Alignment, Caster, Clearance, and Driving Report with Light Racing UCAs
Discussion in 'Suspension' started by bjmoose, May 24, 2011.
  1. Jul 8, 2014 at 1:51 PM
    #281
    gumbeyyy
    gumbeyyy Well-Known Member
    Ya I just want them close where It doesnt wander and tires wear even.
  2. Jul 8, 2014 at 2:12 PM
    #282
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Are you guys finding that the shops know how to adjust the UCAs? or do you need to bring it to them with the arms set already?
  3. Jul 8, 2014 at 2:50 PM
    #283
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Most of the techs I've dealt with can't seem to wrap their heads around the purpose of the adjustable ball joint, even with the sheets. I had to bring the truck in twice, but that was partially because the service manager was unable to properly brief the tech. The second time I went out with the tech and spelled it all out for him with another set of spec sheets. They did dial in my numbers.
  4. Jul 8, 2014 at 2:55 PM
    #284
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    Good luck Adam, I went to a few shops by my house in salt lake and nobody would touch them (LR UCA). So I ended up doing a garage alignment using this thread, then had a shop that your buddy Kurt recommended off 90th and 7th fine tune the lower stock adjustments with the lasers. My "at home" alignment was pretty close to what I wanted.
  5. Jul 8, 2014 at 5:09 PM
    #285
    Box Rocket
    Adam
    Syracuse, Utah
    I am thinking about taking the arms over to the shop before I install them so the tech can take a look and figure out how they're supposed to work. Maybe if I can get him comfortable with them ahead of time I can avoid some issues.
  6. Jul 8, 2014 at 5:35 PM
    #286
    YOTA LOVER
    NH
    Good luck. I'm no rocket scientist and the concept seemed clear, even "cheating" the BJ forward to gain more clearance off the back side of the wheel well.
  7. Jul 8, 2014 at 5:40 PM
    #287
    BigHeadTaco
    BigHeadTaco GFY
    Big Head
    Full OME lift 885's with Dakar leaf springs. LR UCA's. ImMrYo relocation bracket.
    I had my alignment with my LR UCA's done by Les Schwab in Salt Lake, off of 2100 S. and Redwood. I brought in the instruction sheet and explained to the tech how the system worked and he got it right in about an hour. I havent had to have them adjusted in over a year.
  8. Jul 8, 2014 at 5:43 PM
    #288
    YOTA LOVER
    NH
    ^^^this
  9. Jul 8, 2014 at 5:45 PM
    #289
    NoSilverBullet
    NoSilverBullet N60 member
    Northern Canada
    2012 AC 2.7 MT 4wd
    Old Man Emu suspension: 884x coils, Dakar leaf pack, Nitrocharger Sport shocks. Cruisin Offroad bolt-on sliders. Relentless Fabrication aluminum front and mid skid plates + steel transfer case skid. SnugTop Hi-Liner "Sportsman" canopy. Hella Rallye 4000i Xenon (flood beam).
    I bring the spec/information sheet with me to the shop and give an overview of my trucks' setup.
    The first place I went to, they adjusted the UCA to remove 1 degree of caster (was set at the "0" setting, which is in fact +2 from stock IIRC).
    I just had my alignment re-checked at a different shop and they got it back within spec without needing to touch the UCA ball joint adjustment.
  10. Jul 9, 2014 at 4:24 PM
    #290
    Explor
    Explor Don’t take the trip ... let the trip take you
    Northampton County Pa.
    FUN
    TRD valve stem caps , A Chimney & Back up camera. , Cooper STMaxx 255/80/17, SCS Dark Bronze wheels, , bed matt, weathertech floor liners and bug deflector , flyzeyez dash and glove box light , Best Top supertop, Brute Force Sliders , Bumpers ,KC back up lights, vent shades, tinting, superwinch 9.5 , Factor 55 winch thimble , KC ditch lights , BAMF IFS skid plates , Tepui Ruggedized RTT , Awning , Bed light kit , Hood Struts , Camburg UCAs ,Bud built gas skid , all pro differential skid , cbi jerry can holder , 15lb CO2 Tank , URD short shift , Defined engineering shackle bolt crossmember, Clazzio seat covers , 4:56 Nitro gears , ARB rear locker, CMKA12 compressor. Super Bump Stops, Bushwacker Flares , CBI bed rack , king resi front 700# , OME Dakar, Bilstein 6100's 10" light bar diode dynamics , AV monster fogs , TC bed reinforcement brackets , TC spindle gussets w swaybar Yeasue Ham , cb
  11. Jul 11, 2014 at 8:29 PM
    #291
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    me 2
  12. Jul 18, 2014 at 11:25 AM
    #292
    cstallings
    cstallings Well-Known Member
    Arkansas
    2013 MGM DCSB TRD Sport 4x4
    SOS Front Bumper, SOS Sliders, SOS skids, ARB Rear Air Locker, OME Lift (885x Coils, Nitro Charger Shocks, Dakar Leafs), LR UCAs, Leer Shell, OKLED 30" light bar, Wet Okle Seat covers, etc, etc
    What position do you place ball joint bolt for camber adjustment within the upper control arm? Meaning should the nut be pushed back all the way, positioned in the middle or all the way forward? Not sure if that was clear...
  13. Jul 18, 2014 at 11:40 AM
    #293
    Ricks2013
    Ricks2013 Well-Known Member
    Rick
    Orlando, FL
    13' TRD Sport DCSB
    A few things
    I have mine in E position pulled almost all the way out. It's about 1/16"-1/8" from the end. But every truck will probably be a little different though.
  14. Jul 18, 2014 at 7:58 PM
    #294
    cstallings
    Arkansas
    What do you mean pulled almost all the way out? Towards the tire?
  15. Jul 19, 2014 at 7:25 AM
    #295
    Ricks2013
    Rick
    Orlando, FL
    13' TRD Sport DCSB
    A few things
    Yes, towards the tire. You can pretty much eyeball what looks to be about right (at least good enough until you get it aligned) Just look at the tire from the front and set it to where it looks straight up. BUT try jacking the truck up so it's at full droop and make sure the tire doesn't rub on spring. I did that and had to adjust a little just so it doesn't rub. Not that I plan on being in full droop much, but just in case :)
    Edit: pretty much same thing Doording said ^^^
  16. Jul 19, 2014 at 5:29 PM
    #296
    HHogrider
    HHogrider Well-Known Member
    Mark
    Lexington, KY
    11 Tacoma Sport Pyrite Mica
    Tint, ARE Z-Series Cap, Yakima rack on cap, ROLA basket, SCS Stealth 6 Matte Gunmetal with full size spare, 285 Terra Grappler, OME lift (885's with Top Plate Spacers, full DAKARS, Carrier bearing drop, stainless extended rear brake lines, BORLA cat back exhaust, color matched All-Pro rear bumper
    I too started and remain on the E position (+1 caster) with 33" tires and a top plate spacer. They dialed right in and rubbed minimally in the front, full lock reversing
  17. Nov 10, 2014 at 7:07 AM
    #297
    iitywygms
    iitywygms Well-Known Member
    Norcal
    4x4
    Hi All:
    I am installing these upper control arms this weekend.
    From the first post.
    1. First, Maximize caster using the eccentrics on the lower control arm. Do not worry about camber at this time.
    2. Reset the caster cams on the UCAs to the minimum value to bring Caster to an acceptable value. I decided to trade off a little less caster for a little more clearance here, and moved the UCA cams to the "+1" position (One degree LESS than neutral, and two degrees less than I started)
    3. Set the camber using the UCA camber adjustment slide.
    4. Finish off toe normally.
    From my understanding of this. If I set the upper control arms to the E position. (+1)
    Put everything back together and take it to the alignment shop, the end results should be good? Meaning, the tire should be optimally centred in the wheel well for best clearance on both sides.
    Just want to be sure before I take it in. Do I need to tell the tech anything specific?
  18. Nov 10, 2014 at 8:19 AM
    #298
    bjmoose
    bjmoose [OP] Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    In that case - the best thing to tell the tech is to follow those steps that you quoted skipping step 2.
    Some alignment techs persist in thinking that one of the alignment cams is the "caster" cam and the other is the "camber" cam - but in reality they work together.
    You may have to physically show the tech where to adjust the camber using the slide on the UCA, as that's not part of the "alignment book" they look at for each individual car, since it's an aftermarket adjustment.
    When you drop it off - make sure the most experienced alignment tech in the shop gets assigned the job.
  19. Nov 10, 2014 at 10:06 AM
    #299
    iitywygms
    Norcal
    4x4
    Awesome! Thanks for the info.
  20. Nov 11, 2014 at 7:47 AM
    #300
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    If he's using the "E" position, he won't get 3 degrees of caster. But that's OK.
