Alignment issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Trd28, May 24, 2021.
  1. Jun 5, 2021 at 9:31 AM
    SkyDivinTaco
    SkyDivinTaco Well-Known Member
    T.
    Oahu
    Silver 2004 OR Taco & Voodoo Blue 2021 OR Taco
    EXACT same thing after my dealer installed TRD lift on 2021 OR. They also provided alignment sheet with all numbers within spec. At first, I chalked it up to front needing to settle...it's been 3+ weeks and there really hasn't been any settling. Getting new rims/tires (17") installed today and will like return to dealer (or other reputable alignment location) to get a camber consult.
    Trd28[QUOTED][OP] likes this.
  2. Jun 6, 2021 at 9:48 AM
    ForeverWild
    ForeverWild Well-Known Member
    Chuck
    2021 Black Tacoma TRD Pro
    After lifting my 2021 TRD Pro, I had an alignment shop do an alignment. They said their printer didn’t work so there’s no proof of their “as left” readings. The truck drove fine but the camber was visibly WAY off. Similar to the picture the OP posted.
    I took it to another alignment shop. This is what their “as found” measurement below. The curious thing is that the only thing in spec was camber which was my primary complaint.
  3. Jun 6, 2021 at 10:17 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Wow that alignment :anonymous:
    ForeverWild[QUOTED] likes this.
  4. Jun 6, 2021 at 12:00 PM
    ForeverWild
    Chuck
    New Alignment complete. Caster was the only thing I couldn’t get in spec. I expected that.
    I had the tech place camber at +0.2 degree and place toe close to zero and let caster go to where it goes. We ended up with approximately +1.0 degree caster. Not bad for a stock uca.
    I plan to drive it for a bit to see if I want/need more caster. It drives just fine now and my front tire no longer has a visible camber issue the OP described.
    It’s interesting to me that there is a BIG visible difference between +0.9 camber and +0.2 camber. The picture below is my truck after alignment.
    71tattooguy likes this.
  5. Jun 6, 2021 at 12:03 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Caster though is way low. How does it drive on Highway? UCA’s help with caster as you know.
  6. Jun 6, 2021 at 12:48 PM
    ForeverWild
    Chuck
    +1.5 to +3.0 degree is the original factory spec. I’m only half a degree off. It drives fine with the current +1.0 degree caster although not as good as my merc and beemer. They run crazy high caster.
    71tattooguy[QUOTED] likes this.
  7. Jun 11, 2021 at 2:40 AM
    Trd28
    Trd28 [OP] Member
    2021 cement trd off-road
    I really regret it man I’ve been back there 3-4 times I’m getting a humming and vibration even after I tried a diff drop and ecg bearing its a mess I should have asked if they had experience installing it but I was the first at the dealership i was just the Guinea pig keeping the warranty sounded good but I wish I went with another suspension and have a off road shop take care of me
