Alignment and Cab Mount Mod
Discussion in 'Arizona' started by YotaRicky2010, Jan 22, 2012.
  1. Jan 22, 2012 at 3:36 PM
    YotaRicky2010
    YotaRicky2010 [OP] Active Member
    Ricky
    Goodyear, AZ.
    2012 TRD Offroad 4x4
    I will be lifting my truck within the next couple of weeks. I need a couple of good references for a solid alignment shop and also fabricator for my cab mount chop.
    Any recommendations will be greatly appreciated!
  2. Jan 23, 2012 at 12:10 PM
    jtlachac08
    jtlachac08 Well-Known Member
    Jeremy
    Phoenix, Az
    If its not LT. Firestone lifetime alignments for $80 really cant beat it....Cab mount chop is anyone with a cut off wheel, grinder, and welder that has the slightest clue as to what they are doing.....
  3. Jan 23, 2012 at 2:45 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    brandon at avid offroad will do your cab mount. and cheap!
  4. Jan 25, 2012 at 9:29 PM
    YotaRicky2010
    Ricky
    Goodyear, AZ.
    I appreciate the input. I am looking to have it cleaned up with a welded plate to cover the hole though.
    Firestone can cost more time than the money is worth. Also going to run 285-75/17 Nitto Grapplers and could cost myself 5 times a Firestone alignment...
  5. Jan 25, 2012 at 9:33 PM
    YotaRicky2010
    Ricky
    Goodyear, AZ.
    I've heard good things about those guys at Avid. Thanks for the recommendation. I ended getting a decent local deal on my lift from Randy over at Randy Ellis Design and enough so that I'm going to let him knock out the install for me.
