Alignment, Caster, Clearance, and Driving Report with Light Racing UCAs
Discussion in 'Suspension' started by bjmoose, May 24, 2011.
  1. Jul 15, 2015 at 12:12 PM
    #601
    TucTaco520
    TucTaco520 Well-Known Member
    Phil
    It's a dry heat
    11 Hooptie
    OME 90000s+887s, LR UCAs. AllPro Expos + 5100. KM Fab hybrid sliders w/kickout. KM Fab bed rack. 48" hi-lift. 16" FJ Trail Team wheels. 285/75/16 Hankook Dynapro ATMs. Magnaflow cat-back. K&N filter. TRD short-throw shifter. Murdered out via plasti-derp front grille and rear bumper. LED interior. De-badged tailgate. Rock lights (7). G2V 3x2 ditch lights.
    N00b question-would there be any alignment changes if I got an alignment done on smaller tires, then put larger ones in right after?
  2. Jul 15, 2015 at 12:35 PM
    #602
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  3. Jul 23, 2015 at 8:23 AM
    #603
    Trent_G
    Trent_G Well-Known Member
    Central Oregon
  4. Jul 23, 2015 at 8:28 AM
    #604
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Going in for alignment today or tomorrow with the newly installed LRs ucas.
  5. Jul 27, 2015 at 2:30 PM
    #605
    Trent_G
    Central Oregon
    Just got an alignment. Here are my numbers. Do they look okay? Drivers really nice.
    Is it normal for one side (tire) to rub more than the other? Thx
  6. Jul 27, 2015 at 5:35 PM
    #606
    Justinlhc
    Justinlhc Not looking for a relationship
    I don't see why they couldn't get your caster lower. What do you have? Your alignment guy sucks. There is no excuse for that. Did he know the UCA is adjustable?
  7. Jul 28, 2015 at 8:02 AM
    #607
    JonnyBb
    JonnyBb I have to return some videotapes
    Arkansas
    2021 TRD Pro (upgrade from my 2nd gen)
    Work in progress, but mods so far; OTT 7.0 tune, 255/85/16 Falken WildPeak M/Ts
    Actually 3* of caster is recommended by a lot of guys on TW as well as a tech at SPC.
  8. Jul 28, 2015 at 9:06 AM
    #608
    TucTaco520
    Phil
    It's a dry heat
    11 Hooptie
    I wouldn't mind those numbers one bit. I've seen smaller differences than .4 degrees for caster, and that could be the source of your rubbing.
  9. Jul 28, 2015 at 9:06 AM
    #609
    OZ-T
    Peter North
    British Columbia
    They could have been more even but 3 is fine
  10. Jul 28, 2015 at 10:24 AM
    #610
    Justinlhc
    I don't like the .4 difference. With the available adjustments I don't see why they couldn't have matched them closer.
  11. Jul 28, 2015 at 11:19 AM
    #611
    Trent_G
    Central Oregon
    Thanks guys for the feedback.
    Justin, it's something to do with road crown.
  12. Jul 28, 2015 at 11:20 AM
    #612
    Trent_G
    Central Oregon
    Also is it normal for one tire to rub and the other nothing?
  13. Jul 28, 2015 at 11:48 AM
    #613
    Eagle1
    Eagle1 Well-Known Member
    My drivers side used to rub more because I was told that's the side the fuel tank is on....since then we cranked the coils up accordingly and added a leaf in the back and no more rub....that's with a six inch bds lift..fox coilovers...Rev tech add a leaf and 35inch nitto trail grapplers
    Trent_G likes this.
  14. Jul 28, 2015 at 2:27 PM
    #614
    Justinlhc
    Must be a regional thing. :cheers:
    They definitely don't do that out here, but it's dry as a fart and the roads are pretty flat.
    Trent_G[QUOTED] likes this.
  15. Jul 28, 2015 at 2:32 PM
    #615
    TucTaco520
    Phil
    It's a dry heat
    11 Hooptie
    My farts are pretty juicy
    YotaDan likes this.
  16. Jul 28, 2015 at 2:37 PM
    #616
    Justinlhc
    You might need less caster on the driver side :notsure:
    TucTaco520[QUOTED] likes this.
  17. Jul 28, 2015 at 11:15 PM
    #617
    Trent_G
    Central Oregon
    Did a bunch of reading tonight and I think I neend more caster. More caster pushes the wheel forward. I'm going back tomorrow to talk to the alignment guy and ask him to get the drivers side closer to 3.
  18. Jul 29, 2015 at 6:09 AM
    #618
    Eagle1
    Measure the distance from the top of the tire to the fender flare and from the tire to where it hits on both sides to see if your drivers side leans.Ive been through all of this.
  19. Jul 29, 2015 at 10:19 AM
    #619
    Trent_G
    Central Oregon
    Thanks for the reply.
    Did that and it was about 1/2". Going back today to see if they can raise caster and forget about road crown.
  20. Jul 29, 2015 at 11:01 AM
    #620
    Justinlhc
    To give you something to compare to:
    1" front lift
    SPC uppers at the +2 "D" position
    17x9 0 offset
    265/70/17
    Caster at 2.4 both sides.
    My driver side tire STILL rubbed the lower fender/body mount area pretty bad when turning left. No mud flaps.
