Alignment, Caster, Clearance, and Driving Report with Light Racing UCAs
Discussion in 'Suspension' started by bjmoose, May 24, 2011.
  1. Apr 11, 2012 at 9:56 AM
    #41
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    reread a couple of times. What's your point?
  2. Apr 11, 2012 at 10:23 AM
    #42
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Unless I am misunderstanding
    Max the eccentrics
    Set your UCA BJ
    Do your fine tune with the cams at the bottom
    Set Camber at the upper nut
  3. Apr 11, 2012 at 12:02 PM
    #43
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Yeah basically they're not gonna want to touch the UCA. You might get them to adjust camber from the top, and that's what you want.
    You'll need to set your UCAs at home.
    Have them rotate the cams for max caster both sides even though. Then ask them to dial in camber using the slot on the UCA. If they can't get it exactly zero they may have to play with the LCA cams a bit.
    This isn't something they encounter everyday as most people don't even specify what kind of stock numbers they want.
  4. Apr 14, 2012 at 6:13 AM
    #44
    09Tacomania
    09Tacomania Well-Known Member
    Scott
    Little Rhody
    09 Silver Streak Dbl cab 4x4
    Icon CO's, LR UCA's, Icon rear 2.0 rear resi's, Wheelers 1.5" 3 pk aal, blacked out badges, Andre's devil horn's, Extang tonneau. Oem racks
    Put my UCA's in last night. Sitting at Firestone waiting on the alignment. Tech says he does alot of lifted trucks. Will see.
  5. Apr 14, 2012 at 6:51 AM
    #45
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    great thread , thanks.
  6. Apr 14, 2012 at 9:43 AM
    #46
    09Tacomania
    Scott
    Little Rhody
    Here's my numbers. Not ideal caster from what i've read here, but it feels good. I go back for new tires in a month or so. Gotta have a talk with the tech. They didnt touch the UCA's as far as i can tell. I set the ball joint neutral with the SPC logo facing tire and tightened it in the middle of the slot. All the way outbaord had the camber way off. idk
    before
    left right
    .9 camber -0.1
    1.8 caster 2.1
    -0.86 toe -0.91
    after
    left right
    1.0 camber -0.2
    1.8 caster 2.1
    .02 toe 0.0
  7. Apr 14, 2012 at 11:25 AM
    #47
    Hairy Taco
    North of Hell
    08 TRD
    I would be interested to hear an experienced opinion here, but to me the imbalance in your camber is pronounced
  8. Apr 14, 2012 at 11:40 AM
    #48
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    IMO
    Camber is off... a degree isn't a lot but still they ought to be able to get you to 0* or extremely close. However, I do believe it's still in spec according to Toyota. I just wouldn't be happy as I want my alignment ideal and that why I bought the LR UCAs. It's probably okay though, all things considered. If your truck begins to pull, I'd look here. I believe this set up will make your truck pull to the right if it does pull.
    Caster is okay, IMO ideally you'd have them set even but you're off .3 degrees so it's not much and some to subscribe to the idea of slight more caster on the right side to counter road crown so I'd be happy with your Caster numbers.
    Toe is fine.
    Just my .02
  9. Apr 14, 2012 at 2:15 PM
    #49
    bjmoose
    bjmoose [OP] Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Not impressed by camber measurements.
    And -.2 is out of spec. IIRC.
    Looks like the fixed your toe and didn't even touch anything else.
  10. Apr 14, 2012 at 4:05 PM
    #50
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    An alignment sheet from Les Schwab shows specs as -.3 - 1.2 camber and 1.3 - 2.8 caster.
    But yeah now that bjmoose mentioned it, it does look like they fixed your toe and touched nothing else. Which is kinda lame. Especially as you're at the limits of being in spec with camber.
  11. Apr 15, 2012 at 6:41 AM
    #51
    09Tacomania
    Scott
    Little Rhody
    Thanks for the input guys. They didnt touch the UCA's. Once they see how easy they are to adjust, maybe they wont be intimidated. I got the lifetime alignment at Firestone and when I went there i had forgotten the install sheet to give to the tech. When i go back for sneakers next month, i'll try to explain a little to the tech and show him the spec sheet. I feel a little funny trying to tell these guys their business. Don't want to insult there intelligence. lol. On another note, any good tech should be open to learning about something he's not too familiar with. I looked at my before and after spec sheet again, and it says on top : Toyota Truck and SUV : 4x2 : 2009-10 : PreRunner Access Cab V6 Auto Trans : with P265/65/17 Tire
    Not sure if it makes a difference, but my truck is 09 double cab, 4x4, with 265/70/17
  12. Apr 15, 2012 at 10:38 PM
    #52
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    It is always an adventure with firestone. I too went with their lifetime alignment service a couple of years ago and maybe its a good thing. Each time I've had it done, it has required a return trip to get it done correctly.
    Most recently was last week after installing camburg UCAs. The numbers on the spec sheet are decent enough but it just doesn't feel right at highway speeds.
    These are my sentiments exactly.
  13. Apr 15, 2012 at 11:39 PM
    #53
    Mendoman
    Mendoman Well-Known Member
    South Lake Tahoe
    2008 SR5 DCSB / 22 TRD OR DCSB
    6112/5100 RXT Option 1
    Lots of good info, great thread.
  14. Apr 20, 2012 at 2:09 PM
    #54
    Digiratus
    Roaming the PNW
    The RedHead
    Had Firestone do a re-check yesterday. I had to convince the tech that he could achieve a higher caster number because of the Camburg UCAs and still maintain good toe and camber.
    Here are the final numbers.
    Before:
    Left Right
    0.09 Camber -0.06
    2.11 Caster 2.09
    -0.01 Toe 0.03
    After:
    Left Right
    -0.09 Camber -0.11
    2.96 Caster 3.02
    0.01 Toe 0.02
    So far it feels much better though I've yet to get it out on the highway.
  15. Apr 28, 2012 at 9:02 AM
    #55
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I too am about to expirience the before and after, also I will be doing what you did to keep good clearances.
  16. Apr 30, 2012 at 8:31 PM
    #56
    Good351
    Good351 Well-Known Member
    Ames, IA
    03 4Runner V8
    Great info here!! Thank you everyone that has contributed!
    I'm getting LR UCA's any day now..ordered last week. I have been fighting a wandering truck for way too long and it is getting old. Even fighting a cross wind has been an ordeal!
  17. May 3, 2012 at 3:18 PM
    #57
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    How do these trucks drive if the caster is set too high? What caster setting is considered too high on these? After Les Schwab did an alignment I'm at 1.9 and 2.3 and now the truck is a little skittish on the freeway. These settings must be too low so now I'm thinking of increasing it but don't want to go too high.
  18. May 3, 2012 at 3:50 PM
    #58
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2021 TRD Pro (upgrade from my 2nd gen)
    Work in progress, but mods so far; OTT 7.0 tune, 255/85/16 Falken WildPeak M/Ts
    After my lift, I was running at about 1* and hated it. I'm running 3.2* now; huge improvement and no complaints.
  19. May 3, 2012 at 7:23 PM
    #59
    smuggiesrider
    smuggiesrider Well-Known Member
    Vermont
    2021 Army Green TRD Off-Road DCSB AT
    TRD 2" Lift kit w/ PRO Grille swap package ARE CX Classic Cap Sumitomo Encounter AT 265/75/16 tires TRD Pro wheels Predator steps Frame salt protection spray Weather Tech floor Mats and rainguards Wet Okole Seat Covers Bedmat Black exhaust tip Bed light LED kit Tailgate mat Eyecatcher tailgate letters Yoda cover for tow hitch and steering wheel Decals for grille, glove box, badges $$$$$$
    I'm about to install LR UCA's with toytec ULK and dakar leaf packs $$
    I want to run 2.5" lift in the front....is any running same setup and if so what are your UCA's set to and what were your final alignment numbers?
  20. May 3, 2012 at 7:27 PM
    #60
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    IMO you'll never have enough adjustability to get to the point where you have too much caster. Just have them set it as high as they can without affecting camber.
    Also IMO it's not worth it to try and bump caster on the passenger side to counter road crown, just set it even and deal with whatever road you're on at the time.
    Governor likes this.
