Alignment issue after 5100s @1.75"
Discussion in 'Suspension' started by SpeedStar, Jun 18, 2012.
  1. Jun 18, 2012 at 6:19 AM
    SpeedStar
    SpeedStar [OP] Active Member
    Chula Vista,Ca
    2012 PreRunner DCSB TRD Sport
    5100s at 1.75", rear 4pack.
    I have a 2012 DCSB Shortbed and put 5100s on at 1.75" setting over the weekend. The rear already had the 4 pack leaf and the stock Billies. Sits nice and level now.
    I went to get the alignment thinking there would not be an issue at this setting and the supposedly reputable shop told me they could not get it on the rack for the computerized alignment but not to worry, they would get it dialed in the traditional way. I figured they knew what they were talking about so went ahead.
    When he was finished, he said he was out of adjustment and could not get it perfect. The Camber was at 0 with the Castor at .25 - .5 He said it would be good.
    It was the end of the day and they were closing so I left and though I was done. Here are the issues:
    1) Turns out the steering wheel is not straight, slightly left when going straight.
    2) Pulls slightly left.
    3) After making a turn, it wants to keep turning instead of letting the wheel go and recentering.
    Are they full of crap? These should not be like this right? What do you guys think?
  2. Jun 18, 2012 at 10:50 AM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    Take it back to them and have them correct it.
  3. Jun 18, 2012 at 10:53 AM
    cgs2k2
    cgs2k2 Ohio Member
    This. let em keep trying
  4. Jun 18, 2012 at 10:55 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah just take it back and tell them what you told us, if its a descent shop they will fix it for you without any questions.
  5. Jun 18, 2012 at 10:57 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+295k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED), 2006 F350 King Ranch 6.0L
    Make sure they can get it on the rack this time
  6. Jun 18, 2012 at 11:10 AM
    SpeedStar
    Chula Vista,Ca
    I am going to get them to look at it again.
    Is there an accepted target range that it should be within?
    I would rather here from owners here that know instead of whatever the shop feels like passing along.
    Thanks for the help.
  7. Jun 18, 2012 at 11:12 AM
    98tacoma27
    Ben
    Beech Creek
    0° toe, 0° camber, and around 2.4° caster.
  8. Jun 18, 2012 at 11:29 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    You will have a hard time getting enough caster after the lift without going to UCA's to get you more caster.
    There is not enough factory adjustment when you lift it.
    That said the steering wheel can be set straight by a good alignment place.
    Without the proper caster it will be a bit darty on freeways.
