Alignment/Balancing Question
Discussion in 'Wheels & Tires' started by sac130e, Apr 23, 2011.
  1. Apr 23, 2011 at 6:10 PM
    sac130e
    sac130e [OP] Well-Known Member
    Scott
    Milton, FL.
    11' TRD Off-Road 2wd
    JVC Nav. System and entire Memphis Audio Speakers/Amps
    Next week I will install my front shocks and UCA's and then take it in for an alignment. Should the alignment be done with the STOCK rims/wheels, or with the NEW rims/wheels?
    Also, if you had to choose where to get the alignment/balancing done, would you go with the place you bought the tires from (Goodyear), a Firestone shop, or a local performance shop that specializes in aftermarker rims and other items?
    Thx
  2. Apr 23, 2011 at 6:39 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    It doesn't matter if you get the alignment with your stock wheels and tires or your new ones.
  3. Apr 23, 2011 at 8:08 PM
    sac130e
    Scott
    Milton, FL.
    Good to know...I have heard differently, but I will take advise from experts everyday.
    So it would probably let the Goodyear place that have my tires go ahead and swap the TPMS out of the stock wheels, and build up the new ones, install and align all at once.
    Scott
    Also, want to pick up a set of locking lugs for my new wheels (MotoMetal 955 - 7x9)
    Is there a certain set/size needed to work with these rims, and where can I pick them up?
    Thx
  4. Apr 24, 2011 at 6:00 AM
    sac130e
    Scott
    Milton, FL.
  5. Apr 24, 2011 at 6:41 AM
    KPT
    09 Prerunner
    You need 12x1.5 lug nuts, conical seat. Wheelers offroad has a bunch
    http://www.wheelersoffroad.com/tacomablackalloys.htm
  6. Apr 24, 2011 at 5:08 PM
    sac130e
    Scott
    Milton, FL.
  7. Apr 24, 2011 at 5:48 PM
    KPT
    09 Prerunner
  8. Apr 24, 2011 at 5:52 PM
    sac130e
    Scott
    Milton, FL.
    So will the all locking set in the weblink work?
    Thx
  9. Apr 24, 2011 at 7:08 PM
    KPT
    09 Prerunner
    Yep as long as the rim seat thickness is bigger than the shank on the lugs.
  10. Apr 24, 2011 at 8:28 PM
    sac130e
    Scott
    Milton, FL.
    Not exactly sure what you mean, they are the same as shown on website you pointed my at earlier..just these are all locking lugs.
    Thx for the help.
  11. Apr 25, 2011 at 5:35 AM
    KPT
    09 Prerunner
    Yep I just want to make sure that the shank isn't too long. I.e. when you install the lugs will, the skinny part actually be hitting the hub so the lug nut doesn't seat all the way.
    These are extended thread, so I want to make sure you have enough extra thread for them..
  12. Apr 25, 2011 at 5:39 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    i dont know if it matters to you but firestone offers a lifetime alignment as long as you own the truck for like 169 i got mine on sale for 149 and i just took it in for an alignment repeatedly till it was 100% and anytime i change out a suspension part they will check it up for me and adjust and im in and out no problem... i like it and i like the fact that i can do it whenever and not pay another 80 bucks
  13. Apr 25, 2011 at 11:51 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    I'm not sure where you got your information from... Every time you change your lift height, put on new tires, or replace suspension parts, get an alignment.
    Why would you trust your old alignment, which has been subject to shocks and vibrations, to new/expensive tires? That alone should be reason enough.
  14. Apr 25, 2011 at 11:55 AM
    KPT
    09 Prerunner
    If you change the suspension components, then you absolutely need an new alignment. I never said he didn't need one for the suspension change...
    But just changing tires sizes doesn't affect your alignment in the least. And I wouldn't consider an alignment he got a week before the new tires to be an "old alignment".
    Say your alignment was good with your old tires i.e. zero toe, zero camber. ....how would putting a new, bigger tire on change any of those wheel angles? You could put 40's on and the toe and camber would still be zero.
  15. Apr 25, 2011 at 12:08 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    If you recently had an alignment done? None is needed. If not, then yes. Odds are good that after 6 months, your alignment is off slightly, at least. Some places will do an alignment check for free with new tires.
    I agree that angles don't change between tire sizes. I should have been more specific:)
  16. Apr 25, 2011 at 12:26 PM
    KPT
    09 Prerunner
    Alright we're on the same page then. I thought what he was asking was once he installs the lift, can he get an alignment right after that, or does he have to wait for the new tires to come in, and I was just telling him he doesn't need to wait for the new tires, he can get it aligned right after the lift.
  17. Apr 25, 2011 at 1:23 PM
    sac130e
    Scott
    Milton, FL.
    Thx for the info..I plan to lift it myself then take it to them to install the new wheels and then align it.
    Thx
