Alignment, Caster, Clearance, and Driving Report with Light Racing UCAs
Discussion in 'Suspension' started by bjmoose, May 24, 2011.
  1. Aug 25, 2016 at 4:01 PM
    #801
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    0* camber (+/- 0.3*)
    3.0 caster LF/3.5-3.7 caster RF
    0* toe, or toed out 0.5*
    These settings work well for me. Cross caster corrects the right pull with larger tires for me
    dirtnsmores[QUOTED] likes this.
  2. Aug 25, 2016 at 4:44 PM
    #802
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    I think he means settings for the balljoint in the uca? i put mine at D, but different truck, different lift.
    I haven't read the OP in a while, but I'd start at D for caster and in the center of the slot for camber then go from there.
  3. Aug 25, 2016 at 4:45 PM
    #803
    Aussiek2000
    2016 Offroad AC
    yeah, start at D. mine are way off from that now. lol
  4. Aug 25, 2016 at 4:52 PM
    #804
    MTopp
    05 SR5 4x4
    Yeah unfortunately my alignment guy doesn't want to mess with the alignment stuff on the UCA, so I may find a specialty shop, more $$$, but it will be how I want it and they may be able to give me more tire clearance.
    Curious what yours are at now? I may re-research this quickly tomorrow and move them to C so i can get more caster...
    Does the positive adjustment of caster on UCA move the tire backwards or forwards??
    I am also wondering now, at the caster adjust on LCA it moves the tire back towards rear.
  5. Aug 25, 2016 at 4:54 PM
    #805
    Aussiek2000
    2016 Offroad AC
    Mine for some reason are way off from the norm you'll see here. RH side is maxed out, LH is at C. The gave me 3.2/3.7 caster and centered the wheel.
  6. Aug 25, 2016 at 4:55 PM
    #806
    MTopp
    05 SR5 4x4
    Ohh I see. Interesting
  7. Aug 25, 2016 at 5:05 PM
    #807
    MTopp
    05 SR5 4x4
    Good picture to help some about caster adjustment - positive should move the tire forwards
  8. Aug 25, 2016 at 5:11 PM
    #808
    Aussiek2000
    2016 Offroad AC
    Wheel won't move until you start moving the factory lower cams
    MTopp[QUOTED] likes this.
  9. Aug 25, 2016 at 5:25 PM
    #809
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    My lr UCAs (3k miles)have been dumping the grease out the bottom after a long backcountry wheeling trip- i definitely flexed out at some point based on i can see my bumpstops made contact a bunch of times- how much of a pain is it to replace the boots? I see they are only $8.50 and someone said you can do it without removing the ball joint. Does anyone know what kind of pliers I'll need for the retaining ring at the top of the grease boot? Anyone else losing grease like this?
  10. Aug 25, 2016 at 5:26 PM
    #810
    Aussiek2000
    2016 Offroad AC
    Mine leak a little. But it's not a big deal to me. Just shoot a couple pumps in here and there
    IronPeak likes this.
  11. Aug 25, 2016 at 7:28 PM
    #811
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    265/70/17 mostly street but take a monthly trip to the dirt.
  12. Aug 25, 2016 at 7:29 PM
    #812
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    thanks i'll keep this bookmarked. running 265/70/17
  13. Aug 25, 2016 at 9:03 PM
    #813
    MTopp
    05 SR5 4x4
    The older model ucas don't have grease zerks on the balljoints. Those were added in the past year or so
  14. Aug 26, 2016 at 12:36 PM
    #814
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    what's the size of the gold nut on the uca? The one that controls the adjustment
  15. Aug 26, 2016 at 12:42 PM
    #815
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    iirc it was 32mm or 1 1/4 ??
  16. Aug 27, 2016 at 5:39 AM
    #816
    J4m3z420
    J4m3z420 Active Member
    James
    Keystone, CO
    09 DCBS TRD Off-Road V6 4x4
    Front: OME 884x | 90021 | Light Racing UCA’s Rear: CS047R (minus top overload) | 60091 FN Six Shooter 17x8 6-139.7 (20lbs) BFG KO2: LT265 /70 R17 112S C1 RWL (45lbs) ECGS bushing front diff
    Can anyone tell me for alignment adjustment, that when adjusting the cams in the LCA, does increasing caster change the camber measurement? Does camber become more negative or positive as caster is increased through the LCA.
    Trying to figure out the ideal position of the LR UCA bolt ( in, out, or middle) prior to taking to alignment shop. I will not tell them about the UCA adjustment and want them to just fine tune with the LCA. Thank you.
  17. Aug 27, 2016 at 8:14 AM
    #817
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    thanks. I'll search around and try those
  18. Aug 27, 2016 at 8:37 AM
    #818
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Yes 32mm
    Edit I couldn't find 32mm but as stated 1 1/4 works perfectly
  19. Aug 27, 2016 at 2:39 PM
    #819
    Chephie
    Chephie Well-Known Member
    Chad
    Ohio
    2012 MGM DCSB TRD OR
    OME884/5100's Wheelers Progressive AAL LR UCA's 265/75/16 Duratrac Method NV wheels Color matched grille surround ImMrYo rear view mirror relocation bracket Avid slider/steps
    Yes, from my understanding you are correct, caster and camber play off each other and increasing caster with the lca will decrease camber and vice versa. I have the LR UCA's as well, just my $.02 but I would suggest you tell whoever is performing your alignment about the adjustability as well as show them the instructions if they have no experience with them, may save you some headache. I put mine on the "D" setting initially per instructions and the bolt itself for camber adjustment I believe I left somewhere in the middle. I asked the tech to put the lower eccentrics back to neutral and just start from scratch. Most of the fine tuning did come from the lowers however we did have to adjust the UCA's a bit as well. I can tell you from experience if you have an alignment tech who knows what he's doing they can put it right on the numbers you ask for with no issue. Hope this helps...
  20. Aug 29, 2016 at 9:28 AM
    #820
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    at the shop right now. They cant get exactly three, but 2.9 caster, toe and camber 0. Seems like I'll be good based off this thread. Any input much appreciated. 885s/5100s just installed.
    MTopp likes this.
