Alignment issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Todor, Feb 8, 2012.
  1. Feb 8, 2012 at 9:18 AM
    Todor
    Todor [OP] Active Member
    Todor
    PHX AZ
    2007 Tacoma V6 4.0 PreRunner
    3" lift kit with Bilstein 5100 Height Adj. Coilovers. DDM Tunning HID's all around OEM Skid Plate Bed Lights MOD DIff. Breather MOD ABS Kill Switch MOD Fog Lights ON MOD HI LIFT Mag Light MOD LED Interior Lights Pioneer AVIC D3 Installed Python Remote Start Alarm Light Racing UCA's WeatherTech DigitalFit Mats AFE Pro Dry S Cold Air Intake Custom Exhaust with Flow master 41 Series muffler RedLine Tuning Hood Quick Lift Elite
    I got my lift installed saturday and i put new wheels and tires(285/70/16) . I went with a 3" inch in the front and 2" add a leaf in the back. Adjustable billies in the front with new coils from toytec. Took the truck for alignment today and these are the specs :
    After 1st alignment done (1st Pic) - Pulls to the left
    After 2nd Alignment done (pic2) - Still pulls to the left( did a tire swop to see if its just a tire pull and improved a lot but there is still a pull to the left)
    Discount tire just ordered me a new tire to see if anything will improve....
    What do u guys think ....????
    I dont think that the caster on the alignment can cause such a pull since its pretty even... Although it should be around 2.4 it wont get there because i have stock UCA's
    Any suggestions????
  2. Feb 8, 2012 at 9:20 AM
    ffemt2987
    ffemt2987 Shut up Hippie!
    Austin
    Golden
    Cement 3rd gen that was supposed to stay stock
    Rack, sliders, softopper, tjm bumper, eibach temp suspension
    new UCA's?
  3. Feb 8, 2012 at 9:34 AM
    Todor
    Todor
    PHX AZ
    Stock
  4. Feb 8, 2012 at 11:28 AM
    ffemt2987
    Austin
    Golden
  5. Feb 8, 2012 at 11:29 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    This
  6. Feb 8, 2012 at 11:35 AM
    Cbass38
    Cbass38 Well-Known Member
    sebastian
    scottsdale
    07 pre runner
    projector hids,wheels,small lift,flowmaster
    cross rotate your front tires-may be a tire pull-yes even tho they are new
    your specs arent bad. camber is about even right? caster is even also? we generally have a caster lead of .5-1.0 degree to compensate for road crown. if camber and caster are jsut about even on both sides then its not an alignment issue.
    caster will not wear tires.camber will.
  7. Feb 8, 2012 at 11:57 AM
    OZ-T
    Peter North
    British Columbia
    Caster should be like 2.5 no ?
  8. Feb 8, 2012 at 12:27 PM
    Cbass38
    sebastian
    scottsdale
    07 pre runner
    caster is generally like 2.0-5.0 depends on the cars/trucks
    chrysler 300s,chargers,magnums,challengers have caster at like 10.0-12.0 all of em drift right w/ road crown to.
    .4 is probably out of specs,but wont hurt anything, and wont cause to pull left at all.
  9. Feb 8, 2012 at 12:39 PM
    bowman
    bowman Member
    Dustin
    Etowah N.C.
    2003 whitey ext. cab 4x4
    Bilstein 5100's front and toytec aal with bilstein 5100's in the rear. blue led's in cluster home made carrier drop bracket
    Caster is low but as long as it is even it should not pull, just be touchy on steering movement. Caster is the forward or rearward of the tire in relation to the centerline of axle. Caster will always pull to the most negative(rearward) side. Caster will not ever cause wear to the tire. Camber or Toe is the only adjustments that will wear tires. Are you sure it is a pull and not just steering wheel off center? Steering wheel centering is done by toe adjustment and even though toe numbers are good it can be manipulated by setting steering wheel off center when adjustment is made. A pull is described as letting go of steering wheel and truck drifts off straightness. An off center steering wheel is described as when steering wheel is straight truck does not track straight down the road.
  10. Feb 8, 2012 at 12:41 PM
    OZ-T
    Peter North
    British Columbia
    Just saying caster on a lifted Tacoma should be around 2.5 - 3
