Alignment, Caster, Clearance, and Driving Report with Light Racing UCAs
Discussion in 'Suspension' started by bjmoose, May 24, 2011.
  1. Mar 9, 2016 at 3:37 PM
    #721
    pedwards9367
    pedwards9367 Active Member
    Got my spc ucas on today and they got the caster to 1.9 and 1.8. I was not rubbing before and now I'm rubbing on both sides rear fender well. Should I change the setting or trim?
  2. Mar 9, 2016 at 3:47 PM
    #722
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    How much caster did you ask for ? Thats pretty low
  3. Mar 9, 2016 at 4:00 PM
    #723
    pedwards9367
    I didn't ask I'm assuming he went by starting point on the instructions. Could I tell them to move the tire back forward some since the numbers are so low. Most guys up here are reporting 2-2.5
  4. Mar 9, 2016 at 4:13 PM
    #724
    OZ-T
    Peter North
    British Columbia
    I asked for 3 , 0 , 0 , thats what I got on mine
  5. Mar 9, 2016 at 4:22 PM
    #725
    pedwards9367
    The 0's being camber and 3 for caster? Do you have any rubbing? Mine rub now before full lock which I can't stand.
  6. Mar 9, 2016 at 4:22 PM
    #726
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    No complaints with those settings? I'll be doing a lift & alignment soon.
  7. Mar 9, 2016 at 4:24 PM
    #727
    OZ-T
    Peter North
    British Columbia
    3 caster , 0 camber , 0 toe
    I have 275/70/17's on stock Sport alloys with no wheel spacers , no rubbing
    No complaints
  8. Mar 9, 2016 at 5:47 PM
    #728
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    I will be going back for an alignment soon. will have to let them know these numbers. I rub full lock now with 2.5 lift 265/70/17
  9. Mar 9, 2016 at 5:58 PM
    #729
    OZ-T
    Peter North
    British Columbia
    Stock wheels ? No wheel spacers ?
  10. Mar 9, 2016 at 6:14 PM
    #730
    pedwards9367
    Forgot to mention earlier I have procomp 3" with 285/70/17. Here were my numbers
  11. Mar 9, 2016 at 6:52 PM
    #731
    pedwards9367
    It lookes like he put it on setting D so if turned it to E would that fix my clearance issue?
  12. Mar 9, 2016 at 7:01 PM
    #732
    williams63
    chili
    nh
    2011 dblcb
    scs rims no spacers
  13. Mar 9, 2016 at 7:57 PM
    #733
    Justinlhc
    Justinlhc Not looking for a relationship
    Your caster was better before they "corrected" it.
    If they brought your caster out to 3° (where it should be)via the lower control arm adjustments you will have more clearance.
  14. Mar 10, 2016 at 4:06 AM
    #734
    pedwards9367
    So your saying by adjusting the lca and leave the ball joint in the D position I should be fine?
  15. Mar 11, 2016 at 9:13 PM
    #735
    Justinlhc
    I can't guarantee it, but that's my guess. I'd be curious to see where your rear lower control arm eccentrics are set.
  16. Mar 12, 2016 at 6:47 AM
    #736
    pedwards9367
    So I went back today and he maxed out the lower arm eccentrics and now I have no more rubbing. Brought my caster up to 2.4 and 2.5 He left my ball joints in the D position. Rides great!
    Justinlhc[QUOTED] likes this.
  17. Mar 15, 2016 at 3:24 PM
    #737
    TRDrh
    TRDrh Well-Known Member
    Richard
    SoCal
    Is it necessary to purchase new UCA bolts for the install? I just purchased a set of SPC LR UCAs and i didn't purchase any yet. thanks.
  18. Mar 15, 2016 at 3:36 PM
    #738
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    No you can reuse the current one if they are not corroded and you don't damage them removing the old UCAs.
    TRDrh[QUOTED] likes this.
  19. Mar 15, 2016 at 3:37 PM
    #739
    AZ2013
    AZ2013 Well-Known Member
    Blake
    2014 Spruce Mica DCSB
    I just put LR UCAs on my truck and re used the factory bolts. Worked fine for me.
    TRDrh likes this.
  20. Mar 15, 2016 at 3:39 PM
    #740
    TRDrh
    Richard
    SoCal
    Thanks guys for the quick response, I will not be doing the install myself because i do not have room at my townhouse and the proper tools.
