Alignment, Caster, Clearance, and Driving Report with Light Racing UCAs
Discussion in 'Suspension' started by bjmoose, May 24, 2011.
  1. Mar 18, 2019 at 5:49 PM
    #1121
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    No print out since I diy’d it.
    But
    - Both ball joints set at setting “E”.
    - Control arm cams maxed for caster (rear out, front in).
    Aligned.
    Driver (left) side -
    Caster - 3.3/3.4*
    Camber - -.5*
    Passenger (right) side -
    Caster - 3.8/3.9*
    Camber - -.5*
    Toe - 1/8” toe in
    Cross caster - ~.5* to the passenger side.
    Suspension details -
    Front - 5100s @ .85 + Toytec Eibachs + 3/8” top plates. Roughly 3”
    Rear - TSB springs + 3 leaf add a leaf + 1/2” block. Roughly 2”
    285/75/16 Duratracs + 16x8 et-10 wheels.
    Trimmed bottom front corners of the flares + moved front fender liners + trimmed mud flaps + no cab mount chop.
    boostedka and mcharfauros like this.
  2. Mar 18, 2019 at 5:53 PM
    #1122
    08RC
    08RC Well-Known Member
    Looks good . If I go with 1/8" toe my steering wheel gets a bit of bump steer on small bumps in the road . Having a hard time getting used to that term coming from Jeeps where Bump steer meant something else all together.
  3. Mar 18, 2019 at 7:09 PM
    #1123
    Hookedup
    Hookedup Well-Known Member
    SOFLO
    2012 DCSB SPORT/ 2019 OR DCSB
    FOX 2.5 DSC/ICON RXT/SPC UCA
    Ok thanks..maybe I’ll try D next time.. did you notice any clearance difference (cab mount/ fender) between D or E? I know it’s just moving the top of the spindle not the lowers)
    jetbill likes this.
  4. Mar 18, 2019 at 11:27 PM
    #1124
    08RC
    oh yes . I finally got enough trimmed and heated up and moved away on the front of the fender . Now its back to actually needing the CMC or close to it . I had no issue with the CM at E but I remember it was really close at time to just barely touching it at D before. I had done everything on the back side of the wheel well when installing the Foxes but not the CMC. IIRC when I was at D before once in a great while it would just touch the CM to remind me to keep it on my list of things to deal with eventually
  5. Mar 19, 2019 at 4:56 AM
    #1125
    Toyojo
    Toyojo Well-Known Member
    Joe
    Erie,pa
    2010 mgm dcsb TRD offroad
    Back are all the way out fronts are just past bottom center about 7 o'clockish
  6. Mar 19, 2019 at 5:45 AM
    #1126
    08RC
    I am guessing that the alignment guy went for max clearance fore and aft the tire as I also believe he could of got more caster than he did at E but tried to keep the tire out of the front side of the fender on yours. At E all my trimming was needed at the front . I could not hit the Cab Mount. Now at D I don't believe I could touch the front now no matter what the condition. I can see a CMC coming in the D position. I kept the LCA maxed out for caster since I installed the lift . Im mainly after good tracking and no steering wheel shimmy on rough roads. Never did it with OE suspension and did it as soon as I lifted it even with the 285s that were fine before the lift just not the size or wheel I wanted. Before the lift I was amazed at how nothing bump wise effected the steering wheel at all now just the opposite although better at 0 toe just not as good as it could be I feel
  7. Mar 19, 2019 at 7:53 AM
    #1127
    steveo27
    Pittsburgh
    Yup.
    All my trimming is up front at position E. The wheel is completely centered in the wheel well which was my main goal.
    Trimming the front is wa easier than the rear since it’s just plastic. Unbolt the fender liner too and just push it forward.
  8. Mar 19, 2019 at 8:21 AM
    #1128
    08RC
    I used a heat gun for as much of the plastic work as possible to maintain as much strength in the plastic as I could. Some worked some didn't. I think if set at D it would be pretty close to the same out come as far as tire position but with just more caster. With D you move the upper a little farther back but with LCA at max caster they are farther forward, cam adjuster wise. I don't care for rubbing but I will mod things to get 3-4 degrees caster. This is all just my feeling as it sounds logical and so far ( 2 days at D ) I have not rubbed yet at the mount but I feel confident it will eventually. Much less steering correction now at E with lowers still set at max caster. Im just used to not cranking the steering to the max on a 4x4 just to make life easier for all the U joints and on this CV joints out of habit. Once I feel OK with it I will probably have a local shop that knows me well fine tune the alignment
  9. Mar 19, 2019 at 4:42 PM
    #1129
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    what size tire are you running? im at D and just had new tires put on ko2 265/70/17 and it rubs much worse than it did with my toyo open country in the same size.
  10. Mar 19, 2019 at 4:43 PM
    #1130
    09TRDSport4x4
    09TRDSport4x4 OCD Approved!
    Nick
    Southwest Ohio
    I don’t have any rubbing on my 2” lift with stock UCAs and 265/70/17 KO2s
  11. Mar 19, 2019 at 4:47 PM
    #1131
    williams63
    chili
    nh
    2011 dblcb
    stock wheels? I have scs rims little wider than stock
  12. Mar 19, 2019 at 5:00 PM
    #1132
    09TRDSport4x4
    Nick
    Southwest Ohio
    Stock 7.5” wide TRD Sport wheels +30mm offset with 1” spacers.
  13. Mar 19, 2019 at 6:42 PM
    #1133
    steveo27
    Pittsburgh
    285/75/16 on a 16x8 et-10.
    Are your LCAs maxed for caster? This mKes a huge difference on how your tires sit.
  14. Mar 19, 2019 at 7:02 PM
    #1134
    Hookedup
    SOFLO
    Tires are all you changed?? I didn’t check your size but i noticed that the KO2 ran a smidge bigger than the nitto’s i was looking at but only by .1”
  15. Mar 20, 2019 at 7:44 AM
    #1135
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    I was at D and getting some slight rub on the mount running 305/65/17 on 17x8.5 -10 offset Ray 10's and 885's up front with a single AAL in the rear. I just move the UCA to position E and my slight rub appears to be gone. The steering feels slightly looser compared to D but I've been making changes to the alignment slowly myself so I have no idea where any of the numbers are. I wanted to wait until I thought it was close before going to shop to get a readout. My LCA's are frozen so I don't want to waste time trying to have them adjusted until I decide to replace the bushings.
    This picture is when they were at D. There is more room up front but my lowers are not maxed out.
    Hookedup likes this.
  16. Mar 21, 2019 at 7:55 AM
    #1136
    Hookedup
    SOFLO
    Here’s a couple pics before and after proper alignment:
    Driver side: Setting D lower cams not maxed (factory specs)3B211EC1-180B-4F0C-A618-C83D847DEB76.jpg
    Driver side: (wheel in same position) setting E lower cams maxed
    yeos and steveo27 like this.
  17. Mar 24, 2019 at 5:02 PM
    #1137
    energygeek
    energygeek WassawBound
    Santa Clara, CA
    2015 Tacoma TRD Offroad
    Current Setup: Tire: 33" KO2 Wheels: SCS Front: Bilstien 6112 Rear: Bilstien 5100 & OME Leafs Storage: Decked and SnugTop Brakes: Extended Stainless Lines Roof Rack: Prinsu Towing: Tacoma Tow Package with REDAC brake controller Kayak Bunks: 3" PVC. :) Sleep Setup: In shell or on roof with Plywood and Big Agnes Fly Creek II Cooler: RTIC 65 Liter Future Mods: Winch: MileMaker 12000, install in progress. Bumpers: Any Suggestions? Dual Battery: Roof Top Tent: FSR Power Management: SPOD Brake Upgrade: 4 Runner Conversion Needs Fixing: Wheel Wells Broken Sway Bar bolt
    The Firestone shop in San Jose refused to align my SPC UCAs even if I forgo their warranty.
    I just finished installing the UCAs and Bilstien 6112. The ride is very very twitchy so I wouldn't even dare put it on the freeway right now. I have them set in the D position and centered the UCA camber slot. Can anyone recommend a shop in San Jose, CA that will align using these control arms?
  18. Mar 24, 2019 at 5:12 PM
    #1138
    Z7Xtreme
    Z7Xtreme Always Overestimated
    Chuck
    In a tree somewhere
    2015 trd Black Ops edition
    884's and 5100's with HS 1/4" taco lean spacer,1 inch toytec block and 5100's,SPC uca's,SCS Ray 10 wheels,265/75/16 Falken Wildpeak AT3,oem running boards,oem skid plate,WeatherTech floor liners,WeatherTech window deflectors,Access tonneau cover,WeatherTech stone and bug shield ,BPF tow hook,oem bed mat,pro grill,tacomabeast headlights,cali raised ditch brackets with Rigid lights,Rough country 30” lightbar on Rigid brackets RCI bedrack, KC rear lights,maxtrax,dual rotopax.
  19. Mar 24, 2019 at 10:19 PM
    #1139
    Hookedup
    SOFLO
    It took me three 4x4 shops to find someone who knew what they were doing. I’m sure there is a reputable off-road shop there in San Jose that’ll do it right.. call and ask around.. good luck
  20. Mar 25, 2019 at 1:24 AM
    #1140
    08RC
