Alignment after tire size increase.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 8054x4, Sep 4, 2014.
  1. Sep 4, 2014 at 12:52 PM
    8054x4
    8054x4 [OP] Well-Known Member
    south 805
    2013 DCLB 4x4 TRD Sport
    Snugtop Rebel topper Goodyear Duratracs
    Hi all, I have a 2013 double cab long bed, 4x4 sport. About 6 months ago I lifted my truck with aN OME kit, did not install the uca's that I had (I got about 2.75" of lift up front). Rubbing was minimal and I was stoked. At the time I had 265/70/17 duratracs mounted on stock sport rims with spidertraxx 1.25" spacers, and got it aligned with no issues. Recently I replaced the duratracs with Yokohama geolanders sized at 285/70/17 on the same stock sport rims and spacers. But the alignment was WAY off (towards the right) when I just replaced the tires, they were mounted and balanced properly. Does increasing the tire size really throw off the alignment that much? Any help would be great. Thanks
  2. Sep 4, 2014 at 12:55 PM
    shore990
    shore990 Well-Known Member
    Colorado
    2014 TRD Off Road
    I went with a taller tire, not wider, but didn't have any issues. I wouldn't imagine tire size would matter. None of the angles should change.
    Unless maybe the alignment wasn't perfect to begin with and the bigger tires exaggerate that difference.
  3. Sep 4, 2014 at 12:55 PM
    yaapp
    yaapp Well-Known Member
    Bay Area, CA
    URD CAI front: Fox 2.5 w/ reservoir 700lbs coil Camburg UniBall Rear: 2.5 w/ reservoir
    With a lift that much, why didn't you install the UCA's?
  4. Sep 4, 2014 at 2:08 PM
    8054x4
    south 805
    I didn't install them because I was told 3" was the magic number for having to install them. I got just about 2.75" of lift out of the kit. As stated, had no probs with them with smaller tires.
  5. Sep 4, 2014 at 2:09 PM
    8054x4
    south 805
    Alignment was just a hair off to the left after the kit was installed, didn't take much to get it perfect the first time.
  6. Sep 4, 2014 at 2:41 PM
    shore990
    Colorado
    2014 TRD Off Road
    I think you should be fine without UCAs.
