Alignment During/After Center Support & U-Joint replacement?
Discussion in '1st Gen. Tacomas (1995-2004)' started by alpentolic, Sep 25, 2017.
  1. Sep 25, 2017 at 10:56 AM
    alpentolic
    alpentolic [OP] Member
    2000 Tacoma SR5
    I'm replacing my center support bearing and drive shaft u-joints in my 2000 V6. Not sure if the u-joints are bad but I know they haven't been greased in many years and the carrier bearing rubber is completely shot.
    If I mark with paint the alignment of the shaft, should I technically be able to reinstall without issue? Hoping to not take this in to a shop. Thanks!
  2. Sep 25, 2017 at 10:58 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Yep, just make sure the center bearing is lined up correctly.
    scottalot likes this.
