Alignment issues need help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rampage!67, Apr 25, 2023.
  1. Apr 27, 2023 at 5:26 AM
    H6G
    H6G Well-Known Member
    Far from home...
    ‘18 Blk. Pro/ ‘17 GT350
    '22 Pro suspension/ Custom Deaver springs/ ECGS and...
    BandanaBerg likes this.
  2. Apr 27, 2023 at 5:43 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I've seen that kit before or similar cam bolt setups. Someone posted in my build thread (IIRC) and said they were replacing it with the poly performance taco tabs because they could still spin if hit hard enough.
    I can try to find it but if you're not doing as much offroading, the KPO kit should work.
  3. Apr 27, 2023 at 5:51 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    I can’t imagine the KPO kit rotating in there. I’ve got them on my truck with the stock tabs and it seems pretty solid. I wonder how hard the person have to hit something to move it.
    Ive not done any off roading since I installed them but driving in MD and PA, I’ve hit some huge pot holes going faster than I’d like…
  4. Apr 27, 2023 at 6:21 AM
    geekhouse23
    Let me check what kit it was. I think there was more sides than that kit and it looked more round than that.
    EDIT: it's the bison kit and the guy got the kit for free. He said he would have got the taco tabs if he was to pay for a kit:
    https://www.tacomaworld.com/threads...adventure-build.302427/page-311#post-25734179
  5. Apr 27, 2023 at 7:50 AM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    lime others have said, hitting bumps and not having the bolts torqued can and usually will result in a failed alignment?
    in that one pic it looks like the tab is somewhat bent over, that can be causing your issues.
    I got the kpo kit after an alignment shop and a giant pot hole fubared some tabs and the bolt threads. I’m not sure if the pot hole or over torquing the bolt/nut did that. You can kinda see the gouged threads in the picture. I had not removed the bolt until that pic and the alignment shop should not have either. After that no matter what I did, it would not torque or stay solid. That bolt moved all around in there.
    I’m glad I got the kit I did. I just bent the tabs back over and will get the new ones welded on at some point.
    Thanks for sharing. I saw a comment about the bushings for the bison kit being a possible issue. Luckily the kpo has solid bolts so no extra bushings. I slathered them in anti seize before installing.
    geekhouse23[QUOTED] likes this.
  6. Apr 27, 2023 at 7:59 AM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    Need new Tabs for sure.
  7. Apr 27, 2023 at 9:51 AM
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    Several things could have happened here but one is what I think happened.
    1. Wheeled really hard and moved that lca cam which smashed the tab flat. By the way, check the ther 3 cams.
    2. Tech didn't torque the cams properly after completion of the alignment thus allowing movement and the tab smashing. Why didn't the other one do the same thing then? I guess it could have been a little tighter and held.
    3. The tech didn't loosen the bolt BEFORE turning other side to make the adjustment. I've actually stopped a tech from doing this during training and had a tech do this to my 4Runner. I had to use a cold chisel and hammer to get under it and bend it out a little then use a large pair of vice grips crimp REALLY tight to bend it out. Then the hammer again with a drift to get it as vertical as possible. I think this may be what happened because that cam is now upside down and looks like it was turned that direction, which, when the bolt isn't loosened, the oblong part of the cam turns and flattens the tab. The whole time the tech just thinks the bolt is stuck and keeps turning with a big wrench or an impact until he realizes what he's done and says "Oops"
  8. May 12, 2023 at 5:14 PM
    CBAD18Taco
    CBAD18Taco Well-Known Member
    Carlsbad, CA
    2018 MGM TRD OR 4X4
    Eibach Pro-Truck 2.0 front Coilovers Eibach Pro-Truck rear Sport Shocks JBA UCA Cali-Raised LED Rock Sliders 4WP Front Bumper w/wings Pro-Comp lights OB ARB compressor 265/75R16 General Grabber ATx tires
    Poly Performance website shows those are for 09-15, (2nd Gen) Tacos. No problem fitting them on your 3rd Gen?
  9. May 12, 2023 at 5:26 PM
    geekhouse23
    I have a 2nd gen
  10. May 18, 2023 at 2:26 PM
    CBAD18Taco
    Carlsbad, CA
    2018 MGM TRD OR 4X4
    I assumed you had a 2rd Gen since this post/forum is about 3rd Gens
