Alignment issues after suspension rebuild & tie rod replacement. Help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by dalanis, Jun 1, 2024.
  1. Jun 9, 2024 at 10:31 PM
    dalanis
    dalanis [OP] Member
    Los Angeles, California
    2002 Tacoma Prerunner 3.4L
    Earlier in the post:
    Timeline
    05/29/23: Outer tie rods blew after putting on spidertrax 1.5" spacers. My understanding is that spacers do not affect alignment. I noticed that after I got an alignment done that I had very little threads left. Part numbers are below and here you can see the before and after:
    Part NumberPart NamePriceQuantityTotal
    While I do agree it is a bit premature and yes I need to install the correct PN LBJ's, I do not see any harm in excluding the possibility. The tie rods being maxed out was already an issue before changing ball joints. I'm just asking how someone could also visually inspect.
  2. Jun 9, 2024 at 10:52 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    It is almost impossible to visually inspect for a bent spindle. When they do bend it will be at the weakest spot, the right angle at the top of the spindle where the UBJ is mounted. I can't see how a bend in that location would effect the exposed thread count on both Otres. And it seems even more unlikely that both spindles would be bent equally.
    On the other hand, the location of the Otre mounting hole on the LBJ will directly determine where the Otre and Itre interface is.
    Madjik_Man likes this.
  3. Sep 15, 2025 at 1:22 AM
    tha_roost
    tha_roost TX YardBird
    Ry
    Deep East TX
    03 PreRunner CrewCab TRD SR5
    DIY Installations: • Pioneer DMH-W2770NEX Wireless AA Head Unit • OEM Cruise Control, CC Selector Lever Steering Column Mod & CC Stop Lamp Switch Swap • Drivers Power Window Control Reversal • TVIP Security System - New Remote Programming • Muffler Tip Upgrade • 2019 Tacoma Rims/Tire Swap • Reverse Bulbs LED Swap • Cloth Seats Reupholstered w/Med. Oak Leather Grain Vinyl DIY Repairs: • Collapsed OEM Tokiko Rear Shocks Replaced w/FOX 2.0 Shocks • Drivers Side Rear Axel (Seals, Bearings, ABS Tone Ring) • Differential (Flush, Breather & Drain Plugs) • Wheel Hub (Gaskets, Studs & Nuts) • Drum Rebuild (Backer Plate, Cylinders, Springs, Shoes, & Lines) • Parking Brake Calibration • Stop Lamp Switch Replacement • Drive Belts • Propeller Shaft Joints Greased • UV Dye Test Engine Oil Leak
    I am currently experiencing this exact same thing. 03 PreRunner DoubleCab 3.4L. I replaced both UBJs, LBJs, and Outer Tie Rods using all OEM Toyota parts with the correct part numbers for my truck. I did the same thing counting the threads and using a paint pen to mark the jam nut to the inner tie rod. I was very meticulous reassembling everything and torquing all of the fasteners to spec, yet when I test drove it the toe was way out of whack and no matter what Ive tried so far it doesn't want to seem to hold my adjustments. Wheels are squealing while driving above 5 mph almost like the wheels are fighting each other. I did everything by the book...literally even what it says to do for Toe adjustment in the FSM. I used digital calipers to adjust the inner tie rods until they're exactly the same length, but still the same result.
  4. Sep 15, 2025 at 3:41 AM
    THatt
    THatt Well-Known Member
    Upstate SC
    1996 Tacoma 2.7L MT 4X4
    Your new components are probably different than the old. Get your measurements to center front and back of the tire, close enough to drive, and then get an alignment. I did paint pen and measurements when I replaced my front end and it was different afterward. All OEM too. I guess I’m just saying don’t over think it.
