Alignment.. how bad is it? :/
Discussion in '2nd Gen. Tacomas (2005-2015)' started by timbobzimbob, Apr 14, 2016.
  1. Nov 14, 2016 at 12:10 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    You'll get so many different answers. Some say 0 is best, others say you want .5° positive camber. In my opinion anywhere between 0 and .5° is good. The LR arms have PLENTY of room to deduct camber so that's definitely not the issue.
    timbobzimbob[OP] likes this.
  2. Nov 14, 2016 at 12:12 PM
    timbobzimbob
    timbobzimbob [OP] Well-Known Member
    Tim
    Ottawa, Ontario
    05 DCLB 4x4
    so .8° is too much then? I might take it back to them and have them lower it then
  3. Nov 14, 2016 at 12:14 PM
    Justinlhc
    It's not what I would personally want. You *might* notice some wear on the outside of the tires after a long while. Technically it is within spec though.
  4. Nov 14, 2016 at 1:02 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    first off....you do not want any positive camber unless you dont like the outside of your tires tread....
    0 or negative (top of the tire in to centerline compared to bottom) only. Preferred ~ 0.2 to 0.4* of negative camber for even tire wear.
    next, the tech who did that alignment... take it back, if he cant get negative camber out of spc arms hes an idiot.
  5. Nov 14, 2016 at 2:44 PM
    Justinlhc
    If a few tenths of a degree of positive camber will eat the outside of the tires than a few tenths of negative camber will eat the inside of the tires just the same.
    0 camber would be great for perfectly even tire wear if you never had to turn.
    '14RC likes this.
