Alignment issue... seized LCA bushings???
Discussion in 'Suspension' started by wmflyfisher, May 21, 2013.
  1. May 21, 2013 at 10:31 AM
    wmflyfisher
    wmflyfisher [OP] Well-Known Member
    Wes
    PCB, FL
    2010 Sport 4x4
    I had my 5100's installed a couple of months ago along with an alignment. The spec sheet that I was giving showed all of the tolerances in the "green". I didn't pay much attention to it. Ever since it has always looked as if my front tires were tilted in (causing the outside edges to ware over time if it was an issue). Well over the past 2 months I've noticed very slight ware on the outside edges of the front tires.
    I took my truck to a different pretty reputable alignment shop this morning and they said that the lower control arm bushings are seized so they were unable to adjust them. They didn't have a printout because they don't use the nicer machines that everybody uses these days. They use traditional methods to align vehicles.
    Could their problem in aligning be from my lift alone and all I need is new UCA's?? I'm pretty frustrated at this point. Any help would be greatly appreciated.
  2. May 21, 2013 at 10:59 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Seized LCA cam bolts is a pretty common problem
  3. May 21, 2013 at 11:01 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    yup had to cut mine out
  4. May 21, 2013 at 11:19 AM
    wmflyfisher
    Wes
    PCB, FL
    2010 Sport 4x4
    Damn it man. Ill have to look at it further. What causes this? It's a 2010!
  5. May 21, 2013 at 11:24 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Spray them down really good, in behind by the bushing and all over with some HD Silicone spray. Do that every day for a week. Hopefully will work its way in there an loosen things up.
  6. May 21, 2013 at 11:33 AM
    OZ-T
    Peter North
    British Columbia
    rust
  7. May 21, 2013 at 11:46 AM
    wmflyfisher
    Wes
    PCB, FL
    2010 Sport 4x4
    Thanks. Did you have to do both the right and left side?
  8. May 21, 2013 at 11:47 AM
    OZ-T
    Peter North
    British Columbia
  9. May 21, 2013 at 11:52 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The root cause of this is Toyota being really f-in lazy and doing anything they can to save a few pennies. This negligence leads to parts rusting together and having to get cut out rather than able to be adjusted like they were intended. Yes, I'm a little bitter because this is an easily avoided issue if Toyota could have been bothered to put a dab of grease or neverseize when things were put together :mad:
  10. May 21, 2013 at 11:58 AM
    Pugga
    Massachusetts
    If you're still under warranty, I'd fight to make Toyota fix it.
  11. May 21, 2013 at 12:19 PM
    wmflyfisher
    Wes
    PCB, FL
    2010 Sport 4x4
    Thanks for the support guys. Is there a way for me to see exactly which ones are seized before I have to rip each LCA off each side?
  12. May 21, 2013 at 12:22 PM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    You won't be able to turn the seized ones.
  13. May 21, 2013 at 12:24 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    Loosen The bolts and try to turn them as stated above. I had all four of mine seized on my 2000 Tacoma. When I replaced them I slathered grease on the bolts and alignment cams and inside the bushings. No problems since and that was 2 years ago.
  14. May 21, 2013 at 12:25 PM
    Pugga
    Massachusetts
    Well yeah, you have a little more work done than the average bear :laugh:
    Try to spin the LCA bolts inside the bushings. Mark from the cam to the frame so you can set your alignment back to somewhat normal. If you can't spin the bolt inside the bushing, it's rusted together. Try Dan's method, spray with penetrating oil every day for a couple weeks and try to work them free. If they free up, great, if not, well get out your Sawzall and practice your 4 letter words :)
  15. May 30, 2013 at 11:02 AM
    disc0monkey
    disc0monkey All right. I believe ya. But my Tommy Gun don't!
    So I'm going to an alignment next week. Can I pull my alignment cams without taking out the lower control arm to put anti seize?
  16. May 30, 2013 at 11:04 AM
    Pugga
    Massachusetts
    If it's not seized, yes. You'll need to support the front end of the truck and make sure you're at full droop, mark the cam locations from the tab to the frame, pull the bolts, put neverseize on them, and reinstall everything. Do it one bolt at a time and you won't have to take the LCA off.
  17. May 30, 2013 at 11:11 AM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    ^^^ What he said :)
    If the cams aren't already seized. Mark them on the frame, loosen, pull it out, glob on the lube, slid them back in, realign the marks, and torque.
  18. May 30, 2013 at 11:13 AM
    disc0monkey
    absolutely sounds like its worth the effort. thanks guys
  19. May 30, 2013 at 11:15 AM
    YOTA LOVER
    NH
    First thing I did after the lift was installed and before the alignment shop. Truck only had 3k on it, but if you've ever had to deal with them being seized you'll never forget to lube first.
  20. May 30, 2013 at 11:20 AM
    disc0monkey
    yup im hoping they are not seized, the truck has been pretty good with rust so far. wish me luck.
