Alignment, Caster, Clearance, and Driving Report with Light Racing UCAs
Discussion in 'Suspension' started by bjmoose, May 24, 2011.
  1. Sep 16, 2013 at 11:22 AM
    #181
    Texasdynaryder
    Texasdynaryder Well-Known Member
    Chance
    Paris, Tx
    Kings Built Engine All the other small goodies
    Sorry I forgot to mention this but it is the driver side.
  2. Sep 16, 2013 at 11:55 AM
    #182
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Yeah figured that from the picture. Looks like its the -1 balljoint setting, giving you +1* of total caster.. let me go out and check mine .. but pretty sure mine is the opposite which is +1 balljoint, +3* total caster.
    Which as of now seems to be good for me. Im at 3" of lift with new 285/70/17 toyo ATII's. No rubbing, but gonna do some more articulation testing, while backing up specifically.
    EDIT: son of a bitch... lol. I was reading mine wrong. Mine is set to what yours is..
    This:
  3. Sep 16, 2013 at 12:26 PM
    #183
    bjmoose
    bjmoose [OP] Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Mine are set at position "E." When I had them set to position "C" I got gobs of caster which made the truck track rock solid - but lost clearance and rubbed the wheel well while the steering wheel was turned to full lock in reverse (aka every time backing out of a parking place.)
  4. Sep 16, 2013 at 12:31 PM
    #184
    Texasdynaryder
    Chance
    Paris, Tx
    Well now that looking at it front the top view I'm in the C setting. I need to get my front end checked cause I am road walking bad. You like your setting being at the E setting-1.0
  5. Sep 16, 2013 at 12:41 PM
    #185
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I've given up on trying to look at a picture and assess what they're set at. Too difficult to say and the camera's shooting from a single angle that isn't obvious once the picture's taken.
    Yeah, I'd say go with position "D" or "E." My experience is that position "C" doesn't work out so well - you can read my original post on this thread for the complete story.
  6. Sep 16, 2013 at 1:21 PM
    #186
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Thanks Moose!! :thumbsup:
    Yeah mine were originally set at the neutral setting. Had rubbing issues at the back of the fender. adjusted the UCA's to the where they are now (E) and had rubbing issues at the front of the fender. After a few visits to firestone and eventually going to a different location, they got mr 3.1* of caster and it drives great now with no rubbing.
  7. Oct 14, 2013 at 7:46 AM
    #187
    JohnnyWayne
    JohnnyWayne The Past Through Tomorrow
    Johnny
    Lantana, FL
    '12 DCLB TRD Sport
    Look out for snakes in the grass guerrilla marketing.
    Great thread, going to have to go with UCA's after my lift and the info here is much appreciated :thumbsup:
  8. Oct 14, 2013 at 3:32 PM
    #188
    09Tacomania
    09Tacomania Well-Known Member
    Scott
    Little Rhody
    09 Silver Streak Dbl cab 4x4
    Icon CO's, LR UCA's, Icon rear 2.0 rear resi's, Wheelers 1.5" 3 pk aal, blacked out badges, Andre's devil horn's, Extang tonneau. Oem racks
    Good luck Pilgrim.......:D
  9. Oct 14, 2013 at 7:38 PM
    #189
    JackTRD
    JackTRD Well-Known Member
    Jack
    Southern Ontario
    12 SR5 Hidden treasure
    TRD exhaust, bed mat, G4 Elite cover, weather tech front and rear, AVS window deflectors, pop&lock electric tail gate, aFe Pro dry S, compustar alarm with remote start, interior LED, Titan AIr Compressor
  10. Oct 15, 2013 at 8:27 PM
    #190
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    I had mine set at the E setting and had just enough clearance in the wheel well to avoid any rubbing (with the CMC). I adjusted my drivers side coilover 1/4" to compensate for the taco lean and now I rub on the drivers side in full lock reverse. I'm gonna get an alignment because I noticed the steering wheel isn't set straight on either. I probably shouldve just left the coilover set at what it was but the taco lean was killing me and now I need an alignment haha
  11. Nov 11, 2013 at 4:41 AM
    #191
    MrFastener
    MrFastener Fastener Tech
    Richmond VA
    Tacoma Xpro
    3" Toytec Ultimate Adj coil over lift with light racing UCA's, Nittos, remote res rear shocks,
    Max, I realize this is an old post but the info is probably needed almost daily by issues resulting from new owners / members installing lifts etc.
    **I did the Toytec adjustable 3" coilover lift and the light racing uppers on a 2013 4x4 Dbl Taco. Their info had a max tire suggestion of 285/75/16. Even at 2.9 of caster, ( First using all the lowers could provide before going upstairs to the LR uppers for more) my uppers come into contact with the Nitto 285/75/16 on stock TRD beadlock wheels on sharp turns. The only option was to install the Spidertraxx 11/4 wheel spacers to bring the wheels out.
    Now, forward is fine but reverse has fender rubb like yours did. Even after some aggressive plastic trimming on a 2013.. My question is, when you got yours done to where you lost the fender rub, you reduced your caster but didn't say to what number. I'm at 2.9 x 2.9 on caster and the ride is much better but I have that damn reverse rub. Do you or anyone who had the same problem have any suggestions besides tire size reductions? I followed Toytec's site and went with their stuff and their safe tire size suggestion. Maybe these 2013's have a different front fender measurement or something. Anyone else been thru this??
  12. Nov 12, 2013 at 4:16 PM
    #192
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    I recently go my LR UCAs and there's a groove that goes around the pivot sleeve 3/8" from the end of the pivot sleeve on only one side. Is there a certain direction that this groove needs to go? Or just grease the bushing, push it in, and call it good?
  13. Nov 12, 2013 at 4:47 PM
    #193
    4OYOTER
    4OYOTER Well-Known Member
    Alan
    Cedar Park, TX
    4Runner
    That groove is your camber adjustment. I would recommend torquing it down about 1/4th of the way towards your engine bay. That should put the caster adjustment plate just slightly inward of sitting flush with your UCA. (Hope that makes sense) Whoever does your alignment may need to adjust it, but that position is where mine are at and my camber is good.
  14. Nov 12, 2013 at 4:56 PM
    #194
    Drunknsloth
    Retribution
    South West
    I'm not seeing how it adjusts the camber... I though that was all in the LCA?
    We might be talking about two different parts? I'm looking at the silver sleeve in this picture (4 of them) and 3/8" from the end (and only one side) of each of the sleeves there is a groove that goes around the sleeve in a ring. I'll try to upload a picture of the actual one.
  15. Nov 12, 2013 at 5:12 PM
    #195
    Drunknsloth
    Retribution
    South West
    Here's the part I'm talking about and the groove on it.
  16. Nov 12, 2013 at 5:19 PM
    #196
    4OYOTER
    Alan
    Cedar Park, TX
    4Runner
    My bad, definitely a different groove. I didn't even notice those when I installed mine. No idea which way I installed them.
  17. Nov 12, 2013 at 6:03 PM
    #197
    AWF ROWD
    AWF ROWD ...eats at the " Y " often....
    Doc
    40.102° N, 82.804° W
    '13 BLOWN 4X4 Sport
    TRD Supercharger, Walbro 255 FP Upgrade, aFe Stage 2 si CAI, TRD Acrylic cover by Coupe ADD 1 OIL Catch can/SS hoses, TRD cat back exhaust, URD 2.8" Stealth pulley, 3" lift, Toytec/Bilstein C/O's, Toytec Progressive AAL's, LR UCA's, 5100 Rear Billies, Bi-Xenon HID BHLM Retro's w/ Halos RED LINE Tuning Hood Rods Swaybar Relocate, Line X'd Bull Guard/Step, Hitch, Craven Speed Dual Gauge mount, AEM Boost/AFR Gauges, Windows 20% tint, Weather Tech deflectors, GrillCraft upper and lower, Tacoma Raptor letters, LED Interior/Exterior lighting, Lund 6" Color Matched Oval Side Bars, Webasto 700 II sunroof, Heated Two toned custom leather TRD logo'd, Kenwood Multimedia 6990 HD head unit ,JL Stealthbox sub, Hertz Component speakers,, Entire cab damped with hushmat, Viper Security/Remote start, Weather Tech Liners, Blackened exterior LED Lights, Undercover Top w/LED's, Carbon fiber TRD windshield decal,, TRD stitched leather shift knob, TRD steering wheel emblem,
    Sub'd...
  18. Nov 13, 2013 at 3:36 AM
    #198
    Drunknsloth
    Retribution
    South West
    I'm guessing it doesn't matter since the instructions don't mention it but I just want to make sure, being OCD and all :rolleyes: Haha
  19. Nov 13, 2013 at 4:52 AM
    #199
    MrFastener
    Richmond VA
    Tacoma Xpro
    JP, I have the exact issue on a 2013. Mine is a TXPro and came with 265/70/16, no rub. I added the Toytec Adj coilover and light racing uppers with Nitto 285/75/16 and the uppers were snagging the tires at sharp curves. Tried several alignment settings and same issue. I then went with spidertraxx spacers 11/4. The spacers fixed the "UCA" rubb but now I have both front and rear fender rubb. I can't believe I added 3" in lift , LR uppers, 11/4 spacers, up from a 30.6 tire dia to 32.8" and Tacoma cant handle it?? I'm wondering if these 2012 and 2013 are different.
  20. Nov 13, 2013 at 7:41 AM
    #200
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    What's the specs on your wheels? Stock? Aftermarket?
