Alignment Cam Sham
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dalandser, Jun 24, 2017.
  1. Jun 24, 2017 at 3:53 AM
    Dalandser
    Dalandser [OP] ¡Me Gustan Las Tacos-mas!
    Anthony
    Downey
    Empty Wallet Mod
    Found out my front passenger side cam bolt is stripped and need to (hopefully) get my truck back together for an appointment for an alignment at 4. Dealer always does next day so it wouldn't work. Do auto part stores sell these without having to order them? It would make everything go much smoother tomorrow. Thank you! Help is appreciated :)
    This is what happened that I need to replace the front lag bolt - the threads that are flattened down between the larger diameter and smaller diameter parts were much larger and I had to file them down in the middle of the night - it was literally the last part I had to take off before I was ready to put all my stock parts back on :(
    Oh well. Glad to have the parts taken off at least - more funds for my new first gen. :cool:
    ChadsPride likes this.
  2. Jun 24, 2017 at 4:03 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  3. Jun 24, 2017 at 6:25 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Bumpin it cuz morning threads poppin up!
  4. Jun 24, 2017 at 6:32 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Got a junkyard around you can pick one out of? Either that or specialty makes replacement bolts. Try xl parts of you have one or orielys. Other parts houses make alignment parts too but they aren't specialty brand. Moog North Star, stemph, and a few others. Start driving around or calling to parts houses if you don't have a wrecked Toyota in a junkyard. Anything from 05 to now should work for an alignment eccentric bolt
  5. Jun 24, 2017 at 6:33 AM
    Rockymtntacoma
    Rockymtntacoma Well-Known Member
    Jake
    SLc,UT
    03 ext cab 4x4 v6 5 speed sr5
    Dual cases, triple sticks, 4.88’s, Harrop e-locked f/r, 35’s, boosted
  6. Jun 24, 2017 at 6:39 AM
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    Do a search on here... Most people seem to not like the Moog stuff for to the bad design and end up reverting back to OEM stuff.
    ChadsPride and Pigpen like this.
  7. Jun 24, 2017 at 6:42 AM
    Bebop
    Nick
    I prefer specialty above all else when it comes to alignment parts. I will use moog when I'm in a pinch. Maybe the OP is in a pinch?
  8. Jun 24, 2017 at 7:34 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Pinch yep - if I can get it today I'd rather do that - thank you :)
  9. Jun 24, 2017 at 9:32 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Alright O'Reilly's had a set for $45-ish with tax that I can pick up today - dealerships would have to be on Tuesday since they don't ship parts on Sunday and Monday and none had the real bolt (front through bolt) I needed in stock. I'm sure the O'Reilly's parts are junk or close to it, but the truck needs to be getting me to work Monday.
    Firestone is having a $69.99 deal on alignments right now. They come with a 12 month warranty so I can eventually swap in more OEM hardware and go back for a check. Here's the O'Reilly's parts.
    http://www.oreillyauto.com/site/c/d...31017_-1&pt=02920&ppt=C0322#compatibilityTab_
    I'm thinking now whether I want to frankenstein together a setup using OEM parts for the rear bolt assembly and the O'Reilly's parts for the front or if I should just throw both O'Reilly's on. Thoughts, questions, concerns?
  10. Jun 24, 2017 at 9:34 AM
    Bebop
    Nick
    If your in a pinch throw them in!!!!
    ChadsPride and Dalandser[OP] like this.
  11. Jun 24, 2017 at 9:53 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I'm gonna pick them up in an hour or so - we'll see how they compare in dimensions to OEM. All I care about atm is to get my truck on the road by tomorrow afternoon. I'll get a more permanent fix going in the future. :)
    Good call on the junk yard btw - it's my daily driver though and there aren't any nearby :annoyed:
    ChadsPride and Bebop[QUOTED] like this.
  12. Jun 24, 2017 at 12:11 PM
    Bebop
    Nick
    I have about 40 junkyards I can sift through about 15 miles away from me. It's always fun to find cool shit for next to nothing. It brings out the lowballer in me too when it comes time to pay for my bounty.
  13. Jun 24, 2017 at 12:19 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Those aftermarket ones are terrible. The alignment tab itself strips and springs freely of the bolt. Do yourself a favor and order oem stuff
  14. Jun 24, 2017 at 12:19 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    That's the plan. Just have to get the truck on the road for now!
  15. Jun 24, 2017 at 12:22 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Anyone know if I can run just the front aftermarket one with the rear oem one I have?
  16. Jun 24, 2017 at 12:23 PM
    Bebop
    Nick
    Yeah that shouldn't be a problem. They have the same dimensions. Shouldn't be a problem when the alignment comes.
  17. Jun 24, 2017 at 12:23 PM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    I don't see why not. They have nothing to do with each other
    Dalandser[OP] likes this.
  18. Jun 24, 2017 at 12:31 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I wasn't sure if that thank you! I have to chase some threads on the rear one and clearance out the cam tab gusset slot to fit the bolt without any interference. I'm not sure why it was getting pinched / maybe the cam tab gussets were just a little out of spec they shrunk a little from being welded - not sure if that would be possible or not though. Doesn't seem likely if other people haven't had this problem
  19. Jun 24, 2017 at 12:36 PM
    Bebop
    Nick
    Some good bearing grease and antiseize goes along way when it comes to alignment parts like eccentrics and tie rods.
  20. Jun 24, 2017 at 12:49 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Yep - learned the grease idea from the guy that installed the long travel kit. Got the other side complete with bearing grease. The washers have SPC on the washers - looks like I got this kit: Just paid almost twice the price for it, but convenience...
