Alignment and balance every year?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tampa Scott, Jan 14, 2017.
  1. Jan 14, 2017 at 5:35 AM
    Tampa Scott
    Tampa Scott [OP] Active Member
    2016 Tacoma TRD sport
    Just dropped the truck off for 15k service at the stealership blearily eyed at 8 am. Before I could really wake up they had me sign for a recommended service to balance and align the tires. Said they recommend that every year. Got me for $130. The truck drives fine and I don't do any off roading. Don't remember doing this with my last truck. Think I got taken?
  2. Jan 14, 2017 at 5:43 AM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    if your not doing heavy offroading or commuting to work I would have declined. if you think you need alignment or balance you could have done it on your terms when needed sometimes with service discounts
  3. Jan 14, 2017 at 5:47 AM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    Doesn't toyota offer free alignments with Toyota care? I believe they do
  4. Jan 14, 2017 at 5:51 AM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    "toyota care" is a joke covering exactly 3 oil changes and 6 tire rotations and 6 "inspections". beyond that GL getting anything out of them. rotating, balancing and aligning can make a huge difference in tire life so it isnt money totally wasted.
    Hank Heel likes this.
  5. Jan 14, 2017 at 5:51 AM
    ecotecin
    ecotecin Wait, whut........
    WV
    2014 DCSB sold (2020 Chevy Silverado Crew Cab)
    Even under normal driving conditions, it probably wouldnt hurt to get the alignment checked once a year. I think most places will check it for free, but if it NEEDS the alignment thats whan you have to pay. I actually have my alignement checked everytime i get an oil change. Lots of potholes and rougher regular roads where i live. No offroading but you hit enough potholes in 5000 or 10000 miles and you will need an alignment.
  6. Jan 14, 2017 at 6:31 AM
    RIDERED67
    I'm pretty sure there was just a thread on here about toyota care providing free alignment as part of the deal. I'll see if I can find it
  7. Jan 14, 2017 at 6:32 AM
    bobamoo
    bobamoo Well-Known Member
    Greensboro, NC
    2017 Tacoma Limited 4x4 double cab
    I'm not sure how well Tacomas hold an alignment, but on all previous cars I got an alignment once a year, except on the Audi, twice a year (that car would not hold an alignment, apparently the norm on A6). For rebalancing the tires, unless a weight fell off, why would a tire ever need that? I've fallen for that in the past, and ended up with a shimmy after the rebalance.
  8. Jan 14, 2017 at 6:44 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    I balance and rotate tires usually every oil change. I buy tires at Discount Tire and it's part of the package, so no cost. I usually do a couple of alignments a year, but I'm also driving off road a lot. You normally shouldn't need alignments that often. I'd probably check it once a year along with tie rod ends, ball joints and wheel bearings.
  9. Jan 14, 2017 at 7:25 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Rotating every 5k is smart. Aligning when an alignment is needed is smart. Balancing when the tires are shaking is smart.
    CusterFan likes this.
  10. Jan 14, 2017 at 7:35 AM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    If u live where its snows alignment might be necessary in springtime
    Yesterday I hit a huge pot hole rattle my front end where ice, snow and plowing killed the road
  11. Jan 14, 2017 at 7:49 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I only get alignments when I get new tires. So once every 2-4 years depending on when I need tires
  12. Jan 14, 2017 at 7:56 AM
    pra4sno
    pra4sno Well-Known Member
    Fort Collins, Colorado
    2017 DCSB OR MT. Previously 2013 DCSB SR5
    If all they are doing is "checking" the alignment, I would reject the service. That being said if you have even a suspicion of the alignment being off, an inspection can save you money from having to prematurely replace tires and suffering poor gas mileage.
    A full alignment service on a Toyota should include removing and applying anti-seize to front lower control arm cams before reinstalling, hitting all grease zerks on the suspension, performance inspection of all suspension components (looking for play, broken pins, checking torque spec), and four wheel laser alignment. Bonus if they mark all bolts when done.
    For $130 I would expect all of this to have been done. Just a note, for $75 you can get a lifetime alignment from Firestone.
    tacofish likes this.
