6, 2013 at 2:15 PM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Anybody have the LR alignment instructions? I couldn't get the idiots at Firestone to understand that they can adjust the ball joint.
  8. Mar 6, 2013 at 2:16 PM
    OZ-T
    Peter North
    British Columbia
    Maybe they are trying to compromise caster for camber with the factory alignment cams , are they aware that they can adjust camber on the UCA ?
    Did you tell them what specs you wanted ?
  9. Mar 6, 2013 at 2:18 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
  10. Mar 6, 2013 at 2:19 PM
    OZ-T
    Peter North
    British Columbia
  11. Mar 6, 2013 at 2:20 PM
    BigHeadTaco
    Big Head
    Yeah I told them. I said 2.4 on the caster or greater. I didnt specify exact #'s. Good thing is that I have no rubbing issues.
  12. Mar 6, 2013 at 2:20 PM
    evanmb31
    evan
    connecticut
    09 trd off road
  13. Mar 6, 2013 at 2:21 PM
    ckeene9
    Chesterfield, VA
    See Build Thread
    Thanks!
  14. Mar 6, 2013 at 2:22 PM
    OZ-T
    Peter North
    British Columbia
    Yours is rev 2/11
    Mine is 2/13 :)
  15. Mar 6, 2013 at 2:24 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    :pout: someday ill beat you at internets
  16. Mar 6, 2013 at 2:25 PM
    BigHeadTaco
    Big Head
    So I assume my caster is not an issue?
  17. Mar 6, 2013 at 2:30 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Caster is not a tire wear issue, it's a handling issue. High caster means you'll track great on the highway but won't want to corner as well. Camber and toe are the ones that will wear your tires unevenly if you don't have them set correctly, caster will not. My opinion, if it drives nice, I wouldn't worry about it.
  18. Mar 6, 2013 at 2:36 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    Your caster is fine, but you might find you have body mount rubbing issues now depending on the tire size and rim back spacing you are running. Ideally you want to get as much of your caster out of the stock adjustment as you can. Adding positive caster at the bottom moves the tire forward whereas adding caster at the top moves the tire back in the wheel well and closer to the body mount. If you add too much caster at the top with the LRs, not only are you moving it back with the upper adjustment, but then the tech has to take caster out of the bottom to bring you back into spec which further moves the wheel back into the wheel well.
    Basically, if you are not having rubbing issues, then I wouldn't worry about having a little extra caster.
  19. Mar 6, 2013 at 2:55 PM
    BigHeadTaco
    Big Head
    Thanks all!
  20. Mar 6, 2013 at 3:04 PM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    where exactly do you have your LR's set? pic?
