Alignment issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lunatic209, Jun 7, 2019.
  1. Jun 7, 2019 at 11:04 PM
    Lunatic209
    Lunatic209 [OP] Well-Known Member
    17 Inferno TRD
    I've had to get an alignment done on my truck twice already at 39k miles and it's out of spec again. Stock wheels and tires, non lifted. Is it common or does mine have an issue? My steering wheel has alot of play and I'll have to hold it left when driving straight on a smooth freeway
  2. Jun 8, 2019 at 3:16 AM
    Clearwater Bill
    Billy
    Largo Florida
    Not common.
    Lots of potholes in your area? Offroading some?
    Who is doing the alignments? Dealer? Big box store?
    shakerhood likes this.
  3. Jun 8, 2019 at 4:09 AM
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    Check your steering rack bolts and bushings. The bushings are quite soft on the 3rs gens which can make it hard to get a good alignment, and the bolts have been known to be or come loose.
    Ronzio and Lunatic209[OP] like this.
  4. Jun 8, 2019 at 6:28 AM
    BlackTRD4Me
    BlackTRD4Me Well-Known Member
    Sean
    2017 Toyota Tacoma Off Road
    Bull bar with lights, Wheels on stock tires, window vents.
    My 2017 Off Road is a little off as well, thanks for the tips about the bushing, although I live in a place where there is more potholes than pavement.
  5. Jun 8, 2019 at 9:08 AM
    Lunatic209
    17 Inferno TRD
    Not that many potholes and very minimal off roading. Hunting trips on forest roads that a 2wd wouldn't even have an issue going through. Alignments were done by Toyota dealership.
  6. Jun 8, 2019 at 11:02 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Definitely not normal. 60K on mine and 2nd set of tires with zero issues.
    G.
    Lunatic209[OP] likes this.
  7. Jun 8, 2019 at 2:37 PM
    Clearwater Bill
    Billy
    Largo Florida
    I'd recommend finding a smaller shop that specializes in alignments in general but trucks in particular. Some fellow local owners might be a good way to find that special place.
  8. Jun 8, 2019 at 2:54 PM
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    Whatever you do, do not bring it back to the dealer. They only hire incompetent mechanics.
  9. Jun 9, 2019 at 9:06 AM
    Lunatic209
    17 Inferno TRD
    I'll look around for smaller shops after new wheels and tires go on.
    What are the main culprits if my alignment goes out of spec so often?
  10. Jun 9, 2019 at 9:11 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I think the front coils break in and sag a little. Was the inside of the tire wearing faster than the outside?
  11. Jun 9, 2019 at 1:44 PM
    Lunatic209
    17 Inferno TRD
    Inside was wearing faster
  12. Jun 9, 2019 at 2:05 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Both my insides were. I chalked it up to front coil sag.
  13. Jun 9, 2019 at 2:13 PM
    Lunatic209
    17 Inferno TRD
    You believe so? So could alignment be adjusted to compensate for that cause I dont want to spend $100 every 6 months for alignment.
  14. Jun 9, 2019 at 2:27 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Yup! It just needs an alignment if tires are wearing uneven.
  15. Jun 9, 2019 at 2:39 PM
    imovelives
    imovelives Well-Known Member
    Erwin
    San Diego
    18 Tacoma TRD off-road 4x4
    Flowmaster, Pace Edwards Jackrabbit, bedrug, pop n lock TAILGATE lock Kuat Bikerack NV, PioneerNDBC8 front camera, pioneer avh-w4400nex head unit, DWG D10 17x9, good year wrangler ultra terrain AT Kicker speakers font/back Max Modular KBvoodo 10 inch rack (linger on short bed) Freespirit high country medium RTT Pedal Commander
    I’ve had mine aligned 2x with 12k miles on it. Pulled to the left, then steering wheel off center, both after off-roading with lots of rocks. Dealer did both under warranty.
  16. Jun 10, 2019 at 8:55 AM
    Lunatic209
    17 Inferno TRD
    Looks like we're in the same boat
  17. Jun 10, 2019 at 8:55 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    If you're off-road a lot it could just be getting bumped out of alignment.
  18. Jun 10, 2019 at 9:02 AM
    imovelives
    Erwin
    San Diego
    I’ve gone off-roading 3 x since i bought the truck. Each time, I take it real easy ad go super slow since I’m on factory suspension. I never had this issue in previous vehicles, my old rubicon did well and did not have any alignment issues after 4 years of off-roading, even my Subaru was fine after light off-roading. But seems like the tacoma doesnt do as well, any aftermarket parts out there that could prevent this? Just curious before I lift it.
  19. Jun 10, 2019 at 9:14 AM
    Lunatic209
    17 Inferno TRD
    Since the last time I got alignment done 6 months ago I haven't been off road at all
  20. Jun 10, 2019 at 9:19 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    More info is needed like who is telling you that your alignment is off and how bad is it? I always found it interesting that techs that are getting paid to do an alignment will tell someone their alignment is off even if they had it done the day before, but let warranty work come up and the alignment is always perfect.
    Your suspension is pretty rigid and a pothole won't change your alignment. If that were the case, you would need an alignment everyday. Something would have to bend for that to be the case and it just doesn't work that way. Settling is what most commonly changes your angles and that occurs over time.
    You claim that you have to hold it to the left so does that mean that it pulls to the right? That should be pretty evident in your alignment specs if it is caused by alignment and specifically your caster. Do you have a print out that you can post of your alignment specs?
    Lunatic209[OP] and xsf18cdf like this.
