Alignment How to
Discussion in 'Technical Chat' started by wilsonpj, Sep 4, 2010.
  1. Sep 4, 2010 at 4:59 PM
    wilsonpj
    wilsonpj [OP] Well-Known Member
    Pete
    Charleston, South Carolina
    2006 DC, SB, OR
    OME 3in Lift, LR UCA's, 33in DuraTracs, All-Pro Full Skids, TRD CAI & Cat Back, 16x8 KMC Enduros
    Any one have a write up or know how to manually adjust the alignment on a 2nd gen, specifically with LR ucas? I need to adjust the Toe, it is sitting out a bit at the moment.
  2. Sep 4, 2010 at 5:16 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Take it to a shop with the appropriate tools to do alignments??
    You don't really wanna just eyeball stuff like that.
  3. Sep 4, 2010 at 5:17 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x2...
  4. Sep 4, 2010 at 5:30 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
  5. Sep 4, 2010 at 5:35 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    if you wanted to do the toe then you would have to loosen the top nut on the ball joint and slide it in or out
    you will still need a shop to finish the alingment correctly
    also the ball joint on the l.r. rotates 360 for adjustment
  6. Sep 4, 2010 at 5:44 PM
    wilsonpj
    Pete
    2006 DC, SB, OR
    I think that adjusts camber. I think you have to adjust the tie rod for toe...?
