Alignment help
Discussion in 'Suspension' started by Rickym72, Oct 15, 2024.
  1. Oct 18, 2024 at 5:12 PM
    Rickym72
    Rickym72 [OP] Well-Known Member
    2023 Tacoma TRD OR 4X4
    Yeah, I was having a discussion with them for about 30 min about the thrust being off and rear toe too.
    They said you can’t adjust it if it’s on the spring perch torqued down. They checked all the suspension components for a bad install and couldn’t find any.
    They dropped the axle and and reinstalled it again so maybe that plus the alignment check helped.
    Toyota could NOT get it to track straight.
  2. Oct 18, 2024 at 10:22 PM
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    Yeah you can get adjustment to make the numbers work with the play on the rear but they'll be out in a few hundred miles once it re-settles. Dealerships are worthless part swappers these days. It was heading that way when I left the industry and it's only grown worse so if you need an alignment or suspension work, you gotta find an old school shop.
