alignment caster specific help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SkimSTI, Nov 18, 2014.
  1. Nov 18, 2014 at 9:02 AM
    SkimSTI
    SkimSTI [OP] Well-Known Member
    Orange County CA
    '14 MGM TRD dblcab & '16 Mercedes C450
    Magnaflow exhaust, AFE stage 2 intake, King 2.5" resi coilover/rear shocks, Pro Comp UCA's, Deaver 1.5" leaf pack, BPF raptor style grill
    Hey guys,
    just got done installing my king lift, with some new UCA's as well. Ive been through 2 alignments so far and im still not fully happy with the ride.
    my current settings are:
    0 camber
    0 toe
    ~1.7 caster
    i am reading that 2.4 caster or so is ideal for a perfect setting. right now the car feels floaty/light at highway speeds. not as sketchy as when i had stock UCAs though, so thats a plus!
    however, my real question, if i am understand caster correctly, if we add more positive caster, would that push the forward in the wheel well more? i am rubbing ever so slightly on the back of my fender when turning, i am wondering if adding more caster will a) fix the floaty and b) push the tire up enough to eliminate the rub.
    thoughts? am i on the right track of understanding this?
    -Skim
  2. Nov 18, 2014 at 9:57 AM
    wobble
    wobble Well-Known Member
    Ridgefield, WA
    2014 TRD OR
    Modified RCD Lift, 315/70R17 STT Pros
    Correct. Adding more caster using the LCA adjustments will move the tire forward, adding more clearance. The added caster helps reduce the twitchy/floating feeling you describe.
    1.7 is pretty low IMO. Most here suggest around 3. I prefer more towards 4.
  3. Nov 18, 2014 at 10:00 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    What UCAs are you using?
  4. Nov 18, 2014 at 10:17 AM
    SkimSTI
    Orange County CA
    Pro Comp Uniball
  5. Nov 18, 2014 at 11:16 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
  6. Nov 18, 2014 at 11:27 AM
    SkimSTI
    Orange County CA
    those are them! my research findings said i could get 3* max. taking it to get another alignment tomorrow hopefully. finally found someone who sounded like they knew what they were talking about.
  7. Nov 18, 2014 at 11:59 AM
    MPLS TACO
    MPLS TACO Well-Known Member
    CHad
    MN
    TRD Sport
    3" Lift with UCA, Grillecraft grille, XD rims w/ 285/70r17 duratracs, leer xq cap,
    I have camburg UCA's and the caster is set at 2.5 and its awesome. I had the same wondering problem you speak of and this took care of it completely.
  8. Nov 18, 2014 at 12:01 PM
    MPLS TACO
    CHad
    MN
    TRD Sport
    How in the world did anyone get above 3?
  9. Nov 18, 2014 at 12:06 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I could get above 3.0 with my LR UCA's if I wanted to
  10. Nov 18, 2014 at 12:23 PM
    SkimSTI
    Orange County CA
    awesome, thanks for confirming bro
    yea the alignment guy i called this morning does work for some of the camburg trucks. and he said he could easily they them 5* of caster. apparently those UCA's are super tuner status!
    hoping i can get at least 2.5 out of mine.
  11. Nov 18, 2014 at 1:02 PM
    MPLS TACO
    CHad
    MN
    TRD Sport
    Does anything else hinder the caster being higher? When I had mine aligned I told the to get it to 3 and they claimed the highest they could get it was 2.5? I hate to pay for another alignment but I sure would like it if it was higher it makes the truck feel like its on rails LOVE it.
