Alignment Cam Sham
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dalandser, Jun 24, 2017.
  1. Jun 24, 2017 at 1:03 PM
    Dalandser
    Dalandser [OP] ¡Me Gustan Las Tacos-mas!
    Anthony
    Downey
    Empty Wallet Mod
    Looks like I'm going to have to shave down the rear washer on the front assembly - does anyone know how much clearance should be on either side? Do they all have different clearance specs - it seems like some have more than others.
  2. Jun 24, 2017 at 6:44 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    The instructions show to aim the cam washers down ie so the large part is under the bolt. I figure that I'll follow the instructions, but this is the opposite of the stock ones. Why do you think this is?
    @mechanicjon
  3. Jun 25, 2017 at 10:54 AM
    Justinlhc
    Justinlhc Not looking for a relationship
    That is your alignment setting. Placing them exactly how they were will be best until you get it aligned. Don't go by that picture.
    Dalandser[QUOTED][OP] likes this.
  4. Jun 25, 2017 at 8:45 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Thanks man. After messing around with the cams and reading about how the work I figured it didn't matter how they were when I installed them. I read a pretty good write up and just eyeballed it since it was after midnight when the truck was back on its own weight. I didn't do too bad imo:
  5. Jun 25, 2017 at 9:09 PM
    Justinlhc
    You could have done better on the toe :gossip:
    Is that as much caster as they could get? I'm assuming the truck is lifted with stock upper control arms?
  6. Jun 25, 2017 at 10:06 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    lol I didn't care at 1 am outside on the street - I just had to drive a block to get to the alignment shop. I dialed in toe on my truck using the string method before and got one side completely in spec and the other super close before going to an alignment shop.
    Caster is whatever at this point - I know 2.5* plus is preferable, but the truck drives fine. I'm more concerned about getting my sway bar back on. I'm on stock TRD coils and with gusseted sway bar delete spindles the truck dives in corners like crazy. The whole point of this was to take off my long travel kit though so I'm satisfied with what I have until I get the truck back to stock. More funds for my first gen engine build :thumbsup:
    On to the next project :)
  7. Jun 26, 2017 at 2:56 AM
    Justinlhc
    Looks like they just got you in the green and caller it good. I guess the alignment isn't high on your priority list at this point though.
  8. Jun 26, 2017 at 3:09 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    If it affects how the truck drives I'll address it, but until then there's things that are more important. Yes.
