Alignment issues
Discussion in 'Suspension' started by VA SOFTACO, Jun 3, 2017.
  1. Jun 3, 2017 at 9:36 AM
    VA SOFTACO
    VA SOFTACO [OP] ...because who buys hard tacos
    Beauregard
    Virginia Beach, VA
    2015 Tacoma MGM OR DCSB
    I have a 2015 DCSB Offroad with 5100's all around, 887 springs and Headstongs 3 leaf AAL. Also have Total Chaos UCA. My tires are 265/75R16.
    The truck has a slight pull to the right. I got two alignments done from the same place, they even tried swapping front tires to make sure it wasn't the tires. Here are my print outs.
    Initial after lift
    After first one which I asked for a 2.5 caster
    After they tried the tire rotating and still pulling. This is the numbers they came up with
    It still pulls to the right some. What can I do besides find another place
  2. Jun 3, 2017 at 6:30 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    That's a lot of caster. o_O
    Try lowering the caster on the drivers side. I'm assuming your roads have a considerable crown to them?
    Kyitty likes this.
  3. Jun 3, 2017 at 9:46 PM
    VA SOFTACO
    Beauregard
    Virginia Beach, VA
    Yes and they test drove it on two different road types and I even tried every lane on the highway with the same pull
  4. Jun 3, 2017 at 10:04 PM
    Justinlhc
    Lower the caster on driver side. They should know that.
  5. Jun 4, 2017 at 3:55 AM
    VA SOFTACO
    Beauregard
    Virginia Beach, VA
    How far is too far of a distance between the two caster numbers? I'm thinking they should lower both side closer to 3.0 anyway
  6. Jun 4, 2017 at 7:31 AM
    Justinlhc
    I agree.
    I'd try 2.8(driver)and 3.2(passenger).
    VA SOFTACO[OP] likes this.
  7. Jun 4, 2017 at 10:19 AM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    Usually want a .5 difference
  8. Jun 4, 2017 at 3:07 PM
    VA SOFTACO
    Beauregard
    Virginia Beach, VA
    Ok i eikk try to get then to lower the caster to those numbers. Different caster numbers wont prematurely wear the tires?
  9. Jun 4, 2017 at 3:10 PM
    Justinlhc
    Caster is a non-wear measurement. It does not affect tire wear, only steering/drivability. It *should* fix your problem.
    Kyitty likes this.
  10. Jun 4, 2017 at 3:15 PM
    VA SOFTACO
    Beauregard
    Virginia Beach, VA
    Awesome. That is what i thought. What range of toe and camber should i get then to stay around?
    Sorry for all the questions as i am new to the lifted truck life
  11. Jun 4, 2017 at 3:32 PM
    Justinlhc
    As close to 0 as possible and it looks like your setup will allow 0 camber with the caster you're after. They shouldn't have any issues getting it there since they were able to get 4.5° caster at close to 0 camber already.
  12. Jun 4, 2017 at 6:15 PM
    VA SOFTACO
    Beauregard
    Virginia Beach, VA
    Well it is Firestone, soooooooo :rofl:
  13. Jun 6, 2017 at 12:23 PM
    Frankenstuff
    Frankenstuff Busy iracing
    Frankie
    16TRDORDCsb 4x4 & 2020 BMW M2 competition
    16 trd ORdcsb4x4 c4 swingout rear, cbi t3 front , arb lift,16"grabber x3 rtt, hilift,jerry cans,and sliders . 81 hilux trail donkey
    Did you ever consider they are lying to you? Ever wonder why a straight axle in the rear has toe and camber?
  14. Jun 6, 2017 at 12:26 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Holy crap that's a lot of caster! 4.5??
  15. Jun 6, 2017 at 12:29 PM
    Frankenstuff
    Frankie
    I don't even think that's for his truck ... that is a print out for a 4wheel alignment.. Trucks get a thrust angle alignment... sorry to say but I believe the shop has got it "close " and is lying.
  16. Jun 6, 2017 at 12:57 PM
    VA SOFTACO
    Beauregard
    Virginia Beach, VA
    The rear number I could care less about because there really is not adjustment there. Yes 4.5 caster and ZERO rubbing now but holy crap the bump steer and still pulls to the right some.
  17. Jun 6, 2017 at 12:59 PM
    Frankenstuff
    Frankie
    Red flag to me
  18. Jun 6, 2017 at 1:32 PM
    VA SOFTACO
    Beauregard
    Virginia Beach, VA
    Why? I see many posts with rear alignment numbers
  19. Jun 6, 2017 at 1:32 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    Could be. Certainly hope not!
  20. Jun 6, 2017 at 1:33 PM
    Justinlhc
    It looks just like every sheet I've seen for a Tacoma. The rear axle is solid and not adjustable, but they still show the numbers. You can adjust toe slightly by loosening the u bolts and shifting the axle. Camber is never a perfect 0° even on a solid axle.
