Alignment - Caster adjustment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rollin904, Apr 16, 2019.
  1. Aug 6, 2020 at 2:12 PM
    #41
    Taco9616
    Taco9616 Member
    Kyle
    2016 Desert Sand Tacoma
    SPC UCAs 3” spacers 2” AAL 285/70/17 Fuel Vector 17x8.5 -6mm offset
    Les schwab(Taco Bell) lol
  2. Aug 6, 2020 at 3:09 PM
    #42
    ImMrCrash
    ImMrCrash Intermittent Error
    Utah
    07 DCSB ᴛʀᴅ ᴏʀ 4x4
    Bilstein 5100’s Dakar CS047R Supreme Suspension U-Bolt flip kit Sumo Springs Blue ADV Fiberglass Fenders 1st Gen Snorkel DV8 Apex Plate Bumper X-Bull 13k Winch KC HiLiTES 6x9 Trail-Gear Sliders 4x Innovations LCA Skids Spidertrax 1.25” Eagle Alloy 16x8 4” BS Fierce Attitude M/T 315/75R16 Bearcat 980SSB CB
    Seems weird to me, stock suspension parts can be aligned at just over 2° caster easily. With your setup using SPC uppers that come default as +2° over stock you are still only at ~2.1°? Meaning that your stock lowers are set for 0.1° caster and are probably doing all the camber work.
    Here’s my recommendation: Years ago I had 3” of lift, SPC uppers, stock lowers, 305/70R16 tires on the same 16x8 -11 offset wheels. I left the SPC uppers at D and pushed them in halfway for camber. I went and got a basic alignment (they did not touch the UCA) and received 3° Caster, 0° Camber, 0° Toe. I did have a medium CMC but had not touched the pinch weld. Only other trimming I did was on the plastic around the cab mount and bottom of the plastic covering the pinch weld. Truck ran great and almost never rubbed.
    I would do it again the same way. If I were you I would do the same, except go to a different alignment shop.
    meats likes this.
  3. Aug 7, 2020 at 6:08 AM
    #43
    Taco9616
    Taco9616 Member
    Kyle
    I hear ya and I would but I already paid these morons so I want them to make it right
    ImMrCrash likes this.
  4. Aug 9, 2020 at 12:09 PM
    #44
    Taco9616
    Taco9616 Member
    Kyle
    Figured it out bro! Dialed the uppers to setting E(+1). Good call on SPC telling me the wrong settings. Ended up with caster being just under 1* and 1*. Dont rub a single thing. Still have the mud flaps and haven’t cut anything. Also feels more planted in the front. I had a intermittent humming noise before at setting D that’s not noticeable anymore. Truly a stress cloud lifted off. I recommend ANYONE that’s running 285s or bigger start at the E setting and adjust from there.
    thanks again!
    CBrob and ImMrCrash like this.
  5. Aug 9, 2020 at 12:47 PM
    #45
    ImMrCrash
    Utah
    07 DCSB ᴛʀᴅ ᴏʀ 4x4
    Excellent! If it rides great I wouldn’t change it.
    I am curious though, are you saying your final alignment numbers are under 1° caster? Do you get any bumpsteer (potholes and such pull your steering wheel)? Again if it rides great I wouldn’t change it!
  6. Aug 9, 2020 at 1:00 PM
    #46
    Taco9616
    Taco9616 Member
    Kyle
    Not that I recall if I remember and I run into that I’ll let you know. I have these on my 96 and the only time I got bump steer was because the old timers I took it to had the star plate not in its slot
  7. Aug 20, 2020 at 3:36 PM
    #47
    meats
    meats superwhite MT taco meats
    Justin
    Grapevine, TX & Cushing, OK
    '20 Super White DCSB 6spd MT 4x4
    Lots--
    Did the 305/70r16's rub with just the lift alone? CMC is a must do huh?
  8. Aug 20, 2020 at 4:01 PM
    #48
    Taco9616
    Taco9616 Member
    Kyle
    I’m not running 305s I’m running 285/70/17s
    Set the caster at E (+1) and haven’t rubbed a single bit. Didn’t have to remove or cut anything either. Caster comes in around 1*
  9. Aug 20, 2020 at 5:00 PM
    #49
    ImMrCrash
    Utah
    07 DCSB ᴛʀᴅ ᴏʀ 4x4
    Yep I would say CMC is an absolute must do, nothing too drastic though aside from some minor inner fender liner trimming.
  10. Aug 20, 2020 at 5:06 PM
    #50
    81Trekker
    81Trekker Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    You run one degree of caster at ride height?
  11. Aug 20, 2020 at 5:16 PM
    #51
    Taco9616
    Taco9616 Member
    Kyle
    No I have 3” spacers and 2” rear lift. Anything bigger than 285/70 and don’t plan on rock crawling than you don’t need a CMC. Anything bigger than that I would adjust further than E, so F or G and even then if you have a aftermarket front bumper you still won’t need a cmc. The only way you would need one is if your running 35s and plan on fully stuffing your front tires going off road. As for a street driver you would only need a cmc running 35s
  12. Sep 16, 2020 at 2:27 PM
    #52
    Phil4200
    Phil4200 Well-Known Member
    2018 Tacoma SR5 DC 4x4
    3.5 RC Vertex coil overs, SPC uppers, rear blocks\RC V2 monotubes CVC tune 3.0 mbrp exhaust
    My truck is currently being done right now. I had 2.5 caster drivers and 2.7 passenger. Camber at 0 both sides and my ball joint would smack my coil spring. The shop is going for more caster and actually adjusting to UCA top plate!! Most shops don’t even touch it lol. Hopefully by rotating the spindle back it won’t hit on droop. Fingers crossed
  13. Sep 16, 2020 at 2:43 PM
    #53
    ImMrCrash
    Utah
    07 DCSB ᴛʀᴅ ᴏʀ 4x4
    Drives me nuts that you have to ask a shop if they will perform a simple request and even provide the instructions all for a 50/50 chance they won’t do it and a high chance they will charge extra to do it!
    What shocks you running that are allowing your SPC UCA ball joint to hit your coil? Got any close up pics at droop?
  14. Sep 16, 2020 at 3:06 PM
    #54
    Phil4200
    651206C1-7EB8-401B-B234-BFFF531473CD.jpgRough Country lifted struts. 3” front 2 rear
  15. Sep 16, 2020 at 3:09 PM
    #55
    Phil4200
    They just got me in the 4’s on caster. Chances are I rub now on cab mount cause the spindle is rotated back so far to clear coil spring.
  16. Sep 16, 2020 at 4:40 PM
    #56
    ImMrCrash
    Utah
    07 DCSB ᴛʀᴅ ᴏʀ 4x4
    :sawzall:
    But did it work? Does the ball joint still hit the coil?
    Phil4200[QUOTED] likes this.
  17. Sep 16, 2020 at 5:17 PM
    #57
    Phil4200
    Ahaaaaa it did work! 4.2 drivers and 4.6 passenger. Uca st to the “A” position. It’s close on the cab mount, may rub on hard steep incline most likely. Drives way better though! Ball joint no longer hits coil all good there
  18. Sep 16, 2020 at 6:25 PM
    #58
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
    How hard is it to adjust the SPC UCA’s? Want to squeeze bigger tires next year, trying to get away from the cab mount, CMC and I still have rubbing sometimes.
  19. Sep 17, 2020 at 6:09 AM
    #59
    ImMrCrash
    Utah
    07 DCSB ᴛʀᴅ ᴏʀ 4x4
    As easy as jacking up the truck and loosening that big nut. You shouldn’t have to remove the nut completely. You can even leave the tire on if you want to be extra lazy but I would suggest removing it to simplify the process otherwise you will be fighting the weight of the tire/wheel as well as the spindle.
    Changing the caster with SPC’s will also change camber which in turn affects toe so you will need an alignment afterwards.
    Be aware that if you rotate the upper ball joint forward, you will slightly increase tire distance from cab mount but you will also be reducing caster angle.
  20. Sep 17, 2020 at 11:12 AM
    #60
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    If you reduce caster the lower quarter of the tire( the part that hits the cab mount) actually gets closer to the mount.
