Alignment help...
Discussion in 'Suspension' started by Oskie_78, Apr 18, 2010.
  1. Apr 18, 2010 at 3:59 PM
    Oskie_78
    Oskie_78 [OP] Well-Known Member
    Texas
    1998 4Runner, 2016 4Runner, 2023 Tacoma
    I got my lift and wheels on now and got my alignment done just recently. I've been reading up on here a lot about alignments and I'm not sure if my alignment specs are correct. Can some of you guys chime in and help me out on this?
    I've read it's suppose to be...
    Camber 0*
    Toe 0*
    Caster 2.4*
    The manager at Firestone said they couldn't get to those specs. What can I do to get this correct? I have light race UCA's, are they suppose to adjust the UCA's?
    I have 2.5 lift up front and tire size is 285/70/17.
    here are the specs...
  2. Apr 18, 2010 at 4:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    When you installed the UCA's, did you set the ball joint to the 2* + setting?
  3. Apr 18, 2010 at 5:13 PM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
    I set my caster to 2.5...Camber to .4 and toe to whatever Factory specs are...trucks drive like a champ.
  4. Apr 18, 2010 at 5:17 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x2...i made the mistake of installing the ball joints backwards and my alignment was all sorts of messed up. Make sure the SPC Logo is facing you when your looking at it installed. You'll want the rounded edge of the ball joint plate facing the truck w/ SPC facing you (or the tire)
  5. Apr 18, 2010 at 5:19 PM
    ColtsTRD
    Scott
    AZ
    Toe - 0
    Camber - 0
    Caster - 2.4+ to 2.8+
  6. Apr 18, 2010 at 5:39 PM
    Oskie_78
    Texas
    I'm not to sure. How can I found out?
  7. Apr 18, 2010 at 5:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :cool:
  8. Apr 18, 2010 at 6:08 PM
    Oskie_78
    Texas
    The truck does drives perfectly straight. It just feels like when I hit some bumps and crown on the road the steering feels little loose.
  9. Apr 18, 2010 at 8:18 PM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    I wouldn't worry about it at all. It's going to steer way better with the caster where it's at, ant you won't get any rubbing on the body mounts either.
  10. Apr 19, 2010 at 10:28 AM
    Oskie_78
    Texas
    So I can leave it were the specs are at?
    would my tires still wear out evenly? that's what I really worry about.
    I just thought the alignment specs HAD to be set at...
    Camber 0*
    Toe 0*
    Caster 2.4*-2.8+
    Like I said before, the truck does drives perfectly straight. It just kinda feels wiggly on the crown on the highways and bumps, Not real bad, but it does kinda bother me. Can the caster help that?
  11. Apr 19, 2010 at 10:31 AM
    drew02a
    San Antonio, TX
    The Camber and Toe are pretty important. If those aren't right, the tires will wear out really quick. The caster doesn't matter as much.
  12. Apr 27, 2010 at 2:45 PM
    Oskie_78
    Texas
    ok, back again... I've notice the SPC is facing towards the rear of the truck on both the drivers side and passenger side.
    passenger side
    drivers side
    How do I adjust this?
  13. Apr 27, 2010 at 2:46 PM
    Oskie_78
    Texas
    Do I just loosen the bolt on top?
    Is it bad if the SPC is not facing the tire?
    :help::help::help:
  14. Apr 27, 2010 at 4:28 PM
    Oskie_78
    Texas
    so it that why I couldn't get my alignment right to specs because the ball joints are not placed properly?
  15. Apr 27, 2010 at 4:35 PM
    drew02a
    San Antonio, TX
    Yes that is why your specs aren't "right on", but it will steer a hell of a lot better the way you have is set now.
    If you have a big enough socket, you can just loosen up the bolt on top and reposition the joint while the UCA is on the truck.
  16. Apr 27, 2010 at 4:35 PM
    drew02a
    San Antonio, TX
    Also, you'll have less rubbing the way it is set now.
  17. Apr 29, 2010 at 10:38 AM
    Oskie_78
    Texas
    hey Drew, my ride right now feels ok, but I think it could be better. It has some slight bump seer that starting to bother me that's why I'm thinking of moving the ball joint.
    If I face the SPC at me it well set it a 2*+ correct?
  18. Apr 29, 2010 at 11:54 AM
    drew02a
    San Antonio, TX
    What are you shooting for, factory caster?
  19. Apr 29, 2010 at 12:04 PM
    Oskie_78
    Texas
    I want to see if I move the ball joint face me if that would help out on the bump steer and get it all things to specs....I thought have the UCA's installed would help out with all that. It drives straight, I just want the bump steer gone and I do rub the body mount right now too but only in reverse with wheel turn all the way. :confused:
  20. Apr 29, 2010 at 12:07 PM
    drew02a
    San Antonio, TX
    If it rubs now, it will rub WAY worse, once you move the joint further back. You'll just have to decide which you want to live with: Bump Steer or Rubbing.
    Making the SPI face out towards you and positioning the joint as far out on the A arm as possible should give you factory caster.
