Alignment, Caster, Clearance, and Driving Report with Light Racing UCAs
Discussion in 'Suspension' started by bjmoose, May 24, 2011.
  1. Apr 30, 2022 at 7:03 PM
    #1281
    awantura
    awantura Active Member
    Ended up doing the alignment myself since the shop wont listen to what I asked them for. Maxed out lcas for caster->uca to "F"->fix camber on uca->set toe. 2.3 caster, 0 camber, 1/16 total toe dyi driveway measurements. Gained clearance in the back and drives WAAY better than setting "D" with 3.4/3.9 caster turning the wheel was really heavy. Still have to mess with toe a bit as my wheel is slightly off center and may add some cross caster. Most annoying part was loosening tie rod nuts used a 22mm crows foot + breaker bar (one side wouldnt budge tried pb blaster, freezing it, blow torch...then realized I was turning the wrong direction). Used this for caster/camber https://www.amazon.com/gp/product/B00PKI0WXM?ie=UTF8 (worked great), and string method for toe (bought toe plates but string and jack stands worked out better for me).
    BassMaster06 likes this.
  2. Jul 6, 2022 at 9:22 AM
    #1282
    BassMaster06
    BassMaster06 Well-Known Member
    Dan
    South Carolina
    2006 Double Cab V6 4x4
    Mods: sand, dog hair, roof rust
    Setting “E”
    Caster 2.78/2.86
    Camber .32/.30
    Toe .05/.06
    2006, OME 887/5100s, 285/70/17, 17x9 -12 wheels
    Drives straight, handles well. No CMC, minor plastic trimming. Kinda wish my camber was a little closer to 0 but I’m happy with the outcome for now.
  3. Jul 14, 2022 at 1:12 PM
    #1283
    awantura
    For others reference here is my alignment sheet. 2" inch lift . Lowers maxed for caster (driver a bit less to account for cross caster), UCA set at "F" and slid almost 100% towards the center of the truck. Before is my driveway alignment and after tire kingdom. I knew the camber was a bit off but thought my toe was good (based on toe plates + jack/fishing line method). The only change tire kingdom did was slightly move driver front cam for camber and fix toe.
    edit: my at home alignment readings (the before on the tire kingdom sheet) were 2.1/2.6 caster and -0.15/0 camber vs Tire Kingdom 1.8/2.2 caster and -0.6/0.3 camber. I re-measured after getting the alignment and I guess the two driveways I measured on were crooked. I was using a self-leveling angle finder and never zeroed it out next to the wheel. Once I did that my measurements were pretty spot on with tire kingdom.
  4. Aug 28, 2022 at 3:26 PM
    #1284
    CMENTTACOKID
    CMENTTACOKID Member
    18 Tacoma DCSB Off Road Cement Gray
    Can someone please post pictures of their maxed out LCA eccentrics I’m confused as to which way I have to rotate them.
  5. Aug 28, 2022 at 6:44 PM
    #1285
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    CMENTTACOKID[QUOTED] likes this.
  6. Aug 29, 2022 at 11:59 AM
    #1286
    CMENTTACOKID
    CMENTTACOKID Member
    thank you! Top picture is front passenger side & bottom is the same side but the rear of the control arm correct?
    a2lowvw[QUOTED] and BassMaster06 like this.
  7. Aug 29, 2022 at 2:50 PM
    #1287
    BassMaster06
    Dan
    South Carolina
    Fronts in, rears out
    Referencing this diagram, both front cam bolts turned inboard (shorter). Both rear cam bolts turned outboard (longer).
    tacomarin likes this.
  8. Aug 30, 2022 at 7:59 PM
    #1288
    LazyStegosaurus
    LazyStegosaurus Member
    Hello! Just put 265/70/r17 Open Country AT3s on RockTrix wheels that have a -12 offset. Fully stock 2017 TRDOR suspension. Rubs pretty bad when turning. Would strongly prefer not to cut much of anything. Would an alignment possibly fix this issue?
  9. Aug 31, 2022 at 4:44 AM
    #1289
    BassMaster06
    Dan
    South Carolina
    Where’s it rubbing?
  10. Aug 31, 2022 at 4:57 AM
    #1290
    LazyStegosaurus
    Appears to be back side of the wheel wells.
  11. Aug 31, 2022 at 5:38 AM
    #1291
    BassMaster06
    Dan
    South Carolina
    Might be worth a shot if you can find an alignment shop that’ll work with you, but they'll be pretty limited due to your stock UCAs
  12. Aug 31, 2022 at 6:25 AM
    #1292
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    Mud flaps already gone? That size shouldn't rub
  13. Aug 31, 2022 at 6:26 AM
    #1293
    LazyStegosaurus
    Yup, no mud flaps.
  14. Aug 31, 2022 at 9:09 AM
    #1294
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    yes and sorry just saw your response
  15. Aug 31, 2022 at 1:49 PM
    #1295
    BassMaster06
    Dan
    South Carolina
    His wheels have -12 offset, so I’m guessing he’s got 17x9 wheels. The negative offset and wider than stock wheels are likely the culprit.
    Seen a couple 3rd gen owners reporting rubbing with with -10 offset and no lift.
  16. Aug 31, 2022 at 1:53 PM
    #1296
    LazyStegosaurus
    Yup. 17x9 with a -12 offset.
    BassMaster06[QUOTED] likes this.
  17. Aug 31, 2022 at 3:02 PM
    #1297
    BassMaster06
    Dan
    South Carolina
    In my opinion, you’ve got several options to explore. We didn’t get a whole lot of info from you, so it all depends on how you use your truck, how bad you’re rubbing and where, how much you’re willing to cut/trim, or how much $ you’re comfortable with spending to make the rubbing stop.
    A small leveling kit or lift and adjustable UCAs would likely solve your issues. At the same time, it doesn’t sound like you’re ripping off your fenders, so a little plastic trimming might be the way to go. If you’re rubbing the cab mount, there’s also a ton of info on here for that fix and it’s relatively cheap to do, especially if you got a buddy with a torch/welder.
  18. Apr 17, 2023 at 8:32 AM
    #1298
    happyabortion
    happyabortion Well-Known Member
    brian
    port arthur TX
    99 tacoma prerunner
    So my alignment has never been right. Firestone just flat out gave me my money back and the next shop I took it to I pretty much did it for him. It's OK but it's not right. I'm going to go after it again.
    Guys with 6 inch lifts, what setting did you end up with on the ball joint? The "D" setting based on a 2-3" lift?
    I wasn't sure if we need to go out further since it's a big lift. Currently I'm on "A" and my caster setting is super high.
    2013 Tacoma Fabtech 6" lift.
