Alignment and Tire Pressure
Discussion in 'Wheels & Tires' started by 270, Jun 14, 2010.
  1. Jun 14, 2010 at 12:03 PM
    270 [OP] Well-Known Member
    Jeff
    California
    09 Dc TRD 4x4
    bilstein 5100s, bull bar
    Ok well i had an alignment done and the steering wheel is just a tad left from driving center..if that makes sense.
    But to correct it right ima just let some air out of the right side tires. Do you guys think it would be better to let the air out of just the right front or both rear and front of the right side.
  2. Jun 14, 2010 at 12:05 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2010 FJC
    55w HIDs, 16" Countersteer Offroads, Yokahama All Terrains, Demello Sliders
    your tires are gonna wear all retarded. Ive had quite a few alignments done on my vehicles and my rule is it has to be perfect or its going back. Places always realign it for free too. Just my .02
  3. Jun 14, 2010 at 12:06 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    take it back and tell them the steering wheel is off center,they had it locked off center when they aligned it
  4. Jun 14, 2010 at 12:09 PM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    What he said ^^^^^^^^^
  5. Jun 14, 2010 at 12:17 PM
    Jeff
    California
    09 Dc TRD 4x4
    Yea I know fellas but man this will be the 4th time id take it in, to 3 different places.
  6. Jun 14, 2010 at 12:26 PM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Pro grille, remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    You're joking, right?
  7. Jun 14, 2010 at 12:30 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4R TRDOR Premium. ‘01 Tacoma Xtra Cab 4x4
    take it back, they will make it right. if not demand your money back and go somewhere that will fix it. I will be damned if i pay for it to be wrong and not to my satisfaction.
  8. Jun 14, 2010 at 12:39 PM
    Jeff
    California
    09 Dc TRD 4x4
    I joke not
  9. Jun 14, 2010 at 12:40 PM
    Jeff
    California
    09 Dc TRD 4x4
    Im not saying im going to let 10lbs of it out. Right now theyre at 35 all the way around what would be the harm in putting the right to like 32? would there be a difference.
  10. Jun 14, 2010 at 12:56 PM
    Bu11etWhisperer
    Bu11etWhisperer My Taco is Blue!!!
    Mark
    Douglasville, GA
    2010 Prerunner, SR5, TRD Sport, Speedway Blue
    What he said...
    I am pretty sure you want all 4 tires to be pretty close in air pressure.
  11. Jun 14, 2010 at 1:14 PM
    Jeff
    California
    09 Dc TRD 4x4
    Well i guess im out numbered
  12. Jun 14, 2010 at 2:44 PM
    AeroCooper
    NH
    Ok, to answer the question then, letting air out will only cause the truck to have a slight pull the that side. While you are correct in thinking it will 'straighten' the steering wheel, that will only be the effect of the truck steering into the ditch.
    If you really don't want to go back to the alignment place, and the off center steering wheel really bothers you (I'm with you by the way, I hate that), then you could very carefully look at the direction the tie rod ends are threaded, and after loosening the lock nut, turn the left one a little further out and the right one a little further in. The effect of this will be to move the steering wheel more to the right as the truck is going perfectly straight. Tighten the locking nut, then test drive it, and adjust again if needed.
    Do I recommend this method? Not really, because you may end up with too much toe in or toe out, but if you only move them a small amount, and in as equal amounts as possible, you'll probably be fine.
