Alignment Guru's Help Please
Discussion in '2nd Gen. Tacomas (2005-2015)' started by papabear050, May 7, 2009.
  1. May 7, 2009 at 5:40 PM
    papabear050
    papabear050 [OP] Well-Known Member
    11 dc 4x4 TRD OR Auto
    I'm wandering to the left. I just put Bilsteins in all 4 Corners set at .85" of lift.
    I am running stock Dunlops 265/65R17 in my 2008 4x4 Sport
    Do these numbers look right or should I take it back. Any recommendations
    Camber Left: -.20
    Camber Right: -.57
    Caster Left: 1.35
    Caster Right: 1.27
    Toe Left: -.01
    Toe Right: -.02
    Cross Camber: .36
    Cross Caster: .08
    Total Toe: -.03
  2. May 7, 2009 at 5:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Your Caster is below spec, which will amplify any wandering you may have. The only way to correct that is with after market Upper Control Arms that have more caster built into them.
    I would have them re do it. Set the Camber closer to 0*. Toe is fine. If they re do it, have them keep it at 0*.
  3. May 7, 2009 at 8:27 PM
    papabear050
    Thanks Chris, will see if they can redo....
  4. May 7, 2009 at 8:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Keep me posted.
  5. May 7, 2009 at 8:30 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Hey chris what are the numbers suppose to be?
    Just curious as I will be doing mine some time in the near future.
  6. May 7, 2009 at 8:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Spec is
    Caster: 2.13* (+/- .75*)
    Camber: + .59* to -.75*
    Toe: + .077* to - .108*
    I have found that running the following is best on our trucks:
    Camber: 0*
    Toe: 0*
    Caster: 2.3* to 3.1* (most of the time, 2.8* or more can only be achiexed with aftermarket UCA's that add caster)
  7. May 7, 2009 at 9:04 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    I'll post up my specs for comparison since I have been very pleased with this setup.
    Camber
    L -.2*
    R .3*
    Caster
    L 3.9*
    R 4.0*
    Toe
    L .05*
    R .05*
    Total Toe
    .09*
    Steer Ahead
    0*
  8. May 7, 2009 at 9:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im guessing your truck is a 5 lugger?
  9. May 7, 2009 at 9:07 PM
    SC4333
    Grant
    FL
    6 lug PreRunner.
  10. May 7, 2009 at 9:07 PM
    98tacoma27
    Ben
    Not Beech Creek
    Dood, how can you tell?
  11. May 7, 2009 at 9:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I was guessing as his sig didnt mention any UCA's as a mod, and his Caster is WAY high.....
    How are you Caster numbers so high? Also, -.2* left Camber, and + .3* right sounds like they were trying to correct for something?
  12. May 7, 2009 at 9:17 PM
    98tacoma27
    Ben
    Not Beech Creek
    Attention to detail..........Ah
  13. May 7, 2009 at 9:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I'll try not to let it happen again........
  14. May 7, 2009 at 9:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Sc4333, with those Camber numbers, if looking at the truck from the front, your tires are like this:
  15. May 7, 2009 at 9:21 PM
    98tacoma27
    Ben
    Not Beech Creek
    By all means, please let it happen again........:D
  16. May 7, 2009 at 9:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  17. May 7, 2009 at 9:23 PM
    98tacoma27
    Ben
    Not Beech Creek
    I see the problem, the wheels are too skinny
  18. May 7, 2009 at 9:26 PM
    SC4333
    Grant
    FL
    Honestly, I am not sure how he managed to get the caster so high. I told the guy I would like the caster maximized and he got it quite a bit higher than I had expected. The camber was adjusted for the crown on highways, and to minimize pull.
    It drives great and the bump steer is much less noticeable.
    As for my setup, I used to have a Revtek kit on the front but recently took it off because of the harsh ride. Currently I am running stock UCAs w/ TRD off-road springs/struts. The truck has about 18k on it at the moment and everything in the front end is square.
  19. May 7, 2009 at 9:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok...Well...that explains some things. The front may "look" square, but with those numbers, its not. If you mostly drive on the highway, it might be fine, but if your driveng is 50% city, your gonna have some wierd tire wear on the fronts. And with th eCaster numbers, I can only imagine how funky the cam adjusters are. :confused: Glad to hear its working for ya. I never recomend going out of spec., and I have found a "Square" alignment is the best for our trucks.
  20. May 7, 2009 at 9:33 PM
    SC4333
    Grant
    FL
    If I remember correctly, Its the other way around, but it is not very pronounced at all. To the point where it is very hard to tell.
    I'll post a picture up tomorrow if I get a chance.
