Alignment inquiry
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Netman, May 12, 2020.
  1. May 12, 2020 at 9:26 PM
    Netman
    Netman [OP] Well-Known Member
    Bill
    2017 TRD Sport
    I have an appointment tomorrow for an alignment and have a question. My 2017 has the 887/5100 front set up, an add a leaf in the rear and stock control arms. I’m running 285/70/17 with Ray 10’s. I do virtually no off-roading other than the odd logging road fishing trip.
    With what I’ve read, I should be trying to get as close to 0 as possible for camber and toe, and around 2.7ish for caster, does that sound correct? With the current alignment I’m getting some bump steer and wondering from the grooves in the roads. I’d like to eliminate those issues as much as possible without getting new control arms if I can. If that’s not possible, I’ll go the new control arms. Thanks.
  2. May 12, 2020 at 10:10 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Tell me you aren’t going to a dealer. What you need is a front end shop that works on modded vehicles. If they are good they’ll know how to set up your front end.
    If they say new arms get them. A bad alignment will not only be expensive but down right dangerous.
  3. May 12, 2020 at 10:19 PM
    Netman
    Bill
    2017 TRD Sport
    No dealer, an independent front end shop.
