Alignment Gods Hear My Prayer...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by obz, Mar 28, 2017.
  1. Mar 28, 2017 at 5:56 PM
    obz
    obz [OP] Well-Known Member
    Utah
    2017 Silver Sky TRD Sport 4x4
    Just got back from an "attempted" alignment with Toyota. Mounting and balancing the new tires/wheels was DIRT cheap so I figured I'd have them do my alignment too. They got the camber and toe spot on, but told me "Caster can't be adjusted." What the? The truck is TOTALLY rubbing on the back of my wheel well at 1/2 turn of the wheel. Not great. It's SUPER obvious those wheels sit SUPER far back on the wheel well when pointed straight ahead. I've read and it seems the dealership are a bunch of idiots and have NO idea what they're talking about. I've got a set of Kings and Total Chaos UCA's so I thought I'd have all the adjustability in the world. Thoughts??
  2. Mar 28, 2017 at 6:04 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Lot of questions. What size lift if any, UCAs or no? Tire and wheel combo/size backspacing etc.
    shakerhood and Kyitty like this.
  3. Mar 28, 2017 at 6:16 PM
    obz
    Utah
    King 2.5 lift running at about 3" of lift in front with Total Chaos UCA's. Running BFG KO2's 285/70/R17's with SCS Ray10's - 4.30" backspacing. Other people are running similar setups with little rubbing compared to my INSANE amounts of rubbing. Confirmed they did not mess with the caster at all. Was 3.3 and 3.7 before they did any adjustments and was exactly the same after - no change. Description says "couldn't adjust caster because of lift." No additional detail. I'm pretty sure they adjusted the alignment prior to the tires and wheels (I had forgotten to give them the lugs).
  4. Mar 28, 2017 at 6:26 PM
    smitty99
    Scottsdale
    So they didn't adjust your caster. Take it back or take it somewhere where they are more competent. Firestone lifetime alignment is about $180. Well worth it too
  5. Mar 28, 2017 at 6:31 PM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    SCS ray 10's are -10 offset if I remember correctly. 0 offset would be better. The -1 pushes the tire further out from the truck. Wider stance looks bag ass but increases the likelihood of rub. I also believe that the alignment tech is full of shit.
    smitty99 likes this.
  6. Mar 28, 2017 at 7:33 PM
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    Alignment aside, you are going to need to trim with those tires and wheels, I promise.
    A lot of places these days are spouting that same story about caster and lifts, I had a firestone say the same thing.
  7. Mar 28, 2017 at 7:39 PM
    obz
    Utah
    I expected some rub at a further lock, not after a quarter turn of the wheel. Honestly it's SUPER stuffed in there. The side that has caster closer to 3 rubs significantly less. Hopefully another alignment at another place will address the issue.
  8. Mar 28, 2017 at 7:43 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Over 3* caster and still rubbing? Sorry time to cut...the more caster you have the less rubbing you get.....doubt you will get much more caster
    BudMan and tetten like this.
  9. Mar 28, 2017 at 7:44 PM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    3.3 and 3.7? Uhhh something isn't adding up.
  10. Mar 28, 2017 at 7:45 PM
    anthony250f
    Anthony
    San Diego, CA
    Lol I'm at 3.2 and 1.1....must be bent spindle
  11. Mar 28, 2017 at 7:45 PM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    Yeah I have 3.5/3.9 caster with ray10s and 285/70r17s, any more I was rubbing a bit on the front at full lock. The offset on these wheels put the corners right in the fenders. I'd also expect you will need a CMC if you don't already.
  12. Mar 28, 2017 at 7:46 PM
    tetten
    Andy
    Socal
    Did you find the time to swap out the LCA?
  13. Mar 28, 2017 at 7:47 PM
    anthony250f
    Anthony
    San Diego, CA
    Not yet...I'm gonna run it for a few months while I get new spindles and gusset them. I have to do cam tab gussets too...I honestly think it's the spindles. I don't think the LCA would cause this issue
    tetten[QUOTED] likes this.
  14. Mar 28, 2017 at 7:49 PM
    obz
    Utah
    I can't even turn the wheels to full lock at all. I'm okay with a CMC or fender trimming but I'd like to be able to turn the wheels a little bit.
  15. Mar 28, 2017 at 7:51 PM
    tetten
    Andy
    Socal
    You cannot get much more caster than that with stock geometry control arms.
  16. Mar 28, 2017 at 7:53 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    That's a shit ton of caster.
    You definitely need to trim and do the CMC. Even my 255/85/16's required a little trimming and like 2.7 Caster to prevent rubbing. No CMC though.
  17. Mar 28, 2017 at 8:04 PM
    0210
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    It sounds like the alignment numbers are just fine. If you want 285s, you need to get rid of mud flaps, trim the inner wheel-well liner, and do a cab mount chop. Know before you buy.
    Kyitty and friendlywithbears like this.
  18. Mar 28, 2017 at 8:13 PM
    anthony250f
    Anthony
    San Diego, CA
    Do I have to trim the fenders to run 35s. What about the mud flaps?
  19. Mar 28, 2017 at 8:55 PM
    obz
    Utah
    After looking at it a little more the side at 3.7 is barely rubbing at all and only at almost full lock against the cab mount. The 3.3 side is the one that's stuffed in there. It's hitting the inner fender well and the cab mount. I'm going to take it down to another alignment shop and see if they can eak out a little more caster. Again, I'm okay with a CMC but it'd be sweet to clear the fender well.
  20. Mar 28, 2017 at 8:57 PM
    tetten
    Andy
    Socal
    Before you go to an alignment shop, check your LCA cam bolts, if the caster bolt is maxed out you are unlikely to get more out of it without throwing camber out of spec.
