Alignment, Caster, Clearance, and Driving Report with Light Racing UCAs
Discussion in 'Suspension' started by bjmoose, May 24, 2011.
  1. Jul 29, 2015 at 11:03 AM
    #621
    Eagle1
    Eagle1 Well-Known Member
    Don't think that will help...from my understanding caster will only move it a little from where your at...not that much to make a difference. ...I am no expert so please tell me what your alignment man says
  2. Jul 29, 2015 at 11:50 AM
    #622
    Trent_G
    Trent_G Well-Known Member
    Central Oregon
    Okay just got off the phone with Specialty products (light racing) and they suggested this (#5). They did say you can do the adjustment to one side and not the other without throwing the entire alignment out of whack. Going back in for alignment on Monday.
  3. Jul 29, 2015 at 2:10 PM
    #623
    Eagle1
    Nice.....so does this mean you have light racing adjustable lower control arms? Or is this something you can do with the stock lowers?I am very interested in what you find out!I've always had a hunch that it could be done this way.But with my limited knowledge I was unable to clearly explain myself to the shop.
  4. Jul 29, 2015 at 2:21 PM
    #624
    TucTaco520
    TucTaco520 Well-Known Member
    Phil
    It's a dry heat
    11 Hooptie
    OME 90000s+887s, LR UCAs. AllPro Expos + 5100. KM Fab hybrid sliders w/kickout. KM Fab bed rack. 48" hi-lift. 16" FJ Trail Team wheels. 285/75/16 Hankook Dynapro ATMs. Magnaflow cat-back. K&N filter. TRD short-throw shifter. Murdered out via plasti-derp front grille and rear bumper. LED interior. De-badged tailgate. Rock lights (7). G2V 3x2 ditch lights.
    You adjust caster with the stock LCA's as it is, and the LR Upper control arms add another source of additional caster change depending on their setting.
  5. Jul 29, 2015 at 2:22 PM
    #625
    Trent_G
    Central Oregon
    Yep, LR UCA hence the title of the thread (giving you a hard time). ;) Hopefully the alignment guy understands. I'm going to take this F&Q sheet in and a number where he can call them if any questions. Super nice people at Specialty Products.
  6. Jul 29, 2015 at 3:04 PM
    #626
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You can also adjust camber on the LR UCAs
    TucTaco520[QUOTED] likes this.
  7. Jul 30, 2015 at 10:53 AM
    #627
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I finally got Firestone to understand what I want out of my alignment and the tech is willing to work with me. I went into the shop and the tech showed me what was going on. He maxed out Caster and said that the Camber was going to suffer, I get that. Below is with Caster maxed out with the Balljoint at the 'Neutral' position. The question is do I adjust the Caster +1* or adjust the Camber, or both?
    Camber
    1.0 | 0.7
    Caster
    2.5 | 2.6
  8. Jul 30, 2015 at 11:13 AM
    #628
    TucTaco520
    Phil
    It's a dry heat
    11 Hooptie
    I thought you could get 3 degrees of caster and zero out camber in the neutral position. Makes me think I should install with E. Did you tighten the ball joint assembly right in the middle of the slide?
  9. Jul 30, 2015 at 11:25 AM
    #629
    Sandman614
    Tim
    '06 SR5 Off Road
    Mine is more toward the outside of the slide but not maxed out. Moving it to the middle might give me the numbers I want, just trying to get a feel for where it should be.
  10. Jul 30, 2015 at 11:27 AM
    #630
    TucTaco520
    Phil
    It's a dry heat
    11 Hooptie
    I was planning on installing it smack dab in the middle. That should lower the max camber possible and increase the max caster.
  11. Jul 30, 2015 at 4:27 PM
    #631
    Sandman614
    Tim
    '06 SR5 Off Road
  12. Jul 30, 2015 at 4:46 PM
    #632
    OZ-T
    Peter North
    British Columbia
    Do you have the installation sheet ?
  13. Jul 30, 2015 at 4:51 PM
    #633
    TucTaco520
    Phil
    It's a dry heat
    11 Hooptie
    Yes but I haven't gone through it yet. Wont be installing for 2 weeks :annoyed:
  14. Jul 30, 2015 at 4:52 PM
    #634
    Eagle1
    Nice....
  15. Jul 30, 2015 at 4:54 PM
    #635
    OZ-T
    Peter North
    British Columbia
    You should read it
    DoorDing likes this.
  16. Jul 30, 2015 at 4:57 PM
    #636
    TucTaco520
    Phil
    It's a dry heat
    11 Hooptie
    Correct me if I'm wrong on any of the above...we're all here to learn.
  17. Jul 30, 2015 at 4:59 PM
    #637
    OZ-T
    Peter North
    British Columbia
    I'm not trying to be a dick , it's worth reading prior to install so you understand what you're up against
    The neutral position adds 2 degrees of caster , the camber adjustment is via a slide and is adjustable on its own and is not tied in any way to how much caster you dialed in on the balljoint
  18. Jul 30, 2015 at 5:05 PM
    #638
    TucTaco520
    Phil
    It's a dry heat
    11 Hooptie
    Didn't think you were, I just wanted to know if I misspoke. I'll definitely be going through that thing numerous times before anything else. I'm confused why Sandman cant get at least 3 degrees of caster and zero out camber with the neutral position.
  19. Jul 30, 2015 at 5:09 PM
    #639
    OZ-T
    Peter North
    British Columbia
    Depends on how your LCA alignment cams are adjusted
    In the opening post of this thread Steve explains the relationship between the LCA cams and the LR UCA adjustments
  20. Jul 30, 2015 at 5:11 PM
    #640
    OZ-T
    Peter North
    British Columbia
    Did they know they could adjust camber indipendently on the UCA ?
