Alignment, Caster, Clearance, and Driving Report with Light Racing UCAs
Discussion in 'Suspension' started by bjmoose, May 24, 2011.
  1. Nov 13, 2013 at 8:20 AM
    #201
    bjmoose
    bjmoose [OP] Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I bet you haven't trimmed any plastic yet.
    Folks inevitably have to remove/melt/bend/reshape plastic from the inside the wheelwell when running a 33" tire even if lifted.
  2. Nov 13, 2013 at 8:21 AM
    #202
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    This..
    Not to mention a cab mount chop.
    I've trimmed ALOT of my front fenders to clear. I have zero rubbing now.
  3. Nov 13, 2013 at 5:39 PM
    #203
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    Listen to the Moose ^^^ Start trimming and chopping. Nobody ever sees it anyways unless you're a Tacoma dude who is gonna stick your head in someone's fender well in a parking lot...not that i've ever done that.
  4. Nov 14, 2013 at 5:18 AM
    #204
    MrFastener
    MrFastener Fastener Tech
    Richmond VA
    Tacoma Xpro
    3" Toytec Ultimate Adj coil over lift with light racing UCA's, Nittos, remote res rear shocks,
    I'm Running the stock 16" TRD Bead locks that came on my TXpro' with Nitto 285/75/16. These wheels already seem to have some factory offset. I've trimmed all that can be trimmed without completely removing the inners and melting some stuff.
    I really screwed up by not getting the center hub to fender measurement PRIOR to the Toytec Adjustable coilover and LR uca's. Add that to the fact that these TXpro's seem to already be an inch higher than the standard Dbl cab 4x4 and you see my concern about cranking it up anymore. Hell, I had Nitto 295's for a few miles and had only a slight rub before swapping out for the 285's thinking that would solve my problem. I took hours reading all the posts about the LR uca adjustments and have mine on "0" (t1) figure D. I just noticed the front to back distance on the left side vs right is about an inch diff too. If another trip to the alignment shop wont work I don't see any option but to again downgrade tire size. CRAP!
  5. Nov 14, 2013 at 5:36 AM
    #205
    MrFastener
    Richmond VA
    Tacoma Xpro
    I wont have any shame sticking my head in another fender. I consider it taking one for the (TW) team. I'm just not sure these 2012 and 13's have the exact same fender dimensions as the earlier models.
  6. Nov 14, 2013 at 6:34 AM
    #206
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Anyone else even have these grooves on their's?
  7. Dec 5, 2013 at 7:14 AM
    #207
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Installed in the neutral position (D) and got the truck aligned. Tires rub on rear of fender well. Going back to have the clearance maximized as BJMoose said in the OP. I'm going to try and see if the tech can get it really close (to perfect numbers) in the F position, but may have to settle for E.
    I didn't think this would be too much of a problem w/ 32" tires and 3" of lift.
  8. Dec 5, 2013 at 7:16 AM
    #208
    YOTA LOVER
    NH
    Yes. Didn't see them mentioned on the install sheet. Didn't find any matching bump on the inside of the bushing. Said "Eff it" and installed with the grooves on the outside of the UCA.
  9. Dec 5, 2013 at 7:41 AM
    #209
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    I had some issues with the tires rubbing the frame at full lock. Noticed the camber on the LR UCA was way in. I asked them to slide the UCA knuckles as far out for clearance while maintaining a 2.5ish caster. Was able to get the clearance and maintain caster without adjusting UCA caster.
  10. Dec 5, 2013 at 7:58 AM
    #210
    YOTA LOVER
    NH
    I've got plenty of clearance to the frame, as the upper BJs are further away from the fender (as set on the UCA), I'm rubbing the tire on the inside rear of the fender, which I know will be much worse when stuffed. I want to try and cheat the caster setting (forward) on the upper BJ and make up the difference on the lowers to set the caster at about 2 degrees overall. We'll see.
  11. Dec 5, 2013 at 8:28 AM
    #211
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I had that same rub. Back of fender.
    Changing it to the settings that BJ Moose wrote fixed it. That plus a good alignment will get you set.
  12. Dec 5, 2013 at 8:30 AM
    #212
    YOTA LOVER
    NH
    Nice! I can imagine it working, but good to hear it in practice. Thanks!
    And the truck has been aligned again, upper BJ set to "E". Good clearance all around, couldn't be happier. Forgot the alignment numbers in the truck, but I'll add them soon.
  13. Dec 7, 2013 at 12:42 PM
    #213
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    Ok fellas so I just got an alignment last night but I have the steering wheel pulling to the right and the vehicle pulls to the right when trying to track straight. Toe is at 0 and Camber is at 0 . Drivers Caster is 2.2 and Passenger Caster is 2.5. The alignment guy adjusted the caster first via the LCA cams and said that it was maxed at those numbers. What do you guys think the problem is?
  14. Dec 7, 2013 at 3:12 PM
    #214
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    ^^Responding to my own post above. Problem is resolved. Went back to the alignment shop and the tech suggested we flip the drivers and passenger tires (front only). After the flip she drove way better and didn't pull to the right. I don't know if this is common or not but now I'm thinking I may have a balancing issue with one tire? or abnormal wear on one tire? (I didn't see any and am frequently inspecting my tires)
  15. Dec 7, 2013 at 5:05 PM
    #215
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I've had tire-induced pull before. It's not a balance issue - balance induces shake/shimmy/shivver.
    Just something about how the tread pattern and belts on the tire wear.
    Just go to a front-back tire rotation when you rotate, keeping left and right on the same side each time.
  16. Dec 7, 2013 at 5:26 PM
    #216
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Agree with this 100%
    When tires are cross rotated, the wheel actually roll is the opposite direction. I know that many say this is OK for radials. but I am old enough to remember when this was quite a problem.
    The tire guy that swapped from side to side was changing the rolling direction of the tires. IMO, one of those tires has an issue. Possibly an internal belt has shifted or seperated. Long term you may see more issues.
    To prevent this from happening, always rotate front to back. Cross rotation can create it.
  17. Dec 16, 2013 at 7:29 AM
    #217
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Just got another alignment, I have my LR uppers set to the +2 setting, shop set my caster to 1.7 on the left and 3.4 on the right... I told them it needs to be in the 2.5 range, but they said the camber didn't allow that... Do they just not know how to use the LR uppers? Or are they idiots? Idk...
  18. Dec 16, 2013 at 7:33 AM
    #218
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    LCA cams may be seized...
  19. Dec 16, 2013 at 7:35 AM
    #219
    YOTA LOVER
    NH
    It would seem they may need you to bring in this write-up (the section where Moose explains maximizing clearance) and the SCS install sheet.
    I think the tech would've told him if they were seized, or should have anyway.
  20. Dec 16, 2013 at 7:36 AM
    #220
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    I've been holding off to replace the cams for when I can get some poly bushings for the lca, which are supposed to be available by the end of the year....
