Alignment Cost
Discussion in '2nd Gen. Tacomas (2005-2015)' started by descartesairplnne, Apr 26, 2017.
  1. Apr 26, 2017 at 10:08 AM
    descartesairplnne
    descartesairplnne [OP] Well-Known Member
    Justin
    Truckee CA
    2014 Tacoma TRD
    redneck pinstriping, various stickers, not 1 but 2 glade air fresheners because I fart a lot.
    So I just paid $183 for an alignment at 4Wheel Parts in Reno NV. Typically I'd pay around $70 but I have the LR-UCA's and nobody but $Wheel Parts will even touch them. Is this typical? I've never had my truck aligned before so I haven't got a clue as to cost.
    JimboAnz likes this.
  2. Apr 26, 2017 at 10:09 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    what kind of numbers you get ?
  3. Apr 26, 2017 at 10:11 AM
    descartesairplnne
    Justin
    Truckee CA
    2014 Tacoma TRD
    Dunno yet. I just made the appointment and had to pre-pay. Its not going to be aligned till May 04. Our local tire shop here in Tahoe won't do it due to "liability concerns"
    JimboAnz[QUOTED] likes this.
  4. Apr 26, 2017 at 10:12 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Ive had a real difficult time getting anyone to mess with the LR UCAs top adjustment. If they were able to set them up right, I would say OK. should be nothing but little tweeks from here on out
  5. Apr 26, 2017 at 10:12 AM
    irish_11
    irish_11 Well-Known Member
    Everett, WA
    2011 DCSB
    Just keep throwin' money at it.
    Sounds about right. Firestone does lifetimes alignments for $200-ish
    Whitetrash and Mike likes Tacos like this.
  6. Apr 26, 2017 at 10:12 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    might be a little high priced but if its done right then its worth it if no one else has the knowledge to do it...
  7. Apr 26, 2017 at 10:14 AM
    Dimestore55
    Dimestore55 Well-Known Member
    William
    Richmond, VA
    2007 TRD OR Prerunner DCSB
    I paid $75 to a local 4x4 shop with UCA's. They seemed to know what was up.
  8. Apr 26, 2017 at 10:14 AM
    descartesairplnne
    Justin
    Truckee CA
    2014 Tacoma TRD
    Great point. I've read all about the initial adjustments and I set the lower camber lobe at a neutral position per the UCA website so I'm hoping the next time I can just tell them to adjust the lower.
  9. Apr 26, 2017 at 10:15 AM
    descartesairplnne
    Justin
    Truckee CA
    2014 Tacoma TRD
    Ya I've noticed TW has proper shops for you southern boys. We seem to make all the shit here in CA but refuse to work on it. I live at the foot of the Rubicon trail and you'd think at least one shop would have a clue.
  10. Apr 26, 2017 at 10:16 AM
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    Price sounds right for what the shops charge around me with adjusting the LR UCA's. I bought the lifetime alignment from firestone pre-lift and cant get them to adjust the UCA's without paying for a custom alignment which runs around $180.
  11. Apr 26, 2017 at 10:18 AM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    I just made an appointment to get mine done tomorrow. I did put on JBA UCAs which are not adjustable so that may keep my cost down compared to the LR UCAs.
    I'll report back tomorrow, but if I remember this same shop charged me about $100 after I did the 5100s at 1.75 about a year ago.
  12. Apr 26, 2017 at 10:19 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    same here. FS to me is a quick tweek, toe and go. I may have 4wp do mine some day. my caster is 2.0 and 2.5. not great, but not horrible.
  13. Apr 26, 2017 at 10:25 AM
    descartesairplnne
    Justin
    Truckee CA
    2014 Tacoma TRD
    They guy that builds a diy alignment solution and sells it to "hazard fraught" is going to be a billionaire.
  14. Apr 26, 2017 at 10:28 AM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    I paid $68, for a front alignment, with LR's....way out of alignment too, cause I replaced my inner/outer tie rods.
    Sucks, what ya'll out there in California have to go through, price-wise.
  15. Apr 26, 2017 at 10:29 AM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    OP this is so interesting that the aftermarket UCAs raised the price of an alignment by more than double where you live. Pretty much every place I called for a quote had no problem that I'm running LR UCA's and actually appreciated that they had the ability to adjust them and really dial in the numbers. They game me the same price as a bone stock vehicle ($70).
    descartesairplnne[OP] likes this.
  16. Apr 27, 2017 at 6:57 AM
    Chase8059
    Chase
    ESVA
    Just paid $89 for my alignment.
  17. Apr 27, 2017 at 7:21 AM
    justdoit
    justdoit Well-Known Member
    Colorado Springs
    22' 4x4 AC TRD Off-Road
    I paid $100 with SPC LR UCA
  18. Apr 27, 2017 at 7:42 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I have a lifetime alignment from Firestone. My bros there do (did, truck leaves my ownership today) my Ford with a lift and new UCAs without any additional charge. They promise to do the same on the Taco.
    The lifetime cost me $130 I think
  19. Apr 27, 2017 at 8:00 AM
    descartesairplnne
    Justin
    Truckee CA
    2014 Tacoma TRD
    Good to know. What state RU in?
  20. Apr 27, 2017 at 8:22 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Spent 90 on an alignment at a PROPER alignment shop. guy has been in business for like 30 years doing JUST alignments and front end rebuilds. he knew his shit.
    For anyone with SPC UCA's what i recommend is to put the ball joint at the center position (+2* caster) and slide the bitch ALL the way to the outer edge of the arm. Then take it to get it aligned. Tell the tech not to mess with the UCA adjustment and give him 2.5-3* of caster and -0.2* to -0.4* of camber. If they come back and cant get that, move the balls inward yourself by 3/8ths of an inch.
