Alignment in spec?
Discussion in 'Suspension' started by baodown, Jan 13, 2022.
  1. Jan 13, 2022 at 5:06 PM
    baodown
    baodown [OP] Well-Known Member
    13 DCSB 09 600RR 15 Aprilia RSV4
    I had my LCAs replaced with Moogs and the alignment tech at a different shop said my toe adjustment is maxed out. Truck is pulling to the right and my steering wheel is cocked to the left a bit. Just hoping that my alignment is within spec to avoid premature tire wear. Thank you
  2. Jan 13, 2022 at 5:36 PM
    su.b.rat
    su.b.rat broken truck
    pretty crappy. i would get it redone.
  3. Jan 13, 2022 at 6:30 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Is this a stock truck?
  4. Jan 13, 2022 at 6:40 PM
    baodown
    feels crappy. Will do
  5. Jan 13, 2022 at 6:41 PM
    baodown
    3” lift with 285s
  6. Jan 13, 2022 at 6:43 PM
    gotoman1969
    Did replace the uca or the lca?your post says lca?
  7. Jan 13, 2022 at 6:49 PM
    gotoman1969
    Do you have aftermarket ucas?
  8. Jan 13, 2022 at 7:04 PM
    baodown
    I replaced lower control arms. My upper control arms are SPC
  9. Jan 13, 2022 at 7:05 PM
    gotoman1969
    Then, yes that alignment sucks.
  10. Jan 14, 2022 at 4:24 PM
    baodown
    Took my truck to a reputable shop for a proper alignment. Drives perfect now!
    gotoman1969 and su.b.rat like this.
