Alignment after UCA install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dr. Emmett Brown, Jul 21, 2019.
  1. Jul 21, 2019 at 7:11 PM
    Dr. Emmett Brown
    Dr. Emmett Brown [OP] Well-Known Member
    Will be ordering JBA high caster UCAs. I'll be installing UCAs myself.
    Not touching LCAs but seem like with the changed caster from the UCAs an alignment is needed asap. Am I correct to think this? If so, how long can I drive on no alignment before appointment?
  2. Jul 21, 2019 at 7:12 PM
    ajmogen
    ajmogen Well-Known Member
    Aaron
    Wisconsin
    OR MT TACO T4R YARIS MT Corolla Hatchback MT
    You will need an alignment immediately
  3. Jul 21, 2019 at 7:13 PM
    sd1uh8as
    sd1uh8as Well-Known Member
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    Get an alignment ASAP unless you want fucked up tires
  4. Jul 21, 2019 at 7:13 PM
    Dr. Emmett Brown
    How long after is acceptable? We talking like that day or up to a week isn't gunna run me off the road?
  5. Jul 21, 2019 at 7:14 PM
    Dr. Emmett Brown
    Looking for a reason to ditch these 265/70s lol but advice taken. Appreciate it
  6. Jul 21, 2019 at 7:18 PM
    sd1uh8as
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    When you drive it after replacing the UCA, you will understand, first hand, why you need an alignment right away.
  7. Jul 21, 2019 at 7:19 PM
    ajmogen
    Aaron
    Wisconsin
    I wouldn't drive much without an alignment. How long depends on how much you drive, how long you plan on keeping your current tires, and how badly it drives after the install
  8. Jul 21, 2019 at 7:19 PM
    Dr. Emmett Brown
    What are the immediate results from putting on high caster arms? Will the wheel move forward right after install?
  9. Jul 21, 2019 at 7:20 PM
    dead.fm13
    dead.fm13 Well-Known Member
    Chesapeake, VA
    2017 Tacoma TRD Sport
    5100/888's front, JBA UCA's, 5160's/Dakar's rear, Ray 10 MDB 17", 285/70/17 Ridge Grapplers, Hondo Garage Radio Knobs, MESOJDM Ultimate Turn Signals, MESOJDM Ultimate Combo Maps/Dome, MESO Total Tail Stage II, MESO Puddles
    Day or two tops. I’ve got the same UCA’s. Have fun installing them haha.
  10. Jul 21, 2019 at 7:28 PM
    sd1uh8as
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    That, and you'll most likely have toe and camber problems.
    Get an alignment. There's no way around it.
  11. Jul 21, 2019 at 7:29 PM
    ajmogen
    Aaron
    Wisconsin
    Camber and caster are related. You may experience tracking issues, tire rub, tire wear, etc. Every truck is a little different. Let us know how it works out
  12. Jul 21, 2019 at 7:30 PM
    Dr. Emmett Brown
    I'm definitely getting an alignment I'm just trying to coordinate the day of install in relation to alignment appointment. I'll try to do it within 24 hours of install. Thanks for the advice gentlemen.
    ajmogen[QUOTED] likes this.
  13. Jul 21, 2019 at 7:31 PM
    Dr. Emmett Brown
    Anything in particular that made it fun?
    Heard the bolt is a SOB to get out and in.
  14. Jul 21, 2019 at 7:31 PM
    sd1uh8as
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    You got it. We're just looking out. We don't want you fucking shit up lol
    ajmogen likes this.
  15. Jul 21, 2019 at 7:31 PM
    ajmogen
    Aaron
    Wisconsin
    This
  16. Jul 21, 2019 at 7:31 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    You can check toe with fishing line and two axle stands; and check camber with a digital level. If they are reasonably close to neutral, then you can drive for a while with no ill effects.
    The wheel moves *aft* with high-caster UCAs. The wheel moves forward only when you put in caster with LCA cams.
  17. Jul 21, 2019 at 7:33 PM
    ajmogen
    Aaron
    Wisconsin
    Support your spindle when it's disconnected from the UCAs so you dont damage your speed sensor wire
    eman2009 likes this.
  18. Jul 21, 2019 at 7:35 PM
    Dr. Emmett Brown
    I've taken ball joints out of spindles before on other trucks and I've always slacked off the crown nut but but left it on and then hammered the spindle to release the joint. Is this the same idea in this case? And yes I've seen people tying up the spindle so I definitely will do that.
  19. Jul 21, 2019 at 7:36 PM
    Dr. Emmett Brown
    Good info. Probably will get the alignment that day or day after is all goes according to plan. Thanks
  20. Jul 21, 2019 at 7:36 PM
    sd1uh8as
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    The most SoB part is that through-bolt. Everything else is no brainier...
    dead.fm13 likes this.
