Alignment issues, will arms correct my issue?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UncleRick, Feb 23, 2021.
  1. Feb 23, 2021 at 4:54 PM
    UncleRick
    UncleRick [OP] Well-Known Member
    Rick
    2012 Tacoma Prerunner
    Before I dump $600+ on arms, what ya think?
    2inch lift, stock control arms
    Left.
    Camber 0.8.
    Caster. 1.4.
    Right
    Camber 0.7
    Caster 1.6
    My alignment tabs are
    Left.
    Rear. centered.
    Front centered
    Right
    Rear centered
    Front all the way inboard
    My truck was wrecked on the passenger side before the lift
    I'm wondering if high caster arms will allow me to sacrifice some of that high positive caster for better camber.
  2. Feb 23, 2021 at 4:57 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    That’s not enough info to answer your question. The answer is take it to a frame shop and have them check the specs. If you can get the alignment into stock numbers with the arms it still doesn’t mean everything is straight.
  3. Feb 23, 2021 at 4:57 PM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    What size tires? Are you rubbing? Does it wander on the road?
    Just trying to figure out your concern
  4. Feb 23, 2021 at 4:58 PM
    UncleRick
    Rick
    265/75r16 all terrains, no rubbing at all
    It drives good. Just I can notice the positive camber. My tires poke out at the top. Opposite of the tuner look
  5. Feb 23, 2021 at 5:09 PM
    UncleRick
    Rick
    I had the truck at the frame shop when it was wrecked out of my own pocket. Most of the damage was to the bed rear quarter.
    6 gearT444E[QUOTED] likes this.
  6. Feb 23, 2021 at 5:36 PM
    UncleRick
    Rick
    Seems like how I understand the SPC arms are adjustable for BOTH Caster and Camber independent of the lower control arms.
    Is this correct?
  7. Feb 23, 2021 at 5:39 PM
    eon_blue
    Azusa, CA
    That is correct
  8. Feb 23, 2021 at 6:11 PM
    UncleRick
    Rick
    Real question is of I go with JBA arms which gives me extra caster so I can sacrifice some of that high positive caster for better camber closer to zero.
    I found some newish JBA from a local club member that he went long travel. So I can save ALOT of money going with those vs the SPC. But if I can't make it work, then I gotta save up for the SPC
  9. Feb 23, 2021 at 6:24 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I have JBAs and had no issue getting 0 camber and I have my caster set at 4*.
  10. Feb 23, 2021 at 6:27 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    Spc arms all the way I have 3.75 to 4 degrees of caster and 0.camber.
  11. Feb 23, 2021 at 6:27 PM
    UncleRick
    Rick
    On my other tacoma, same thing, JBA arms, 3inch lift, 3.75 of caster, 0 camber. BUT this Tacoma the cam adjuster is maxed out.
  12. Feb 23, 2021 at 6:29 PM
    UncleRick
    Rick
    I can get the JBA arms with 15k miles for $250 or the SPC for $600+.
  13. Feb 23, 2021 at 6:30 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    you should be good then, as long as the cams aren’t seized up
  14. Feb 23, 2021 at 6:32 PM
    UncleRick
    Rick
    Nope. Cams are good. I checked that before I did the lift, knowing my 09 had frozen cams and it was a nightmare. Just totally freaks me out that one is totally pulled in and the rest are dead center.
  15. Feb 23, 2021 at 6:33 PM
    gotoman1969
    Imo. Whenever I see an adjuster maxed out. Tells me the alignment guy wasn’t fully aware of what to do and just kept adjusting until numbers looked good. The adjusters when done properly should be mirror images of each other.
    6 gearT444E likes this.
  16. Feb 23, 2021 at 6:41 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    ive seen them off to correct for an unknown bent steering knuckle.
  17. Feb 23, 2021 at 6:42 PM
    Muddinfun
    Muddinfun Well-Known Member
    Move the right rear cam all the way outward. That will increase caster and decrease camber. Both good. Then since the left cams are currently in the middle, you should have plenty of room for adjustment to match the right.
  18. Feb 23, 2021 at 6:43 PM
    gotoman1969
    Correct. I was making the assumption of no bent suspension stuff. But yes if something is bent they may be different.
  19. Feb 23, 2021 at 6:46 PM
    gotoman1969
    Hey Mudd you know what confuses me. When I was mechanic and did alignments. I’d always take all the adjusters and set them neutral and start from there so everything was being done the same from side to side, so many guys now just start from where the adjusters sit and imo that’s what messes them up.
  20. Feb 23, 2021 at 6:54 PM
    Muddinfun
    I don’t care where the cams start. You need to turn the cams in the direction that improves the alignment. When you run out of adjustment, then you start worrying. There are so many things that affect the alignment that I would never expect the cams to be exactly the same side to side.
