Alignment help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UGAFAN, Nov 21, 2013.
  1. Nov 21, 2013 at 1:12 PM
    UGAFAN
    UGAFAN [OP] Well-Known Member
    George
    Atlanta, GA
    2021 TRD Off-Road
    TRD lift and 33’s.
    Guys,
    I have a 2012 prerunner with 5100s on it set at 2.5" lift. Here are my alignment specs from Firestone. It seems to drive great, but the alignment specs I've seen posted on here make these seem way out of whack. I've read 0 camber, 0 toe, and 2.4 caster and I know I'm not going to get that with a lift and stock ucas, but should I expect better than this? Thanks for any help in advance.
    George
    Sorry for the sideways picture...don't know how to fix.
  2. Nov 21, 2013 at 1:19 PM
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    They can bring that caster up a little more
    Edit: And lower your camber.
  3. Nov 21, 2013 at 1:20 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    sounds spot on, you could add a bit more caster and it will track much better and help with the bump steer, otherwise you are perfect...
  4. Nov 21, 2013 at 4:55 PM
    UGAFAN
    George
    Atlanta, GA
    2021 TRD Off-Road
    TRD lift and 33’s.
    Is it a trade off between caster/camber? For example, if I tell them to give me more caster, will the camber go more out of whack?
  5. Nov 21, 2013 at 5:00 PM
    JRFugitt
    JRFugitt Well-Known Member
    Justin
    Texas
    '13 PreRunner V6
    No increasing caster should drop the camber down some. Unless you are totally maxxed on your adjustments.... if you are, drop those shocks to 1.5 or whatever the next spot is to gain some adjustment. Safety of the vehicle handling and excessive tire wear(expensive) are more important than how the truck looks! IMO
  6. Nov 21, 2013 at 5:00 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    I'd say that is far from spot on or perfect. Ideally you should look for Camber/ Toe at 0 and Caster as close to 2.4 as possible. Too much positive Camber, not nearly enough Caster, Toe is close. I'd be having them realign it for sure.
  7. Nov 21, 2013 at 5:06 PM
    UGAFAN
    George
    Atlanta, GA
    2021 TRD Off-Road
    TRD lift and 33’s.
    It doesn't wander at all, and I've had it up to about 80mph. Feels just as steady as it should. I'm mainly worried about tire wear, and also the fact that I should get a good (in spec) alignment for what I paid.
  8. Nov 21, 2013 at 5:16 PM
    JRFugitt
    Justin
    Texas
    '13 PreRunner V6
    MOST techs just get it in spec and not worry about marking it up. Me, I personally align it to what the vehicle is used for and the tendancies/flaws the vehicle design has in it. Try to find an independent shop with a very busy alignment tech. Ask to see the screen before the vehicle is unhooked and tell them what you want beforehand.
  9. Nov 22, 2013 at 9:04 AM
    UGAFAN
    George
    Atlanta, GA
    2021 TRD Off-Road
    TRD lift and 33’s.
    Update: just got finished at Firestone, and I'm MUCH happier. Here are the new specs for my Prerunner with 5100s set to 2.5". Thanks again for everyone's help. It drives so much better.
    George
  10. Nov 22, 2013 at 9:37 AM
    JRFugitt
    Justin
    Texas
    '13 PreRunner V6
    no prob, welcome!
  11. Nov 22, 2013 at 10:29 AM
    TRSJimmy
    Jimmy
    Gainesville, GA
    :thumbsup:
