alignment help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nwb3160, Apr 13, 2012.
  1. Apr 13, 2012 at 7:57 AM
    nwb3160
    nwb3160 [OP] Well-Known Member
    Nick
    Cartersville, Ga
    2008 Tacoma TRD Sport
    5100s OME 885 2009 tail lights 6000K HID Pioneer 4400 DVD Viper Alarm/Remote Start Avid Offroad Bar/Side Steps Wet Okole Seat Covers Husky Floor Mats Toyo Open Country MT 265/70R17 BANKS Monster Exhaust Ultraguage
    put my 5100 and OME coils on and adjusted the lower control arms, after that the truck had to be towed to an alignment shop and the alignment shop said they won't touch it because there's something other than an alignment wrong with the truck and Toyota said between 3 and 500 dollars to fix it, I dont know what to do
  2. Apr 13, 2012 at 8:05 AM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    Could you explain more on the adjustment to the lower control arm and why it needed to be towed to an alignment shop. Was the truck not drivible?
  3. Apr 13, 2012 at 8:21 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Are the alignment cams seized ? That's a fairly common problem
  4. Apr 13, 2012 at 8:24 AM
    medic2230
    Murph
    Bama! Roll Tide
    Why couldn't you drive it? What did you adjust on the LCA's? Pics?
  5. Apr 13, 2012 at 8:26 AM
    BradyT88
    BradyT88 Well-Known Member
    I just put OME coils on my 5100's last weekend by myself and had no problems. I also put LR UCA's on with the new coils though. I didnt play with the lower control arms, so like was said above. You need to elaborate more. Some pics maybe?
  6. Apr 13, 2012 at 8:27 AM
    medic2230
    Murph
    Bama! Roll Tide
    I put OME lift on the front last night and only thing I need to go back and adjust is the LR UCA to level the tire a little to go get the alignment. Mine are tilted out at the top.
  7. Apr 13, 2012 at 8:39 AM
    nwb3160
    Nick
    Cartersville, Ga
    I took a pry bar and moved the lower control arms out and adjusted the lower control arms according to my friends 4wd truck however mine is a 2wd and the tires were fighting each other so bad I couldn't drive it
  8. Apr 13, 2012 at 8:40 AM
    nwb3160
    Nick
    Cartersville, Ga
    my front right tire is turned in app 2 inches, when I went to turn the truck would automatically force the truck to make a complete turn
  9. Apr 13, 2012 at 8:54 AM
    OZ-T
    Peter North
    British Columbia
  10. Apr 13, 2012 at 10:09 AM
    medic2230
    Murph
    Bama! Roll Tide
    Every truck is different. You can't adjust one to what another truck is set to. If that was the case, we wouldn't ever need an alignment shop. It's easier to just mark the alignment cams with something where they are sitting before the lift and then you can loosen them to get the shocks in and put them back in the approximate area to get to the alignment shop. Or leave them alone and see if you can get them in without loosening the cams. Are you using new UCA's?
