Alignment, Caster, Clearance, and Driving Report with Light Racing UCAs
Discussion in 'Suspension' started by bjmoose, May 24, 2011.
  1. Feb 20, 2012 at 4:09 PM
    jspetrovitsis
    jspetrovitsis Well-Known Member
    James
    NEW HAMPSAHHH
    2011 Tacoma TX PRO
    Toytec/Eibach front coils, Bilsteins on all four, 2 '' AAL, Light Racing UCA, K&N CAI, Weathertecs front and back, Wet Okoles, Alpine INA W900BT in dash navigation, LED cab lights
    Yeah I have probably around 2.75 to 3'' of liftt. Put the LR UCA's and got it aligned but it still doesn't feel right. trying to figure out what to tell the guy when i go back on friday
  2. Feb 20, 2012 at 4:33 PM
    jspetrovitsis
    James
    NEW HAMPSAHHH
    2011 Tacoma TX PRO
    also, will i loose more lift if i set my caster somewhere between that 2.3-3.0 mark????
  3. Feb 20, 2012 at 4:43 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Lose lift? No.
  4. Feb 20, 2012 at 4:48 PM
    jspetrovitsis
    James
    NEW HAMPSAHHH
    2011 Tacoma TX PRO
    i was just reading somewhere that increasing caster will decrease clearance and I plan on putting 285's on after my x country drive and dont want to rub
  5. Feb 20, 2012 at 5:36 PM
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2021 TRD Pro (upgrade from my 2nd gen)
    Work in progress, but mods so far; OTT 7.0 tune, 255/85/16 Falken WildPeak M/Ts
    read the FAQ pages for those UCAs on SPCs website. they'll give you tips on how to maximize clearance. that being said, with 285s there is a decent chance you will rub.
    61ragtop likes this.
  6. Feb 20, 2012 at 6:41 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Yes caster will change your tire position in the wheel well. You don't lose any ride height though.
    Increasing caster at the LCA will push your wheel/tire away from the cab mount, increasing caster through the UCA will push it towards the cab mount/fire wall.
    As per JonnyBp's recommendations... spot on
  7. Feb 20, 2012 at 6:44 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Reading the OP of this very thread gives a good explanation
    Lol
  8. Feb 23, 2012 at 3:21 PM
    Relik
    Relik Well-Known Member
    Eddy
    Thousand Oaks, CA
    '11 TRD Sport PreRunner-Auto-Magnetic Gray
    Bilstein 5100s (Front & ext. Rear), Eibach coils @ 0, MaxTrac 4" Spindles, Light Racing UCAs, 1/4" lean spacer, All-Pro 3" Standard leafs, u-bolt flip kit, SpiderTrax 1.25" wheel spacers, 33" (285/70/17) TreadWright Warden A/T tires, extended lines
    Any recomendations for what setting to put the LR UCAs with 0 to 1.6" lift? Everyone recommends the neutral "0" setting which adds 2* of caster, but this seems to be for 2-3" of lift.
    I will be putting on eibachs/5100s at 0 or getting new COs and setting them between 0 and 1". Would the Neutral 0 (2*) setting work fine or would it give too much caster?
  9. Feb 23, 2012 at 3:34 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Fantastic writeup.
    I have been postponing my install and fighting the twitchy itchy tracking for too long!!!
    Time to act.:D
  10. Feb 24, 2012 at 4:11 PM
    bjmoose
    bjmoose [OP] Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    That would be too much caster. Why install them at all for that little lift?
  11. Feb 24, 2012 at 6:02 PM
    Relik
    Eddy
    Thousand Oaks, CA
    I'll be putting on spindles and knew I wouldn't need UCAs, but I was thinking next upgrade was extended travel COs and you need a new UCA. LR was cheapest option and jus jumped on deal. Hm I'm debating keepin them though...
  12. Feb 29, 2012 at 10:07 AM
    Relik
    Eddy
    Thousand Oaks, CA
    I kept the Eibachs (1.6" lift) with my spindles and put LR setting at the -1 setting (so +1* caster). Figured since the neutral setting @ 0 (2* caster) is used for 3" lift then -1 should be good for me. Plus bjmoose used -1 with 3" lift too. Hopefully I can get 2.5*-3*.
    I need to lift the rear today hopefully then align it today/tom. I'll try and post my results...
    Thanks
  13. Mar 7, 2012 at 1:22 PM
    Relik
    Eddy
    Thousand Oaks, CA
    Ok with my LR UCAs set at the -1 setting (so total of +1* caster) I got my alignment done. Again I have 5100s and Eibach set at 0 in front, All pro 3" leafs in rear.
    Toe:0*
    Camber:0*
    Caster: 3.5*
  14. Mar 7, 2012 at 1:23 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Looks good.
  15. Mar 9, 2012 at 6:43 PM
    #35
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    I'll need this soon...sub'd
  16. Mar 22, 2012 at 9:33 PM
    #36
    SKULLY
    SKULLY Well-Known Member
    Dave
    San Diego
    06 DCSB
    Sub'd
  17. Apr 11, 2012 at 7:06 AM
    #37
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Well im at another alignment shop. The tech literally has no idea what I'm talking about. He keeps saying, "well if we can get it right from the bottom we won't have to touch the Uca"... fml. I've showed him all the diagrams and instructions, but I don't think this is going to work. sigh
  18. Apr 11, 2012 at 7:19 AM
    #38
    OZ-T
    Peter North
    British Columbia
    What setting did you have the UCA's at when you got to the shop ?
  19. Apr 11, 2012 at 7:28 AM
    #39
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    Neutral. Should I have set it before? I thought they would do it as they go.
  20. Apr 11, 2012 at 8:35 AM
    #40
    OZ-T
    Peter North
    British Columbia
    Reread the OP of this thread .
